List of HDTV's with 120Hz native refresh ability (forcing 1080p@120Hz via DVI or HDMI from computer) - Page 2 - AVS Forum | Home Theater Discussions And Reviews
post #31 of 41 Old 11-09-2013, 09:49 PM
Logun's Avatar
ok so I moved my PC down to my TV room today and tried to see what I could make happen.
My TV is a Panasonic 65ST50 - this is done over a high speed HDMI cable.
at 1920x1080 I bumped up the refresh rate to 62Hz. That's it. Anything more was not accepted.
At 1280x720 I thought I had more success. I did get what I thought was 120Hz, and it was verified by the tool over on HardForums
http://hardforum.com/showthread.php?t=1423433
However when I loaded into a game even though it was showing 120FPS with VSync enabled there was still some skipping or stutter.
I believe that I was in 3D mode only while on my desktop and the tv forced it to 2D when a game loaded.
I attempted 2 methods of OC'ing.
1) EVGA Precision
2) MonitorTests patching the driver and then creating a Custom resolution.
Logun is offline
post #32 of 41 Old 11-12-2013, 07:05 PM - Thread Starter
Mark Rejhon's Avatar
Quoted: 14 Post(s)
Liked: 109
Certain games have poor fluidity.
Which games did you try? Did you try several different games?
Also, a newer/easier frame skipping tool: www.testufo.com/frameskipping
Mark Rejhon
www.BlurBusters.com - Everything Better Than 60Hz(tm)
Mark Rejhon is offline
post #33 of 41 Old 11-12-2013, 08:10 PM
Logun's Avatar
I tried Borderlands 1 and 2 and both were the same - not an experience anyone would enjoy.
I'll give it another go and test with that tool, but something must have been amiss as even the resolution of 1280x720 didn't quite fit the screen properly.
Logun is offline
post #34 of 41 Old 06-25-2014, 03:55 PM
TripKidd's Avatar
Thumbs up
E601i-A3 - Perfect 120hz at 1920x1080 via HDMI. 4:4:4 chroma also.
I've been in love with this TV since day 1.. great value for the money, now its going to be even harder to upgrade because I'm going to have to find a larger true 120hz display down the road.
I verified no frames are dropped with the tools at blurbusters.com, but its instantly apparant. The mouse glides smoothly across the screen, and in games everything is so much crisper and clear when moving. It has really upped my abilities in first person shooters as there is no perceptable ghosting or input lag. Racing games are great too.
For years I've missed CRT, no more!
TripKidd is offline
post #35 of 41 Old 06-26-2014, 07:27 AM
tgm1024's Avatar
Location: Sorry, chances are excellent that you're an idiot.
Quoted: 2484 Post(s)
Liked: 2264
This surprises me. I had thought that the earlier E series were frame dropping; is this something that was fixed with the A3?
You're the wife. You're the dead wife. Give me my @#$%ing coin, dead wife.
-Mad Sweeney
tgm1024 is offline
post #36 of 41 Old 06-28-2014, 08:34 AM
TripKidd's Avatar
I've got no idea about the E series, but I can 100% confirm this TV is not dropping frames. I was able to get it working both with my NVidia GTX 570 and with a little more work, my AMD R9 290.
I tested with this website http://www.testufo.com/#test=frameskipping and a camera capable of taking 120FPS video and it came out perfect, although as I said its immediately apparent.
TripKidd is offline
post #37 of 41 Old 06-28-2014, 08:56 AM
tgm1024's Avatar
Liked: 2264
"Immediately apparent" is something that I disregard from folks right away, because I've heard that before even on TVs that were frame dropping like crazy. It's too hard to turn off the part of you looking for improvement.
However, I don't doubt your finding, I'm just interested in when precisely Vizio-E's started working with this. When you used your 120 Hz video, did you step through each frame carefully afterward? Mark actually suggests using a standard camera set at a large (1/5th second) exposure for that particular test.
-Mad Sweeney
tgm1024 is offline
post #38 of 41 Old 06-28-2014, 09:37 AM
TripKidd's Avatar
I just uploaded the video to youtube. Be aware that the 120FPS recording on my phone (galaxy S5) is not synced to the refresh rate of the TV of course, so that causes some off effects, and the stuttering visible in the youtube reincoded version of the video doesn't happen when I play it back directly on my phone. Besides that, you can see that no squares are skipped.
Edit: Here, this shows it well -
TripKidd is offline
post #39 of 41 Old 06-28-2014, 02:02 PM
TripKidd's Avatar
For anyone else who wants to set this up, this is pretty much what I did here: http://www.blurbusters.com/overclock/120hz-pc-to-tv/ using the AMD driver patcher to allow higher refresh rates from here http://120hz.net/showthread.php?270-...-refresh-rates
I was able to create refreshrates above 120hz, I tried 125, 133, and 140, and even though the "Info" menu in the TV settings showed that it was at the higher rates, frames dropped and any on screen motion was jerky, so it looks like 120 is the maximum actual refresh rate.
TripKidd is offline
post #40 of 41 Old 03-31-2016, 03:21 PM
Imaginos's Avatar
Sorry for bumping an old thread like this, but is this possible to do on a TC-P55ST60? I tried making a custom resolution using ToastyX's tool along with Nvidia's as well. Unfortunately, all I get is a black screen on anything above 60hz. Any help at all in regards to this dilemma of mine would be much appreciated.
I've had this particular plasma for years now and I was never really concerned about whether or not it could display at 120hz. However, recently, I've started using it as a gaming monitor and I've been wondering if it's possible with my current display. My display adapter is an EVGA GTX 970 OC'd connected to a Denon 1713 AVR via a "RedMere" HDMI cable. The television itself is also connected to the receiver with a "RedMere" HDMI cable. I have zero experience with 120hz, and am eager to see how it would improve my gaming experience (assuming it's possible, of course). As an aside, I've seen that 120hz has a much higher success rate at lower resolutions, but I'm not prepared to sacrifice 1080p for hertz. Just thought I'd make that clear in case that's the only way this can be done.
Imaginos is offline
post #41 of 41 Old 11-11-2016, 08:56 PM
rakers8's Avatar
Cool
Originally Posted by Mark Rejhon View Post
Quote:Originally Posted by sadbuttrue
Successful: Panasonic 50ST30 plasma
Resolution: 1280×720 @ 120hz.
Source: HardForum post (by sadbuttrue)
The OSD reports 60hz and 3D mode detected. Colours are slightly different but there is no 3D being applied. I have verified that it does show 120 unique frames. So, when you try outputting 120hz to your TV don’t assume the OSD is giving an accurate report. It may say 60hz yet actually be showing 120hz.
Just wanted to login here and say thanks for this thread - found on google. Happy to report the Panasonic ST50 ( TCP50ST50 ) allows for 120Hz @ 720p. I'm not sure if it's just my settings but after switching to the custom resolution in the Nvidia Control Panel, I hit must hit "3D" on my remote and everything works great. NOTE: You'll know it's working when hitting the 3D button and it doesn't say "2D -> 3D" conversion, just "3D". It's also quite obvious with the mouse cursor but I tested it with BB UFO, etc. Pretty nice playing Rocket League with Fast Sync enabled. Frametimes around 3 or 4
Edit: To the poster above try this in NCP:
Last edited by rakers8; 11-11-2016 at 09:01 PM. Reason: Added image for guy above ^^
rakers8 is offline
Reply LCD Flat Panel Displays
Vizio E3d420vx 42 Passive 3d Lcd Hdtv , Panasonic Viera Tc P55vt50
