Vizio E701i-A3 Owners Thread - Page 90 - AVS Forum
post #2671 of 2686 Old 12-05-2014, 03:04 PM
primetimeguy's Avatar
Quoted: 202 Post(s)
Liked: 158
Originally Posted by seneschal View Post
Just got my fifth replacement TV from Vizio, an E700i-B3. Everything looks good so far, but...
They got cheap with the B3! No longer an RGB (computer)/audio input!
I used to hook it up to my laptop to watch movies from it...
Any suggestions on how to get this to work right?
Does anyone know if the VGA to HDMI cables work?
Also the new remote has no keypad, but the Manna guy was nice and let me keep the old remote.
Does your laptop have Display Port so you could use DP to HDMI cable?
primetimeguy is online now
post #2672 of 2686 Old 12-05-2014, 03:33 PM
seneschal's Avatar
Quoted: 26 Post(s)
Nope, unfortunately it's an older Dell, only has a RGB output.
Do you think one of these will work?
http://www.ebay.com/itm/1080P-Audio-...item1c475b735c
seneschal is offline
post #2673 of 2686 Old 12-05-2014, 04:01 PM
Quoted: 202 Post(s)
Liked: 158
It would appear something like that would work. I don't have any experience with any brands of those to say.
seneschal likes this.
post #2674 of 2686 Old 12-06-2014, 12:58 AM
jjthenovice's Avatar
TV Just got another update
Turned my E701i-A3 with Q serial # on today it says it has updated the firmware to V1.60.10-004.0090. Anyone know what issues this addresses?
jjthenovice is offline
post #2675 of 2686 Old 12-07-2014, 07:53 AM
kpiskin's Avatar
My current version is still v1.34.44.0090,. Seems like a pretty big update, number wise.
kpiskin is offline
post #2676 of 2686 Old 12-07-2014, 10:56 AM
There are two different Firmware's. Does your TV have a Q in its serial #, if not then you wont get this update version.
post #2677 of 2686 Old 12-07-2014, 11:13 AM
kpiskin's Avatar
Yes I also have a Q version.
kpiskin is offline
post #2678 of 2686 Old 12-09-2014, 11:45 AM
seneschal's Avatar
Quoted: 26 Post(s)
Got the unit yesterday (all the way from the other coast, only took one day, not bad for $17!).
It works like a charm! At 1080p there were some artifacts but looks good at 720p.
Good solution for anyone who needs an interface to the old 9-pin RGB plugs.
post #2679 of 2686 Old 12-09-2014, 09:46 PM
Squeeken's Avatar
I also kept my keyboard remote from the E701i-A3, but the keyboard portion does not work on my new E700i-B3. Has anyone else been able to get the keyboard to work with the new set?
Squeeken is offline
post #2680 of 2686 Old 12-10-2014, 11:27 AM
seneschal's Avatar
Quoted: 26 Post(s)
The keyboard works for me on most screens. I noticed some of the Yahoo apps don't like it though and get currency symbols instead. I guess it's still better to have it than not.
post #2681 of 2686 Old 12-11-2014, 08:19 AM
Movie78's Avatar
Quoted: 87 Post(s)
Does any have a calibration setting for this New model.
Movie78 is online now
post #2682 of 2686 Old 12-11-2014, 05:31 PM
raven69david's Avatar
So it seems the TV went 11 months without the cluster of white dots that appear on the screen. Now I've contacted Vizio and they are sending me a replacement with a "Re-certified" (not refurbished) TV. The model is e701i-a3b and they stated that it does not have a VGA port and that it's the only difference from my tv e701i-a31.
raven69david is offline
post #2683 of 2686 Old 12-12-2014, 11:39 AM
FUCCO's Avatar
I went through 3 of the units because of the white dots appearing on the lower left of the screen. Vizio stated a lot of them were sent back because of this issue. They sent me the a NEW B series model that just came out in July.
FUCCO is online now
post #2684 of 2686 Old 12-14-2014, 08:43 AM
xnappo's Avatar
Quoted: 21 Post(s)
Liked: 50
They are calling me back Tuesday to setup delivery of my 2nd replacement. They say it will be new - I hope there are no "As' left!
Have to say, I am impressed they didn't give me a hard time at all about replacing the set again even though I am four months out of warranty if counting from the original set.
Almost balances out them acting like every single 'A' set doesn't have this issue, and mine is the first they have ever heard of
xnappo
xnappo is offline
post #2685 of 2686 Old Today, 02:15 PM
Liked: 0
b3
Same issue with white spots here. I was well out of warranty and they were pretty easy going about the issue on the phone although they did ask me to show a receipt which I told them I don't keep receipts for 2 years. I really hope everyone keeps up with any issues on this forum with the new B3 model. They are sending me one and I haven't heard of any white spots showing up on it.
xxlive9xx is offline
post #2686 of 2686 Unread Today, 06:24 PM
Liked: 0
I actually have the E601i-A3 model but this is one of the only references on the internet to this update. I'm not sure about the "improvements" but ever since mine updated about a week ago, I have had to do a factory reset every single day to get the wireless to connect. I already had to do this once a month or so to get Netflix working again, but this is just ridiculous.
homerow is online now
Reply LCD Flat Panel Displays
Vizio , Lcd Hdtv , Vizio E550va 55 Inch Lcd Hdtv , Vizio E701i A3 Led Hdtv
Gear in this thread - E701i by PriceGrabber.com
