Samsung UN55ES7003 - Turning Off SyncPlus isn't Sticky - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 11-28-2012, 01:36 PM - Thread Starter
ajcoon's Avatar
Further to this thread it appears that when I turn off SyncPlus the setting is not "sticky". What I mean is, after turning off the TV and then back on, the setting returns to 'On' and I have to go back into Smart Hub and turn it to 'Off' again.
How can I disable SyncPlus so that it stays off?
ajcoon is offline
post #2 of 4 Old 11-28-2012, 04:08 PM
EAnglum's Avatar
Uncheck the terms and conditions box for SyncPlus (same place you turned it off).
EAnglum is offline
post #3 of 4 Old 11-29-2012, 08:33 AM - Thread Starter
ajcoon's Avatar
Again, fantastic. Thanks for the help!
ajcoon is offline
post #4 of 4 Old 12-10-2012, 05:28 PM
LAXEsq's Avatar
Hi. I can turn off the T&C for SyncPlus, but I don't know how to actually disable it. Can someone please help. Thanks.
LAXEsq is offline
Reply LCD Flat Panel Displays
