Help me decide - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 11-09-2012, 03:06 PM - Thread Starter
matteos's Avatar
http://www.amazon.com/gp/product/B006VFS4J2/ref=ox_sc_act_title_1?ie=UTF8&smid=ATVPDKIKX0DER
60" LG Plasma or 55" LED
http://www.bestbuy.com/site/LG+-+55%26%2334;+Class+-+LED+-+1080p+-+120Hz+-+HDTV/6735568.p?id=1218789792782&skuId=6735568
I know there are better TVs for more money but my budget is already stretched as far as it can go.
The 60 inch is bigger and cheaper, but it is heavy and I can't mount it to a TV stand, I can mount the 55" one (Can't wall mount either) Mounting would be nice as I have a lot of AV components and would help placement for center channel. I also game and use a HTPC (no cable TV though) so burn in may be an issue, most movie and tv watching is done on netflix. But it is bigger and the picture quality is probably better.
viewing the TV from 8-13 feet away. Sound quality is a non issue as I have a sound setup.
So the plasma would be nicer for size, budget and image quality but much less convenient than an LED
matteos is offline
post #2 of 2 Old 11-09-2012, 03:10 PM - Thread Starter
matteos's Avatar
also some LGs are IPS panels, I like IPS panels... is that a lottery? is this one an IPS? (the LED)
matteos is offline
Reply LCD Flat Panel Displays
