Official LG XXLM7200 Thread - Page 25 - AVS Forum | Home Theater Discussions And Reviews
post #721 of 749 Old 12-20-2013, 10:21 AM
chicagozookeep's Avatar
Do the pixels go all the way to the bezel, or is there a black border around the image on the LG 60LM7200?
I have a 55LM8600 whose pixels stop 1/2" from the bezel, and a 55LM9600 whose pixels go right to the bezel.  I am making an array of these monitors, and need to minimize the black in between the images.
Thanks for any information or images you can offer.
chicagozookeep is offline
post #722 of 749 Old 12-21-2013, 03:40 PM
Zap Branigan's Avatar
They go to the edge of the bezel.
Zap Branigan is offline
post #723 of 749 Old 12-22-2013, 08:48 AM
Thank you, Zap Branigan!
post #724 of 749 Old 12-23-2013, 08:27 AM
lamplighter's Avatar
Will only a LG webcam work with this TV?
lamplighter is offline
post #725 of 749 Old 12-23-2013, 02:33 PM
caloyzki's Avatar
Quoted: 168 Post(s)
Liked: 46
Yes
caloyzki is offline
post #726 of 749 Old 01-10-2014, 06:37 PM
King J Gregory's Avatar
So it seems that ever since the Jan 7th 2014 firmware update my TV keeps flashing brighter and darker. Backlight problem maybe? I tried messing with backlight settings and local dimming and that doesn't help at all. Am I alone here?
Living Room:
LG 60" Lm7200
Onkyo TX-NR616
Klipsch KF-30 floor
Klipsch C-20 center channel
Klipsch QUINTETIV surround
Xbox 360
Xbox One
PS3
PS4
WiiU
HP Pavilion dv7 with IR
King J Gregory is offline
post #727 of 749 Old 01-10-2014, 07:47 PM
I haven't had any issues.
post #728 of 749 Old 01-10-2014, 10:01 PM
Well, I turned the power off and unplugged the TV for a minute and the problem seems to have gone away for the time being. It had been intermittent since the update, so it my return. Hopefully, though, it will stay gone.
Living Room:
LG 60" Lm7200
Onkyo TX-NR616
Klipsch KF-30 floor
Xbox 360
Xbox One
PS3
PS4
WiiU
post #729 of 749 Old 01-11-2014, 04:55 AM
What was in the update..what version are you using?
post #730 of 749 Old 01-11-2014, 09:20 AM
06.01.03 is the version I am using. I just downloaded it this week and that's when the problem started. Since I unplugged it though, I haven't seen the issue return. I have no idea what the update was for. I tried adjusting a bunch of different settings to fix it at first. Just unplugging it should have been the first thin I tried. I do not have any power saving settings on or the ambient light sensor on so it seemed really strange that it kept dimming and getting brighter. It wasn't a gradual dimming either. It was quite jarring an obnoxious. So far so good though. We have a movie night tonight, so if the problem returns I will update.
Living Room:
LG 60" Lm7200
Onkyo TX-NR616
Klipsch KF-30 floor
Xbox 360
Xbox One
PS3
PS4
WiiU
post #731 of 749 Old 01-11-2014, 09:40 AM
Ive been using that one for awhile..I suppose it didnt completley install untill after you turned the set off and then back on..you should be ok now.
post #732 of 749 Old 05-02-2014, 04:15 PM
alvindd's Avatar
Quoted: 23 Post(s)
I have some questions about some items I saw in the ..Service Menu.
#5. Tool Option6
STD Backlight =85
So can I turn this down to get rid of some of the white corners I have?
In the standard menu my Backlight is 41.
#6. Tool Option7
EDID Type = PCM
options are DTS and AC3
What's this for?
#13. SUB B/C
Sub Brightness =128
Sub Contrast =128
I would like to turn that Brightness down, eliminating white corners.
#5. and #13. could really get my picture dark how I like it.
thanks for any input.
alvindd is offline
post #733 of 749 Old 06-24-2014, 12:39 AM
Leonheart's Avatar
Quoted: 86 Post(s)
Liked: 25
Originally Posted by PerfectCr View Post
Quote:Originally Posted by Leonheart
Hi Perfect Cr, which are your game settings?
Same as what I listed above. I only use Input HDMI 1 because everything feeds though my Denon AVR-1712. I typically try and find a happy medium for all content because I really don't like messing with once I've found something that works.
I think for gaming the color temp has to be medium though
Leonheart is offline
post #734 of 749 Old 07-24-2014, 03:17 PM
syphon00's Avatar
my 60lm7200 just updated to 06.04.07 today, anyone know what this update does?
thanks
syphon00 is offline
post #735 of 749 Old 08-07-2014, 07:30 AM
psxp's Avatar
Wow.. like no one is keen on this TV anymore? Not many posts in ages.
psxp is offline
post #736 of 749 Old 11-21-2014, 06:25 PM
psxp's Avatar
Just got firmware 06.05.02 today..
anyone still reading this?...
psxp is offline
post #737 of 749 Old 11-21-2014, 07:56 PM
Liked: 0
Question
Hey guys,
60LM7200 owner here, been experiencing kind of an odd horizontal colored static appearing on my screen sometimes. It's usually subtle but sometimes it's quite severe and in the worst case the entire picture's colors go completely screwey (rainbowed almost). T
he unit's not always been this way of course, but I'm curious if anyone's seen this happen. Possibly an issue with the HDMI cable? It's hooked up to the HDMI output of a Yamaha RX-V373 receiver.
Thanks in advance!
Winterblink is offline
post #738 of 749 Old 12-23-2014, 05:25 PM
raynist's Avatar
Quoted: 1574 Post(s)
Liked: 1550
Has anyone had an issue with their TV since the last upgrade a week or so ago?
I am now seeing what looks like frame rate issues and sometimes screen tearing at the bottom third of the screen. Seems to have happened with the most recent update.
Is there a way to revert to old firmware? I plugged another tv into the signal to verify it was indeed the tv and not the dish network receiver or my AVR.
Ray Nist
JTR (3 215 RT, 5 212HTR, 2 Growlers, 4 S2's)
PSA (4 Triax's, 3 210T's)
Behringer (4 B1200 Midbass Modules)
raynist is offline
post #739 of 749 Old 01-24-2015, 04:28 AM
BigHAZE's Avatar
YES! I thought I was going crazy. This newest firmware update BROKE the ability to stream movies from my PLEX server in the basement. They are now jerky with audio dropout. I also see they have added advertisements to the home screen. I am desperately trying to roll back the firmware...have been scouring the internet to find the version before 06.05.03. This better be addressed quickly by LG, as we use this in our home theater room, and I store all movies on a HTPC running pleX media server. They SHOULD have just released a firmware that turned this crappy LG interface into a Google TV. I own a 55" Google LG TV and a 40" Google LG TV and they both work better.
If anyone has info email me please @ blister2pac@yahoo.com
*edit* I found this page http://drivers.softpedia.com/dyn-sea...0+TV+Firmware+ and plan to downgrade to 06.01.03.
YMMV
BigHAZE is offline
post #740 of 749 Old 04-10-2015, 10:48 AM
neocvera's Avatar
I guess that answers my question about the latest firmware. Sad to see thus thread die though. I still have this set and it's working fine.
neocvera is offline
post #741 of 749 Old 04-10-2015, 08:00 PM
Quoted: 67 Post(s)
Liked: 1
Is this set has screen mirroring features?
tapsilog is offline
post #742 of 749 Old 05-28-2015, 04:05 PM
Metalcrack's Avatar
Anyone else having an issue controlling the volume? The audio is not distorted, but no matter how we try and adjust the volume.....2 different remotes or the volume buttons on the side, the volume will not change. The red LED blinks acknowleding the signal is being recieved for the remote, but no changes......
Occasionally it will go up the level, and then we have to hold down the button for another 10 seconds or so for another tick.
I will have to check with BB if we got the extended warranty, but I think it's run out.
Metalcrack is offline
post #743 of 749 Old 07-25-2015, 01:23 PM
Metalcrack's Avatar
Ended up being the main PCB. Was starting to shut off and turn on by itself too. Replaced with an Ebay part and all is well.
post #744 of 749 Old 07-29-2015, 11:08 AM
AniMisM's Avatar
Originally Posted by Winterblink View Post
Hey guys,
Thanks in advance!
Hmmm, yes. I have noticed this, usually just a quick blip for a second at the top of the screen. I thought this was maybe a Plex transcode problem, but now I'm thinking it's the TV. I have noticed stuttery playback as well since the last update. Time to roll back!
AniMisM is offline
post #745 of 749 Old 07-29-2015, 11:32 PM
AniMisM's Avatar
It doesn't seem to be possible to roll back the firmware. Is there something I'm missing?
AniMisM is offline
post #746 of 749 Old 07-29-2015, 11:32 PM
AniMisM's Avatar
Now what?
AniMisM is offline
post #747 of 749 Old 08-11-2015, 07:40 AM
Metalcrack's Avatar
Still happening. I ended up getting all the boards in a package deal and after a few days the volume is still non responsive. Replaced all but the display driver board (hooks up to the LCD panel). Even replaced the remote sensor and button PCB for the power button. As long as the display doesn't shut off on its own I will prolly get a sound bar. Hate to clutter up the TV stand, but I just paid this off in January, and don't want to replace it already. Too good a picture.
Sent from my DROID RAZR using Tapatalk
post #748 of 749 Old 07-06-2016, 07:18 AM
Anyone else having this issue? Whenever I hit the menu button on the remote to change inputs, I have to agree to the TOS two times before it lets me do anything. It does this every time I power the TV on and hit the button. It's OK if I leave it on though. It's a PITA.
post #749 of 749 Old 12-11-2016, 05:19 AM
Metalcrack's Avatar
New update posted today.....06.05.07. Any idea on what this fixes/changes? My guess is a TOS changed for an app, and had to update it....but I see no info anywhere.
EDIT:
Found under another model... I was close
Detailed applicable model list : Please check with reference Tab exactly
* SW information
1. Improvement
1) Disable the skype due to spec out.
2. Applicable model list
47LM7600-UA
55LM7600-UA
42LM6700-UA
47LM6700-UA
55LM6700-UA
32LM6200-UE
42LM6200-UE
47LM6200-UE
55LM6200-UE
65LM6200-UB
32LS5700-UA
42LS5700-UA
47LS5700-UA
55LS5700-UA
60LS5700-UA
60LS5750-UB
47LS579C-UA
55LS579C-UA
60LS579C-UA
3. Release History
[06.00.11]
1. Security enhanced in Smart TV
[06.01.03]
1. Security enhanced in Smart TV. (2nd Bug Patch SU)
[06.05.03]
1. There are some error such as infinite loading, lock-up when access to some web-site. These are caused by
security fragility(POODLE attack) protection and are improved by Using TLS1.2 instead of SSLv3 in
Web Browser and Gstreame
[06.05.07]
1. Disable the skype due to spec out.
Reply LCD Flat Panel Displays
Samsung Un60es6500 60 Inch 3d Slim Led Hdtv , Led Hdtv
