Will this tv work Samsung UN46ES6500 portrait (Vertical) - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 11-07-2012, 11:54 PM - Thread Starter
hevnbnd's Avatar
Looking for a cheap LED tv to turn vertically. Anyone know if I should have any issues with this tv? Thanks in advance.
hevnbnd is offline
post #2 of 3 Old 11-08-2012, 12:48 PM
walford's Avatar
Do I understand correctly that you are looking for a TV that instead of mounting as a 16:9 aspect ratio can be mounted as a 9:16 display and which would scale the 16:9 aspect ratio video images to distorted 9:16 images in the same way a reader tablet can process TXT without distortion by changing the number of characters of text per line.
I have never read about such a TV.
walford is offline
post #3 of 3 Old 11-13-2012, 05:12 PM - Thread Starter
hevnbnd's Avatar
I am going to take images from a usb drive and rotate them and just use the tv to play a slide show.
hevnbnd is offline
Reply LCD Flat Panel Displays
Samsung Un46es6500 46 Inch 1080p 120 Hz 3d Slim Led Hdtv Black
