trying to reprogram my tv - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 11-21-2012, 09:16 AM - Thread Starter
babyboy's Avatar
do you have to use the remote that the tv came with to rescan the channels trying to reset the channels i dont have cable anymore so trying to get regular channel.can i get a remote from target or walmart somewhere and will a universal remote work for scanning the channels
babyboy is offline
post #2 of 2 Old 11-21-2012, 01:27 PM
Otto Pylot's Avatar
Quoted: 1629 Post(s)
Liked: 1024
Can you buy the remote from the tv mfr? A universal remote would probably work if it has your tv listed in it's section of codes. That should give you pretty much the same functionality that the original remote has. Is there a manual set of buttons on the side/front of the tv that gives you Menu access?
Otto Pylot is online now
Reply LCD Flat Panel Displays
