60" vizio smart tv problems - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 11-26-2012, 05:50 PM - Thread Starter
DHULL's Avatar
Ok just bought the 60 inch vizio smart tv. Have been trying to get the apps to work for 3 days. I connected to my old router and it kept saying it was too slow so i went out and bought a brand new cisco one. I set it all up and when i put my passwork in it just keeps saying unable to connect but when i exit out and come back the litttle wireless half circles are there on the left. And sometimes when i hit the vizio button for the apps on the remote none of the other buttons will work expect the on/off PLEASE HELP
DHULL is offline
post #2 of 2 Old 11-26-2012, 07:35 PM
walford's Avatar
How far is your new 11n WIFI router from your 11n WIFI TV? What type of internet connection do you have?
Do you have other WIFI devices running on your router and therefore using available bandwidth at the same time and not having any problem connecting to the internt?
walford is offline
Reply LCD Flat Panel Displays
