LG 47LM4600 - Page 12 - AVS Forum | Home Theater Discussions And Reviews
post #331 of 362 Old 12-07-2013, 09:33 PM
SuperSVGA's Avatar
I updated my 47LM4700 to 03.40.10, but I didn't notice any difference from the official 03.40.08. I can't extract the firmware file from LG's site without the AES key. There might be a chance I could figure that out from the TV itself. but the 47LM4600/4700 don't have the RS-232c service port attached and I don't feel like tearing my TV apart. The only thing I have to look at is the source, and I don't know if the source is the official or engineer source, or even past that.
When I first updated the TV from the original firmware to 3.40.08, some things changed a bit. The option for LED Dimming (when enabled in the service menu) had disappeared from the user menu. The option still exists in the service menu, and I haven't tested whether it actually works. I also can no longer find the firmware rollback option. Previously I could get to it by pressing the Settings button and pressing the '9' key 7 times. I also used to be able to force firmware upgrade by pressing the '7' key 7 times, but now I have to press the '2' key 7 times.
SuperSVGA is offline
post #332 of 362 Old 01-24-2014, 11:37 AM
Nu11u5's Avatar
I puchased this TV about a year ago.
In fast motion I've noticed that the display will retain 2 or 3 frames, making high contrast images blurry and even nausiating to watch. This is especially a problem with games.
Is this a problem with the panels response time, or is it due to some kind of post processing that I can adjust?
Nu11u5 is offline
post #333 of 362 Old 01-24-2014, 12:15 PM
UHD Addict
aaronwt's Avatar
Quoted: 5186 Post(s)
Liked: 3097
I've not noticed any issues when playing games from my secondary XBOne on my 47LM4600. It is an LCD though. My main display is a DLP which can display an image many,many times faster than any LCD TV can.
53TB unRAID2--41TB unRAID3--35TB unRAID1a
Sony 65x850C--Samsung UBD-K8500--Sony HT-NT3
XBL/PSN: WormholeXtreme
aaronwt is online now
post #334 of 362 Old 01-27-2014, 04:02 PM
SuperSVGA's Avatar
Does anyone know how the 24p Real Cinema Works on the 60hz panel? It looks nothing like movies from a 60p source. It's almost like having a 24p source fed to it enables the hidden trumotion feature.
post #335 of 362 Old 02-05-2014, 02:34 PM
Dig and Spike's Avatar
Where did you find 03.40.10? I looked on LG's website, but I could not find it...
Dig and Spike is offline
post #336 of 362 Old 02-05-2014, 02:35 PM
Does the LM4600 series support 24p?
post #337 of 362 Old 02-05-2014, 02:58 PM
UHD Addict
aaronwt's Avatar
Liked: 3097
Yes. It applies 3:2 pulldown to the 1080P24 input to go to 1080P60.
post #338 of 362 Old 02-05-2014, 05:17 PM
SuperSVGA's Avatar
I had to go into the In-Start with a remote and change some setting to engineer firmware. I then used the internet update.
It has a Real Cinema 24p setting, when enabled and fed a 24p source it identifies that as a 24p source and adjusts accordingly.
Dig and Spike likes this.
post #339 of 362 Old 02-08-2014, 03:30 AM
Thank you!
post #340 of 362 Old 02-08-2014, 03:33 AM
Thank you
post #341 of 362 Old 02-08-2014, 03:35 AM
Thank you SuperSVGA!
post #342 of 362 Old 02-08-2014, 09:33 AM
UHD Addict
aaronwt's Avatar
Liked: 3097
This is a 60Hz TV. All it does it accept the 24P signal and apply 3:2 pulldown. The same as any other 60Hz TV. This TV does not do interpolation and create frames in between existing ones. Creating the so called Soap Opera effect. This TV just has regular 3:2 pull down.
I have been enjoying this TV in my secondary viewing location for the last 13 months. It was a nice deal at Best Buy when I got it in January last year.
post #343 of 362 Old 02-10-2014, 03:46 PM
SuperSVGA's Avatar
But that doesn't explain why the TV's 3:2 pull down is better than any other device, or why it needs a different display mode for 24p. I've recorded it at 120fps and compared it to the TV's normal mode slowed down and there is a slight difference between them and also a noticeable backlight flash.
post #344 of 362 Old 02-10-2014, 04:54 PM
UHD Addict
aaronwt's Avatar
Liked: 3097
I still see judder from this TV like every 60Hz TV I've viewed. If it were truly at 120Hz and it applied 5:5 pulldown, there would be no judder.
post #345 of 362 Old 02-20-2014, 11:19 AM
VOTE4DALEK's Avatar
I wish I wouldve found this thread before buying my 55LM4600. I was coming from an old Philips LCD with its version of trumotion caused a bit of soap opera, but in a way I found enjoyable. I really loved the motion on that TV but it was a 47" and contrast was poor, so I would have nearly unviewable images when the screen was mostly black (The Walking Dead for example)
SO I got a great deal on a 55LM4600 and thought I was going to love it, but having REALLY bad issues with the juddery motion. I am wondering if there are ANY settings to reduce this effect, as LG doesnt seem to care.
Now, they've sent three technicians out, replaced the main board, but it always has the SAME judder motion. Ive tried to argue that they've sold me a 60hz panel when the box said 120hz, and attempt them to replace it with a true 120hz panel with no luck.
If ANYONE has any advice for me, please let me know.
VOTE4DALEK is offline
post #346 of 362 Old 02-20-2014, 11:36 AM
VOTE4DALEK's Avatar
Hi there I am writing those that seem to be having the same issue as I with LG regarding the LM4600 series. I recently purchased the 55" model of this TV and the judder is unwatchable, and LG seems to have NO issues with selling a 60hz quality set with lies on the box. I am wonder if you ever reached a conclusion with LG that might allow myself or others to receive the same solution. Furthermore, if there were any further actions taken between you and LG that you can share I would love to hear about them.
I would also love to know if you found any particular settings that helped with the issue.
post #347 of 362 Old 03-21-2014, 10:48 AM - Thread Starter
abbigabbi's Avatar
Originally Posted by abbigabbi View Post
LG 47LM4600 This thread is to help me and anyone else with issues, calibration advice and all other subjects for owners of this 3D HDTV. I personally seeking Sharpness setting advice, and also would love to here someones calibration advice OR OWN PERSONAL SETTINGS (in detail) I've recently purchased this tv and can't seem to find much out there on the net on it.. Come on guys dive in...any advice or input on anything to do with this HDTV calibration would be great...
Hi All, When I started this thread I had Full intention on posting my settings when i figured them out with the Disney WoW calibration disc...I posted the results but recently realized they never actually uploaded on this forum.
For what it's worth...here they are....
Back Light --- 50
Contrast
91
Brightness -- 51
Sharpness - 54
Color
51
Tint
0
Color Temp 0
All options such as Clear White, Dynamic blah blah blah control and etc are ALL OFF....
Black Level set to LOW
For gaming on my PS3/PS4 I have My GAMMA set to LOW --- the blacks seem more accurate this way for some reason---crush less...
For TV/MOVIES the GAMMA is set to MEDIUM usually.....
For comparison to your surroundings...my living room is usually lit well so lighting both sun and bulbs are usually lighting the room fairly well..(not to dark in my living room)
I spent allot of time trying to get the best out of this TV with allot of GREAT help from here...this has been the best i have achieved...
abbigabbi is offline
post #348 of 362 Old 03-24-2014, 12:46 PM
nags425's Avatar
Hello, im not the most knowledgeable person when it comes to tv but im not completely stupid.
I have owned this tv for about a year and use it a lot for gaming on my xbox 360 and xbox one.
I have noticed a lot of textures loading very very slowly and was wonderi g if this could be a problem caused by the tv. gta5 and dead rising 3 were terrible.  I would walk up to a building and sit for 10sec or more as the detail started to slowly creep on to the building I was standing right in front of. Ive tried 2 different xbox 360s and now an xbox one, so it is not a problem with the console.
And I dont believe its just the way the games are cause ive shown others and they said that theirs doesnnot do that.
The only thing I can think of is that the is the cause. The only other weird thing in the system is that we have a old house with old electical wiring but I dont see that effecting it.
nags425 is offline
post #349 of 362 Old 04-10-2014, 05:19 PM - Thread Starter
abbigabbi's Avatar
I have seen that same thing while playing Battlefield 4 online...I was never sure if it was the TV or the Internet connection or possibly the Server...
post #350 of 362 Old 04-10-2014, 05:51 PM
UHD Addict
aaronwt's Avatar
Liked: 3097
It's not the TV.
post #351 of 362 Old 04-16-2014, 05:25 PM
nags425's Avatar
I dont think mine has to deal with the internet as it will also happen when playing single player
nags425 is offline
post #352 of 362 Old 06-02-2014, 10:37 PM
Italystallion5's Avatar
I know that it's been a while since a lot of the "soap opera effect" problems have been addressed but I have found the solution with the push of a button! Go into "Settings" then "Picture" and scroll down under picture mode until you come across "Advanced Control". Once you're in there scroll down until you come across "Real Cinema" then just simply click it to "off". I tested this with a blu ray on my ps3 because all of my blu rays produce the "soap opera effect" which I abhor. I turned "Real Cinema" on and off several times and without fail when this option is turned on, SOAP OPERA ALL THE WAY! Unfortunately it took me a few years to figure this out haha. I plan to keep that feature on only when I'm watching television because it doesn't seem to have any negative effects while viewing that HD content, but for blu ray movies I will most definitely be turning this off! I held back with buying blu rays for a long time because of the "soap opera effect" but now I intend to stock up!
Italystallion5 is offline
post #353 of 362 Old 06-03-2014, 07:25 AM
UHD Addict
aaronwt's Avatar
Liked: 3097
What soap opera effect problems? This TV never had any. It's only a 60Hz TV. Mine has never done any frame interpolation.
post #354 of 362 Old 07-06-2014, 02:15 AM
SuperSVGA's Avatar
It appears it has some sort of frame interpolation but only with a 24p source.
post #355 of 362 Old 07-06-2014, 06:33 AM
UHD Addict
aaronwt's Avatar
Liked: 3097
I've never noticed any with mine. It's doing 3:2 pulldown to go from 24P to 60P. But that is normal for a 60Hz TV. And you have judder.
Was there ever another firmware update for this TV?
post #356 of 362 Old 07-26-2014, 02:44 AM
SuperSVGA's Avatar
All I've seen is the engineer 03.04.10 update which has been there for a while. Just so you know, the update file for this tv is exactly the same for many other LG TVs in a similar product line.
post #357 of 362 Old 06-30-2016, 07:03 PM
Liked: 0
My LG 47LM4600 TV does not pass-through 5.1 surround signals from its HDMI inputs (e.g. Sony Blu-ray player & DirecTV receiver) to its optical audio output (which I feed to my Kenwood surround-sound receiver). The TV passes (apparently down-mixed) stereo, but not 5.1 surround sound. If I connect the Toslink/SPDIF outputs of the Blu-Ray player or DTV receiver to the Kenwood receiver, the surround sound works perfectly. I messed with the TV's audio settings to no avail.
I search on the web and saw other LG owners complaining about this problem. Some people said that 5.1 pass-through can be enabled in the TV's hidden service menus (known as "EZ-Adjust Menu" and "In-Start Menu"). However, when I accessed those menus (via the AnyMote Universal Remote Android app on my Galaxy S5), I couldn't find any setting that fixed the problem.
Does anybody know how to enable 5.1 pass-through from HDMI to optical out?
I don't have enough digital inputs on my amp to handle all of my players (BRP, Xbox, Kodi, WiiU, DTV, & PC). And it's really convenient not to have to switch the amp for each video source (instead of simply leaving it set to "TV").
Razzmctazz is offline
post #358 of 362 Old 06-30-2016, 07:07 PM
Liked: 0
By the way, the TV, has the latest official firmware from LG's site (v03.40.08).
post #359 of 362 Old 06-30-2016, 07:12 PM
UHD Addict
aaronwt's Avatar
Liked: 3097
Get a switch to connect the extra devices. I use several HDMI switches in all my setups because four to eight HDMI inputs are not enough at each tv/receiver. Even when I used component and optical in the late 90's and early 2000's I used switches to handle all my devices
post #360 of 362 Old 07-02-2016, 10:36 AM
Liked: 0
Thanks, but my receiver doesn't have HDMI inputs. If I could just get the TV to pass-through 5.1 from HDMI to Toslink, that would be perfect.
Reply LCD Flat Panel Displays
Lg , Lcd Hdtv
