what's the difference between 2d, full 2d & full 3d? - AVS Forum | Home Theater Discussions And Reviews
Old 11-22-2012, 06:28 PM - Thread Starter
Stealth3si's Avatar
Quoted: 32 Post(s)
I was comparing the "HD" features of the Samsung TV models on one of the amazon product pages section called "Samsung LED TV Comparison Chart".
for example, scroll down about halfway: http://www.amazon.com/Samsung-UN46EH6070-46-Inch-Blu-ray-Player/dp/B0083KGX1Y/ref=sr_1_1?ie=UTF8&qid=1353633873&sr=8-1&keywords=samsung+un46eh6070
most of the models say "Full 2D & 3D", about several of them simply say "Full 2D" and a couple of them just say "2D."
Should I take this into factoring when considering/comparing buying Samsung TVs?
What's the real differences between those terms regarding the "HD" performance/feature?
5.1 small-room size: 800 ft³+ 54 ft³ corner door space
AVR: Denon 1712
Fronts: Pioneer SP-BS41-LR /Center: Pioneer SP-C21 / Rear: Pioneer SP-BS21-LR
Subwoofer: SVS PC12-NSD
Screen: Samsung UN46EH6070 46" 1080p 3D LED 240 CMR TV
Viewing distance: 7.33 ft
Stealth3si is offline
Old 11-24-2012, 05:17 PM
sherisdoppel's Avatar
Although it's not a standard term, Full 2D in this case means "Full HD".
1080p is considered as a true, full HD (1920x1080). Looking at these models I can tell that just normal "2D" TVs are 720p (1280x720).
And yes you can spot a visual difference since the resolution is doubled. The difference becomes clearer as a size of a monitor becomes larger.
sherisdoppel is offline
