Official Vizio M3D470KDE Owner's Thread - Page 5 - AVS Forum | Home Theater Discussions And Reviews
post #121 of 125 Old 07-14-2013, 11:45 AM
johncap523's Avatar
Just got one of these. Was looking for an inexpensive TV for the basement but after trying a BestBuy brand piece of crap, I decided to upgrade my family room TV to 3D instead and move my Panny plasma to the basement. But am finding some very annoying "features" on this TV. Hopefully it's just me.
First, the audio volume goes up and down with commercials, changing channels, etc, no consistency.
Second, there is a muting of audio every time I change channels, skip forward or backwards, and even on many scene changes, like from a commercial back to the show.
The other annoying thing is I can't find any code that allows my FiOS remote to do anything more than the the TV on and off. Would be happy to just have the input selection button work so I can switch inputs without having to grab the Vizio remote.
I'm connected to a sound bar using SP-DIF, and running FiOS connected via HDMI.
I'm going to call Vizio about this on Monday and if there's no solution, back it goes.
johncap523 is offline
post #122 of 125 Old 07-14-2013, 12:05 PM
indept's Avatar
Quoted: 86 Post(s)
Liked: 92
Didn't have those issues with the one I had. My Comcast remote controlled on / off and volume, sound worked fine. The reason I returned it was the terrible motion blur watching sports, everything else was great, picture quality was good & 3D was too. Also it was REALLY slow when changing channels even though the channel change was through the cable box, my preset TV in that spot, A Vizio M551D, changes very fast with the same cable box so it was the TV.
indept is offline
post #123 of 125 Old 10-27-2013, 01:57 PM
johnsonparts23's Avatar
Hello all. I'm new to the avs community and am looking for some help with my Vizio m3d470kde. There is something wrong with the picture/screen. The picture is choppy and has lines going horizontal mostly but also vertically, that are not consistent. The lines will go in and out at all different places and the picture will seem to cut at different spots. This happens on all inputs and when menu is up. Any help would be appreciated.
Here are a few images showing the issue, and it's inconsistency. http://imgur.com/a/3ezAA
johnsonparts23 is offline
post #124 of 125 Old 01-31-2016, 08:22 PM
ravencr's Avatar
Hey guys, I just opened the box to our m3d470kd after sitting in storage for 3 years. All the menus are in full color, but as soon as I start playing anything on the TV it's only playing in black and white. Any ideas?
Chris
ravencr is offline
post #125 of 125 Old Today, 04:43 PM
scottjoh's Avatar
I have the same problem with a M3D470MDE. Built in menus, help and even the built in Netflix menus are all in color. As soon as video starts playing it's in B&W. Overlay text like CC is in color, just the video is B&W and it's on all inputs, broadcast using built in tuner, all HDMI inputs, etc. There is a guy on eBay selling a replacement NAND Flash chip which he says fixes a number of problems including "LOST OF COLOR" I'm quoting from the auction description. Here is the whole description. I don't think the flash chip is bad. I suspect a ball issue with the main BGA chip. The color did return once since I noticed the problem.
SELLING PRE-PROGRAMED U405 BLANK CHIP PART # H27UAG8T2BTR
FOR REPAIR YOUR HARD TO FIND MAIN BOARD
PART # 756TXCCB02K028 Main Board for M3D470KDE
PROBLEM FIXED:
STUCK IN VIZIO LOGO
INTERMITTENTLY COME ON
LOST OF COLOR
TO VERIFY CHIP BAD : FREEZE THE CHIP TO SEE IF THE TV RE-ACT DIFFERENTLY.
I'm going to try replacing the main board, but, I would love to know if the Vizio has a special service menu like what I saw with the Samsung where you press Mute-1-8-2-Pwr starting with the TV off. In the Samsung service mode video I saw there was a way to select the panel connected and when the wrong panel was selected the colors were very weird.
scottjoh is online now
Reply LCD Flat Panel Displays
Vizio , Vizio M3d470kd 47 Inch 240 Hz Class Theater 3d Edge Lit Razor Led Lcd Hdtv With Vizio Internet Apps
