46" LCD for a computer monitor - AVS Forum | Home Theater Discussions And Reviews
post #1 of 9 Old 11-20-2012, 03:52 PM - Thread Starter
marklari's Avatar
Hi everyone.
I need a quick help cos I need to decide tomorrow what to get.
I went thrue a real nightmare with buying/returning 2xPhilips LCDs to the shop. 1st one had a dead pixel (40pfl5507) and the 2nd one (46pfil5007) had really bad bleeding and after 2 days of using stopped working properly connected to my computer. the computer recognized it as generic and max resolution was 1024x768. I suppose the software got bug-ed. I tried connecting to other computers/different HDMI ports/cables/reseting to factory settings,... and same results so I returned that one also and I don't want to hear about Philips ever again in my life mad.gif.
Anyway I need your advice cos I don't know what to pick at this stage. The only thing that is important to me is good picture and no-problem(s)/bugs/... using it as a computer screen (movies, games, internet, work,...) at 1080p/60Hz.
I don't use 3d, smart Tv, usb play, wi-fi, effects,.......
As I see it's not really possible to get a good quality screen without all these options that IMHO are only problem for me cos to much options could meen many bugs (the philips TVs that I tried had really slow menu/software).
I'm thinking of going Sammy 46es6710 or 46es6100 if you confirm that I don't really need local dimming as some sites claim. AFAIK this is the only main difference between these 2 that could affect me using the TV as a computer monitor?
Currently I'm on Sammy 40" a656 that's been great and still working great to this date after years of using. never any problems/bugs/blocking or whatever.
Is it really hard to get this kind of a TV in these days when they "stick" all kind of unnecessary options (to me) inside the TV?
Are there any models maybe that have the same quality of picture as series 6 but without all these options so the price would be even less?
thanks.
marklari is offline
post #2 of 9 Old 11-20-2012, 04:36 PM
EscapeVelocity's Avatar
Quoted: 528 Post(s)
Liked: 290
The Toshiba 2200U series has been reported as good computer monitors.
Epson 8350 / Panasonic AX-200u / Optoma Graywolf 92" / Draper Luma 92"
Samsung 51F8500 / Panasonic P50ST60 / Vizio P502ui-B1 / Sony 50W700B LCD
Sony S790 / Panasonic BDT-220 / Roku 2 XS & Roku 2
Samsung F550 / Speakercraft CS3 / Yamaha YAS-105
EscapeVelocity is offline
post #3 of 9 Old 11-20-2012, 11:10 PM - Thread Starter
marklari's Avatar
hi. thanks for the reply.
I wasn't able to find this model around here so it seems it's not available in my area.
I would really prefer Samsung for my next TV cos I have good experience with them and along with philips, sony and panasonic they are the most available around here (Croatia).
I would just like a confirmation from someone using one of Sammy newest series 6 how it behaves connected to a PC.
thanks.
marklari is offline
post #4 of 9 Old 11-20-2012, 11:27 PM
Quoted: 528 Post(s)
Liked: 290
Cheaper no frills sets generally make better computer monitors. LG has had great computer monitor sets in the past. Check out 4:4:4 Chroma subsampling. Dirty whites connected to scrolling.
Good Luck.
post #5 of 9 Old 11-24-2012, 10:09 AM
TerrenceQ's Avatar
you may find side by side comparison of 40L2200U and UN46ES6100 here,
http://tv-compare.blogspot.com/2012/11/40l2200u-vs-un46es6100.html
TerrenceQ is offline
post #6 of 9 Old 12-01-2012, 03:10 AM - Thread Starter
marklari's Avatar
hi guys. I got myself a sammy 46es6710 and I'm really happy with it. I'm one of the lucky ones that don't have any visible bleeding/clouding etc. (at least for me).
I've made a calibration as best I could without pro equipment using disk 709. I never get above 16-235 flashing except when I played with ffdshow settings and forced it somehow but not sure if this is ok. I use ffdshow, hali media splitter and ac3filter (for SPDIF to my decoder). I've tryed using madVR but no luck, can't get subtitles to work, will have to investigate more).
I set my desktop using on standard mode (60Hz in OS), my games on entertain mode (60Hz; I don't like this one much cos it's to "burned out" somehow, but can't use standard cos I keep it very low on backlight to be "soft" for my eyes (4) and also this one (standard) looks a bit strange in games, like looking thrue a grey filter or fog).
for movies/video I switch on 23,976Hz (I get 24p on my TV) thrue Media Player Classic Home Cinema (EVR Sync) when I watch movies and that one look very good to me.
What I'm interested is which output (0-255 / 16-235) to set in the nvidia control panel (NCP further in the txt), and if even possible cos If I use HDMI it sets it self in YCbCr444 wich is if I understand 16-235 output, and if I connect thrue DVI I get RGB output (0-255). AFAIK this is a bug in NCP cos I can't change those for specific connection and can be changed thrue .inf changing or using some third party tool.
should I bee woried about this or should I just leave it at HDMI (YCbCr444)?
If I'm not mistaken data (games) from computer is made as RGB 0-255 and video (movies, etc) as YCbCr444 (16-235)?
P.S. Al this is still abit confusing to me, especialy outputs/ranges (0-255/16-235; RGB, YUV,.....) and I'm trying to connect the dots. I've read alot of guides already but some info's are still missing in the head :-).
My computer is i5 2500k/4,5GHz/8gb/GTX570/Win7 x64, so I think it should have more than enough juice for any possible demanding video processing.
thanks.
edit: forgot to mention, I've connected my PC to the TV using HDMI1 connector and I've set it in PC mode in TV's menu cos of awful mouse lag that I can't stand otherwise. The downside of this is that majority of settings in the menu is disabled for me :-(.
When I switch to 24p when watching movies I get this options back, so only for that mode I was able to setup color, tint/hue etc.
also, when watching movies in MPCH should I set it to switch to 23,976 or 24Hz? To me, 23,976 seems less judder.
marklari is offline
post #7 of 9 Old 12-02-2012, 12:29 PM
Katre's Avatar
Can you tell me all your settings that you have for the PC mode? I have the same tv, only smaller. Can't for the life of me get mine right.
Katre is offline
post #8 of 9 Old 12-02-2012, 04:23 PM - Thread Starter
marklari's Avatar
hi,
connected to HDMI1 (PC mode set):
dekstop usage settings (1080p, 60Hz):
brightness 4/5
95
44
40
white balance:
24
25
25
25
25
25
gamma 0
color tone: standard
entertain mode for games (1080p, 60Hz):
7/8
80
45
45
warm1
mode for movies (1080p, 24p):
6
95
44/45
5
48
g49 r51
black tone: darkest
color space: native
white balance:
25
25
25
25
25
20
gamma 0
xvYCC: off
warm1
motionplus: off
3d movie (24p):
15
96
45
35
48
g49 r51
color space: native
white balance:
25
25
25
25
25
20
gamma 0
xvYCC: off
warm1
motionplus: off or standard
let me know of your results mate.
cheers.
marklari is offline
post #9 of 9 Old 12-06-2012, 11:44 AM - Thread Starter
marklari's Avatar
mate, did you try my settings? results?
cheers.
marklari is offline
Reply LCD Flat Panel Displays
