Is my HDTV dying? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 8 Old 11-24-2012, 03:21 PM - Thread Starter
TenTonBass's Avatar
Quoted: 27 Post(s)
I have a 47" Philips that is approaching 3 years old. It has gotten significant use over these years.
I've always though my picture looked rather well on my blu rays and HD cable content.
Just out of curiosity I decided to run a "INHD" video calibration setup and see how it went.
To my interest after setting the brightness to the point of seeing the 4th shaded circle I proceeded to the contrast setup
The contrast setup consists of 11 different shaded rings ranging from light to dark. The test recommends to set contrast to the point of where the 11th ring becomes visible.
Even at 100% contrast the 10th ring is barely visible and the 11th ring is non existent.
Is it advisable to run contrast at 100% or should I just lower contrast and increase brightness?
Thanks for any help guys!
TenTonBass is offline
post #2 of 8 Old 11-24-2012, 05:57 PM - Thread Starter
TenTonBass's Avatar
Quoted: 27 Post(s)
damn, no opinion on this guys?
post #3 of 8 Old 11-24-2012, 07:39 PM
sitlet's Avatar
Perhaps if you waited more than 2 and a half hours, people would respond.
sitlet is offline
post #4 of 8 Old 11-24-2012, 07:48 PM - Thread Starter
TenTonBass's Avatar
Quoted: 27 Post(s)
Lol. Yeah I'm a little tipsy right now and got kinda antsy.
post #5 of 8 Old 11-24-2012, 07:50 PM
Midwest User1's Avatar
It's also possible that your set just doesn't have the best "gray" scale to calibrate to. Some sets have a better gray scale than others and one with a lesser gray scale would give what you describe with the contrast setup. I'd just chalk it up to your particular sets design.
Midwest User1 is offline
post #6 of 8 Old 11-24-2012, 07:56 PM
EscapeVelocity's Avatar
Quoted: 573 Post(s)
Liked: 316
Where is the Brightness (Black Level) setting? Reduce that. And then start again.
Please be advised that some manufactuerer's Advanced Settings stuff takes control of the Backlight Level, disregarding where you set it. Like Dynamic Contrast Ratio as one example.
Backlight Level
Brightness Level (Black Level)
Contrast Level (White Level)
The Brightness Level and Contrast Level has no effect on longevity and does not hurt the set. The Backlight Level, generally you hope that you dont have that full blast, so as to save life on the lamps. Over the life of the unit, (were talking decades) you will have to keep turning up the Backlight Level to keep a constant lumen output as the bulb wears itself out.
Epson 8350 / Panasonic AX-200u / Optoma Graywolf 92" / Draper Luma 92"
Samsung 51F8500 / Panasonic P50ST60 / Vizio P502ui-B1E / Sony 50W700B
Sony S790 / Panasonic BDT-220 / Roku 2 XS & Roku 2
Sony NT5 / Samsung F550 / Speakercraft CS3 / Yamaha YAS-105
EscapeVelocity is offline
post #7 of 8 Old 11-24-2012, 08:10 PM - Thread Starter
TenTonBass's Avatar
Quoted: 27 Post(s)
My LCD set does not have a Backlight level that I have noticed. The brightness setting is at about 50% right now.
Active control is turned off.
Dynamic Contrast is turned off.
Color temperature is set to normal.
post #8 of 8 Old 11-24-2012, 08:17 PM
Quoted: 573 Post(s)
Liked: 316
No Backlight Level control?
Bummer.
Reply LCD Flat Panel Displays
