I need a 37-42" local dimming LCD. What are my choices? - AVS Forum | Home Theater Discussions And Reviews
Old 11-12-2012, 02:23 PM - Thread Starter
PathofNeo's Avatar
Quoted: 67 Post(s)
Liked: 26
I asked before but I don't think I worded my question correctly. I'm looking to build a virtual pinball machine and need either a 37-42" LCD. But I'm not attracted to edge lit LCDs because if I'm going to be standing directly over it I don't want to see ghosting, bleeding, clouding, etc the usual problems with LCD. So is there a 37-42" on the market now with local dimming?
I hear great things about Vizio and Sony. I'm not set on any particular brand.. just need maximum bang for my buck and something to give me a near 3D image (for pinball tables). I decided to not go with a plasma such as the 42UT50 due to heat and dithering up close. I think LCD will give me the razor sharp picture I'm after so all I need is suggestions to what I can buy right now.
PathofNeo is offline
Old 11-12-2012, 02:30 PM - Thread Starter
PathofNeo's Avatar
Quoted: 67 Post(s)
Liked: 26
If the Sony only has a minimum of 46" local dimming model that I can stretch for that size. The absolute largest size I can fit in the cabinet is 47". I'd prefer 37-42" but if the picture is going to be out of the world then I'll take a larger but 47" is the limit and it has to be worth it.
Old 11-12-2012, 02:37 PM
fatuglyguy's Avatar
Quoted: 285 Post(s)
Liked: 617
Nothing with LD available in the 37-42" range.
Try the Sony 46HX929 (discontinued recently) - LED-backlit with LD. - about 43" wide
or the Sony 46HX850 - edg-lit with LD.
or you can go all out....
http://www.dolby.com/us/en/professional/hardware/video-monitors/prm-4200-professional-reference-monitor.html
This LG is backlit with local dimming, but it would appear that the 47" size might already be discontinued or unavailable...41.5" wide
http://www.lg.com/us/tvs/lg-47LM9600-led-tv
desktop Sonus faber Toy monitor| REL T Zero| Sony UDA1|Sony MDR-Z7|Sony MDR-1000X|Audioquest NightHawk|Audioquest DragonFly Red
surround Monitor Audio Silver RX6, RX Centre, RX1|SVS SB-2000|Sony STR-ZA5000ES|Panasonic 60ZT60|Oppo 103D|Sonos Connect + Peachtree Audio DAC•iT
stereo Sonus faber Toy tower|REL S/5|Teac UD-501|Sony TA-A1ES|Sony SCD-777ES|Sony ST-SA50ES|Sony BDP-S1700ES|Sonos Connect|Furman Elite-15 PFi|Sony 43X800D
fatuglyguy is offline
Old 11-12-2012, 10:10 PM - Thread Starter
PathofNeo's Avatar
Quoted: 67 Post(s)
Liked: 26
I thought Vizio has (or had) some 42" XVT models with local dimming.. or is it "smart dimming" they call it? What's the difference and are they good performers? I'm leaning toward the 46HX929 but want to consider all options first.
Old 11-12-2012, 10:52 PM
EscapeVelocity's Avatar
Quoted: 531 Post(s)
Liked: 293
Well if you dont mind tracking down a used one from a couple of years ago..
Vizio XVT423SV
Vizio XVT3D424SV
Epson 8350 / Panasonic AX-200u / Optoma Graywolf 92" / Draper Luma 92"
Samsung 51F8500 / Panasonic P50ST60 / Vizio P502ui-B1 / Sony 50W700B LCD
Sony S790 / Panasonic BDT-220 / Roku 2 XS & Roku 2
Samsung F550 / Speakercraft CS3 / Yamaha YAS-105
EscapeVelocity is offline
Old 11-13-2012, 08:00 AM - Thread Starter
PathofNeo's Avatar
Quoted: 67 Post(s)
Liked: 26
Old 11-13-2012, 09:06 AM
TerrenceQ's Avatar
you may also look into LG47LM6700 and Vizio M3D470KD. comparison here,
http://tv-compare.blogspot.com/2012/10/47lm6700-vs-m3d470kd.html
TerrenceQ is offline
