1080p HD from cable box to monitor with max resolution of 1600x900. What happens? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 11-20-2012, 10:19 AM - Thread Starter
qwerty11's Avatar
What happens to the resolution when I connect an hdmi cable box putting out 1080p HD to a monitor which handles up to 1600x900? Does the monitor scale down to native resolution or what?
qwerty11 is offline
post #2 of 3 Old 11-20-2012, 10:49 AM
sitlet's Avatar
The monitor SHOULD scale it down to it's native resolution. However, this depends on the model/brand. Some lower end monitors will lack scaling that an actual "tv set" will have.
sitlet is offline
post #3 of 3 Old 11-20-2012, 10:50 AM - Thread Starter
qwerty11's Avatar
Anybody know if a dell s2009wb does it?
Will it mess up the picture quality with the scaling?
qwerty11 is offline
Reply LCD Flat Panel Displays
