TCL 48" F3300 240Hz LED LCD HDTV - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 11-13-2012, 08:26 PM - Thread Starter
EscapeVelocity's Avatar
Quoted: 571 Post(s)
Liked: 316
I spied this at Sam's Club.
It looked to have a nice panel and good blacks.
No Smart TV functions and No WiFi.
Ultra thin bezel.
240Hz is questionable though. I think this might be a 60Hz set.
Remote is supposed to suck, cheap and the codes are spotty. (Though I read you can use RCA codes).
Might pick one up just to check out. $450 at Sam's.
Here is some information on it from Amazon.
Epson 8350 / Panasonic AX-200u / Optoma Graywolf 92" / Draper Luma 92"
Samsung 51F8500 / Panasonic P50ST60 / Vizio P502ui-B1E / Sony 50W700B
Sony S790 / Panasonic BDT-220 / Roku 2 XS & Roku 2
Sony NT5 / Samsung F550 / Speakercraft CS3 / Yamaha YAS-105
EscapeVelocity is offline
post #2 of 5 Old 11-14-2012, 07:23 PM - Thread Starter
Quoted: 571 Post(s)
Liked: 316
Does anybody own this set?
Aparently TCL is a big player in LCD TVs. A top 6 worldwide manufacturer.
post #3 of 5 Old 11-14-2012, 07:56 PM
ListedGuru's Avatar
I thought I read somewhere that these TCL tv's are direct light and not edge light. Does anyone know for sure. Also are their screens matte or shiny?
-Guru
ListedGuru is offline
post #4 of 5 Old 11-14-2012, 08:01 PM - Thread Starter
Quoted: 571 Post(s)
Liked: 316
-Guru
Next time Im in town, Ill swing by Sam's and inspect further.
The specs say it's 5" thick, which would indicate a Direct Lit LED screen.
post #5 of 5 Old 11-15-2012, 04:52 PM - Thread Starter
Quoted: 571 Post(s)
Liked: 316
So I checked this one out today at Sam's and the design of the back panel would seem to indicate a Full Array Direct Lit LED backlighting scheme.
I didnt like the off axis viewing, which seemed to dim rather quickly.
There is no Optical Digital Audio Out. It is a SPDIF Coax Digital Audio Out.
There is a 1/8th" Headphone out jack.
There is no Audio Input associated with the VGA Input.
There are separate Component and Composite inputs but they share the same RCA Analog Audio Stereo Inputs.
Hope that helps.
Ill pass on this set and do not plan on recommending it. Too many odd things about it.
Reply LCD Flat Panel Displays
