"Dark Corners" on new Sony Model KDL60EX645 - possible generic issue - AVS Forum | Home Theater Discussions And Reviews
post #1 of 16 Old 11-07-2012, 11:50 AM - Thread Starter
rexbo's Avatar
Just wanted to let the forum community know that I may have encountered a possible generic (I would call minor) flaw with the new 60" Sony LED line of TVs. I recently bought a new KDL60EX645 and discovered that it exhibited a small "dark area" angling up diagonally out of both the left and right lower corners of the screen, otherwise the set was very good. The dark spots are barely noticeable during "normal" viewing with varied colored background/images, but are easily spotted against a white, yellow, light blue, light grey, etc screen. It's almost like the opposite of flash-lighting. It almost seems like a shadow or smudge trapped underneath the outer screen.
Anyway, I decided to exchange it for another unit, and was able to swap to a different tv with a serial number separated by over 9000 and built about two months apart. The replacement set has the EXACT same shadow/dark spots in the same locations. I can now say that this model Sony has a generic flaw, or I just happen to be a victim of quite a coincidence.
I just wanted to get this info out, so that anyone else considering this particular model can have a "heads-up". I would welcome anyone else to share their experience if the too own or purchase this model. I would also welcome any opinion as to what may be the cause of this condition. The dark spots are present on every input and present with or without a signal. No picture adjustments affect them either, but the backlight and contrast will "interact" so to speak with the dark spots, altering their prominence slightly, but it's just masking the effect not actually changing anything.
At this point I will likely keep the set, because besides for this issue everything else is quite good. No significant/noticible banding or DSE, no flash-lighting or clouds, good picture quality, etc.
Thanks for listening!
rexbo is offline
post #2 of 16 Old 11-07-2012, 03:14 PM
barber76's Avatar
My blind guess is, this is caused by screen surface not being perfectly flat (some kind of a tension points in the corners), and has nothing to do with non-uniform back-lighting.
barber76 is offline
post #3 of 16 Old 11-07-2012, 11:53 PM
Do-It-Yourself's Avatar
Location: In a house far away from you creeps (hopefully)
Liked: 24
Like the vignetting effect in pro cameras?
Do-It-Yourself is offline
post #4 of 16 Old 11-07-2012, 11:59 PM
EscapeVelocity's Avatar
Quoted: 528 Post(s)
Liked: 290
This sounds like what is being reported on some Vizio E601-A3's.
My theory is that it is a by product of trying to avoid flashlighting by removal of LED's from the corner area of an Edge Lit panel, producing instead of light areas angling from the corner, a dark (reverse) flashlighting.
Epson 8350 / Panasonic AX-200u / Optoma Graywolf 92" / Draper Luma 92"
Samsung 51F8500 / Panasonic P50ST60 / Vizio P502ui-B1 / Sony 50W700B LCD
Sony S790 / Panasonic BDT-220 / Roku 2 XS & Roku 2
Samsung F550 / Speakercraft CS3 / Yamaha YAS-105
EscapeVelocity is offline
post #5 of 16 Old 11-09-2012, 04:29 PM - Thread Starter
rexbo's Avatar
Update...
After spending more time with the set, I can add a few fresh observations:
I don't think that it's a "reverse flashlight" because the same lower corners do have moderate flash-lighting in a dark room and dark onscreen image. I think it's a mechanical issue in the way the various screens and panel interacts in the lower corners. If I push/pull on the parts of the frame/bezel near the corners, I seem to be able to very briefly alter the magnitude of the darkness/size of spot. It's as if the screen is contourted in some sort of way that a shadow is being cast and appears on screen.
I am kind of surprised this is not being noticed/reported in other large (60" plus) Sony's
rexbo is offline
post #6 of 16 Old 11-12-2012, 04:18 PM - Thread Starter
rexbo's Avatar
Update 2:
Exchanged the second set for a third, attempting to eliminate what became an unacceptable backlight bleed.
Anyway the third set (serial number about halfway between the first two) has the EXACT same dark spots in the lower corners. Unfortunately set three also has backlight bleed.
Sony's quality control must be very, very poor
Still like the picture though
rexbo is offline
post #7 of 16 Old 11-14-2012, 05:48 PM - Thread Starter
rexbo's Avatar
Update 3:
Exchanged the third set for a fourth, in a continuing attempt to eliminate unacceptable backlight bleed.
Anyway the fourth set (serial number one off from TV 1) has the EXACT same dark spots in the lower corners.
BUT thankfully the backlight bleed although there is minor an I can live with it
Anyone looking to buy this TV needs to stay above a serial number of 501000 and and past a September build date or risk nasty flashlights
rexbo is offline
post #8 of 16 Old 11-15-2012, 01:23 PM
barber76's Avatar
Originally Posted by rosskings View Post
yeah, i think so,that it is a by product of trying to avoid flashlighting by removal of LED's from the corner area of an Edge Lit panel, This sounds like what is being reported on some Vizio E601-A3's.
Two different explanations.
barber76 is offline
post #9 of 16 Old 11-15-2012, 02:00 PM - Thread Starter
rexbo's Avatar
I am sure that the LED's are present in the corners...
I am now convinced after having 4 of the exact same tv's in my living room, that it is a shadow or some other sort of light distortion caused my how everything is assembled.
It's important to note that these two lower corner "shadows" are VERY subtle and do not spoil normal viewing. If you are watching the TV normally, with your eyes focused primarily center screen, you won't even notice it.
Basically you have to be looking directly at the corner when a light colored background is present.
rexbo is offline
post #10 of 16 Old 11-21-2012, 08:10 PM
chong67's Avatar
Another one bites the dust ... not getting this TV. Dont know what to get now.
chong67 is offline
post #11 of 16 Old 11-22-2012, 08:18 AM - Thread Starter
rexbo's Avatar
Just to be fair, this is a very good tv for the money. I have decided to keep my current unit, and as I had mentioned the "dark spots" are not significant in normal viewing.
rexbo is offline
post #12 of 16 Old 11-22-2012, 12:00 PM
barber76's Avatar
barber76 is offline
post #13 of 16 Old 11-22-2012, 12:28 PM
chong67's Avatar
Originally Posted by barber76 View Post
Yes, I have done alot of reseach and no matter what HDTV you buy, there is something good and bad in all of them.
I want a HDTV with full array of backlite, not just a few, and local dimming. That would cost me 2K.
I wonder if I will hard press to find all these defect on anyTV. I dont have good eye sight for one thing. :-) I wear minus 12 contact lens.
chong67 is offline
post #14 of 16 Old 11-25-2012, 06:31 PM
tattooedbones's Avatar
Hi,
I'm just about to upgrade my Sony 46" to this KDL60EX645 model. I'm sort of used to this "dark corner" effect you are describing. It's really not too bad in normal viewing.
Do you have a recommended setup / settings that you're using ? Thanks.
tattooedbones is offline
post #15 of 16 Old 09-18-2014, 06:29 PM
Liked: 0
2014 Sony has same problem?
Hi guys,
I just got a Sony 630B with the same noticeable dimming the OP is describing. It's in top the corners (esp right) but what's odd is that my twin just got the same one and doesn't seem to have this issue.
Otherwise, it's a fantastic set. Treats lower def content nicely and has slightly crisper hi-def than the Samsung panel I had for 2 weeks before it (6203) - both 60 inches.
Cheers!
t
tarapada is offline
post #16 of 16 Old 11-03-2014, 11:04 PM
Liked: 0
Yeah I seem to have come across the same issue on a Sony Bravia 700b (exclusive to best buy). Both lower corners exhibit some sort of "reverse flashlighting" the right being worse than the left (the left is barely perceptible). What would you do? Return and take a shot at another... or keep this one?
ID:	348730   Click image for larger version
ID:	348738   Click image for larger version
ID:	348746   Click image for larger version
vai777 is offline
Reply LCD Flat Panel Displays
