Dolby Digital audio output not working - AVS Forum | Home Theater Discussions And Reviews
Old 11-27-2012, 04:26 PM - Thread Starter
Eric Katz's Avatar
I recently purchased an digital optical cable to go from the TV to my receiver. My receiver identifies the signal coming from the TV as PCM, even though I have the audio output on the TV set to Dolby Digital. I also just updated to revision U0905131 on my LC-46D64U, and it was successful, hoping to correct this problem, but no dice. Anyone have any knowledge of this issue?
Eric Katz is offline
Old 11-27-2012, 08:41 PM
lovinthehd's Avatar
Quoted: 4588 Post(s)
Liked: 4775
What's the actual source the tv is using? OTA? Cable? Sat? What is the spec for that source?
lovinthehd is offline
Old 11-28-2012, 05:13 AM
Ratman's Avatar
Quoted: 1289 Post(s)
Liked: 1028
This question is asked often....
Most TV's will only provide DD when using the TV's internal tuner. Any devices connected to the TV (cable box. DVD player) will be downmixed to PCM stereo. DD (or DTS) will not be "passed through".
You will need to connect the digital audio outputs from the external devices to the receiver.
Ratman is offline
Old 11-29-2012, 05:58 PM - Thread Starter
Eric Katz's Avatar
I appreciate you guys helping me out. Here's my situation:
1. I have Comcast, the set top box is an SA 4250HDC. It is connected via HDMI cable to my Sharp Aquos LC-46D64U.
2. I have connected my tv to my receiver via digital optical cable.
3. Cable box is set to output audio via HDMI.
4. TV is set to digital audio via HDMI
5. I had anticipated that my receiver would identify that receiver would report that it is in Digital mode, as it does when my blu-ray player is playing (connected audio via digital cable)
6. My receiver always says its using PCM. This is the part that disturbs me. It sounds fine, but I know it can be better.
Anybody have any suggestions?
Old 11-29-2012, 06:55 PM
topr's Avatar
See post #3
topr is offline
Old 11-29-2012, 06:58 PM - Thread Starter
Eric Katz's Avatar
I actually tried that, I connected a digital optical (toslink) cable from my cable box to my receiver, still only PCM. Very odd.
Old 11-30-2012, 05:14 AM
Ratman's Avatar
Liked: 1028
Check the audio settings in the SA 4250HDC. Maybe an audio option (if there is one) is set to PCM only.
Look at page 12:
http://media2.comcast.net/anon.comcastonline2/support/help/faqs/settopboxes/4250UserManual.pdf
Ratman is offline
Old 11-30-2012, 10:39 AM
sitlet's Avatar
Also be sure you are on an HD channel. SD channels will only output 2 channel stereo. Actually some HD programming is only 2 channel as well, but that is becoming more rare.
sitlet is offline
Old 11-30-2012, 12:29 PM
Ratman's Avatar
Liked: 1028
Perhaps.... but typically "digital" cable channels are Dolby Digital. They may be only DD 2.0 with non-HD channels, but still DD nonetheless, not PCM.
Ratman is offline
Old 05-19-2015, 10:40 PM
See The Light's Avatar
Quoted: 45 Post(s)
Liked: 59
Check you cable box's Digital Output Setting to see if it's set to Dolby Digital, or if it's set to PCM.
For some cable boxes, you get to that settings menu by truning the the cable box off and prssing "Menu" on the cable tv remote.
Cable Channel Choice is the only choice I want to make !!
See The Light is offline
