LG LED Screen has slight bend ..is this normal ??? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 11-08-2012, 07:39 PM - Thread Starter
bearzfan1963's Avatar
I have an LG LED tv and I noticed that when i look at the tv from the side a few feet back the tv appears to have a slight bend to its shape- it does not look straight. I placed a level on the screen and frame and they are slightly off center.
When I had an LG tech come and look at this problem he said this was normal with all flat panel tvs, that all led panels have a slight bend that make them look concave etc. He said as long as it doesnt affect the tv viewing expeience its not something LG would fix.
Is LG lying ?? Or is this a defective tv?
bearzfan1963 is offline
post #2 of 2 Old 11-08-2012, 11:39 PM
Do-It-Yourself's Avatar
Location: In a house far away from you creeps (hopefully)
Liked: 24
Televisions are not concave whatsoever. Would you like to tell us what model you have? Thanks
Do-It-Yourself is offline
Reply LCD Flat Panel Displays
