Samsung UN55ES7003 Audio Return Channel - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 11-27-2012, 08:56 AM - Thread Starter
ajcoon's Avatar
The HDMI 2 port on the back of my TV says ARC, which would imply that the set supports Audio Return Channel. I have a Denon AVR-2312CI which also supports ARC and is connected to HDMI 2 on the Samsung TV.
When I go into the Samsung Smart Hub and play content from Pandora (for example), the sound comes out of the built-in TV speaker. How do I configure the TV settings to use ARC instead?
ajcoon is offline
post #2 of 4 Old 12-08-2012, 08:10 PM
pbass's Avatar
I have very similar question, but I have the Sony 55hx850 (tv) and Denon 2312ci AVR. Netflix is hosted on the TV, but sound will not play through Denon...just TV speakers (which I disable). I thought HDMI was smart enough to sense and switch...When I go to Netflix, the picture plays the Netflix movie while the cable box audio continues to play.
Any help is appreciated.
Paul
pbass is offline
post #3 of 4 Old 12-12-2012, 04:13 PM - Thread Starter
ajcoon's Avatar
Enabling HDMI-CEC in the Denon AVR fixed this for me. It, however, has the unintended consequence of an on-screen display whenever I change the volume level. Trying to find the option to turn THAT off now smile.gif
ajcoon is offline
post #4 of 4 Old 12-12-2012, 04:18 PM
fatuglyguy's Avatar
Quoted: 277 Post(s)
Liked: 606
ARC is a pain in the ass. I remember getting it work with my Panasonic TV and marantz AVR and it being so annoying to use that I just switched to optical.
desktop Sonus faber Toy monitor| REL T Zero| Sony UDA1|Sony MDR-Z7|Audioquest Nighthawk|Audioquest Dragonfly Red
surround Monitor Audio Silver RX6, RX Centre, RX1|SVS SB-2000|Sony STR-ZA5000ES|Panasonic 60ZT60|Oppo 103D|Sonos Connect + Peachtree Audio DAC•iT
stereo Sonus faber Toy tower|Teac UD-501|Sony TA-A1ES|Sony SCD-777ES|Sony ST-SA50ES|Sony BDP-S1700ES|Pro-Ject Debut Carbon DC Esprit + Tube Box S|Sonos Connect|Furman Elite-15 PFi
fatuglyguy is offline
Reply LCD Flat Panel Displays
Samsung , Denon Avr 2312ci Receiver
