Off-axis grayscale problem - AVS Forum | Home Theater Discussions And Reviews
post #1 of 1 Old 11-01-2012, 11:06 PM - Thread Starter
iunit's Avatar
I have a Samsung 40ES6100 and I noticed a peculiarity for black and white images viewed from the side at an angle greater than 50 degrees. Some gray gets a yellowish-red color. Best seen on an image to grayscale. Panel that it is s- pva and my theory is that appears when you open all 4 parts of the pixel.
I want to see if the problem is specific panel or the producer, so I invite you to do the same type of photos and specify the type of panel that you have. It is advisable to use the settings that you like the most, however I noticed that the problem is not major boost in one way implied that comes factory set.
This is the pixel structure you see shades of gray up to 50% or above this value.
iunit is offline
Reply LCD Flat Panel Displays
