Sony KDL-32LL150 Horizontal Line, suggestions.... - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 11-04-2012, 06:48 PM - Thread Starter
ultimatek's Avatar
Hello, i have this wierd problem with a Sony KDL-32LL150, suddently playing sesame street on my PS3, the tv showed this thin horizontal red line(mostly red, but it changes colors depending on the background, and yes it still shows when i press the menu button).
Turned off the TV, turned on again then it came with some other vertical multicolored columns(pink mostly) from the bottom of the tv up to the crossing of the horizontal line, after a few minutes these columns disspaeared, never saw them again. Still the horizontal line have stayed on the tv forever.
Was wondering what are my chances of a faulty TCON board($45 bucks @ ebay) or something else like TAB bonding issue or cable...
if is something cheap i will fix it, but if it costs too much, will leave it as it is...im starting to adapt my eyes to ignore the freaking line. Thanks in advance...
ultimatek is offline
post #2 of 2 Old 03-07-2013, 05:41 PM
joeavs2013's Avatar
Not sure if you still have the TV but a very simple thing you can try is unplugging the wire Harness ( has about 8 wires?) that leads into the LCD screen. It's a multi-wire plug that is the last wire stage I think going into the LCD panel. It is 3/4 up from the bottom and directly centered. You'll have to take the back cover off obviously, but that is pretty simple.
I had a very screwed up display with mine when it was 1 yr old but still brand new pretty much unused. I think I remember a bunch of weird horizontal lines and strange colors making the picture look like a cartoon. It was involved in a house move, so not sure if something went wrong such as it getting set down hard or?
Anyway, I fixed mine by unplugging that wire harness, blew some canned air into the receptacle and plug, plugged it back in and the pic has been fine ever since! I was lucky I guess. It really has never given me a problem since except that it won't accept the remote commands anymore either, which went out shorty after the screen was remedied.
joeavs2013 is offline
Reply LCD Flat Panel Displays
Sony 32 Bravia Lcd Hdtv Kdl 32ll150
