ready to purchase HX850 or HX950 , is it worth the extra money? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 16 Old 11-29-2012, 02:59 PM - Thread Starter
jrmtl's Avatar
Quoted: 37 Post(s)
Hello all,
This is my first post and hopefully I'll be back for more ...
I am about ready to buy the HX850 this weekend and after some research and being a long time SONY fan.( I still have a 15 yr old CRT XBR tube tv) I see that their TV's are still expensive but really good.
I have found many reviews on the 55 inch HX850 but since the 950 just came out , I can't find much in terms of decision breaking reviews.
I read that the intelligent peak LED is about the only real thing the HX950 has more to offer but is it worth 800$ CAD ?
I've gotten a price of 2100 and 3000 for them both respectively
Thx
Present Set:
Sony XBR55X900B ( Not 100% satisfied waiting on Sony response regarding edge bleed )
Previous replaced under warranty :
Sony XBR55-HX950 ( I miss it already with it's full array backlighting )
jrmtl is offline
post #2 of 16 Old 11-29-2012, 03:08 PM
BoilerJim's Avatar
Quoted: 56 Post(s)
Liked: 118
You might try the threads already dedicated to these TVs rather than starting a new one. They should answer a lot of your questions.
http://www.avsforum.com/t/1430346/sony-xbr-hx950-owners-thread-xbr-55hx9-50-and-xbr-65hx95-0
http://www.avsforum.com/t/1407673/official-sony-hx850-owners-thread-46hx850-55hx850
BoilerJim is offline
post #3 of 16 Old 11-30-2012, 06:46 AM
8mile13's Avatar
Quoted: 1730 Post(s)
Liked: 1011
The HX950 is a better option when you watch TV often in a semi-dark/dark environment, it's the videophile's choice. btw best pq you will get on a pro-calibrated TV when watching the best sources - blu-ray quality -... in a semi-dark/dark environment.
8mile13 is offline
post #4 of 16 Old 12-02-2012, 06:14 PM - Thread Starter
jrmtl's Avatar
Quoted: 37 Post(s)
Thanks a bunch for the advice... The tv will go in a basement man-cave smile.gif
And it's a fairly darkish room view narrow viewing angle.
A couple more questions...
1) So you are saying it's worth the extra 800 ?
2) does it need calibration and can I get help on this Site or yourself?
3) blooming issues that I hear?
4) how's the 3d with normal program and glasses
I saw the Samsung series 8 and it has a lot of gimmicks
Thx
Present Set:
jrmtl is offline
post #5 of 16 Old 12-03-2012, 04:13 AM
8mile13's Avatar
Liked: 1011
actually Plasma performs better in a dark environment (and Plasma is cheaper).
1) Is it worth the extra money for you? some reading in both threads will help.
2) all TVs need some kind of calibration. You could do some calibrating yourself (or copy settings) with the help of fellow owners. You might wanne know some more then visit the Display Calibration Forum
http://www.avsforum.com/f/139/display-calibration
3)+4) visit the HX950 owner thread and ask folks over there
http://www.avsforum.com/t/1430346/sony-xbr-hx950-owners-thread-xbr-55hx9-50-and-xbr-65hx95-0/1860
there is also a HX850 owner thread and a lot of Samsung owner threads.
8mile13 is offline
post #6 of 16 Old 12-03-2012, 09:08 AM - Thread Starter
jrmtl's Avatar
Quoted: 37 Post(s)
Ok will do ...
Seems like it's split down the middle on opinions .
Present Set:
jrmtl is offline
post #7 of 16 Old 12-04-2012, 04:24 PM - Thread Starter
jrmtl's Avatar
Quoted: 37 Post(s)
Just looked at a demo of the HX950 and wow that blooming we are talking about is really evident with a Sony logo on screen and when there's a menu on black background.
Not there on the 850.
Should this be deal breaker for this set or can we lessen the effect with some settings ?
Present Set:
jrmtl is offline
post #8 of 16 Old 12-04-2012, 06:07 PM
chicagorunner10's Avatar
This is why I'm not convinced that 'full-array' is really worth it.
Yes, it's better in some scenarios, but it's actually slight worse than edge-lit LED (due to blooming) in other scenarios, such as the one you mentioned, white text on black background; it's VERY obvious when movie credits run.
And then factor-in the fact that the full-array is more expensive, is somewhat more power hungry, and slightly thicker (not that I care about that one), and I think the highest-end edge lit (hx850) is the way to go. That's why I have my 46" HX820, and will probably stick with the highest-end edge-lit when I buy my 55" or 65" soon. The only thing that will probably change this is if they can get the full-array zones a lot smaller so that blooming is negligible.
chicagorunner10 is offline
post #9 of 16 Old 12-04-2012, 06:20 PM
stonorobert's Avatar
stonorobert is offline
post #10 of 16 Old 12-04-2012, 06:24 PM
mike50's Avatar
I have the 55HX950 and blooming is not an issue, unless it is set in torch mode(vivid with max baxklight). For movies, I set the backlight at 3 and there is no blooming even with white rolling credits on black background.
mike50 is offline
post #11 of 16 Old 12-06-2012, 10:16 AM - Thread Starter
jrmtl's Avatar
Quoted: 37 Post(s)
Thx for the input ...
I'm more confused now more then ever between the 2 sets.
The TV will be in a basement which is somewhat a darker room, so you say then with a minimal backlight it can fix the blooming thing?
Present Set:
jrmtl is offline
post #12 of 16 Old 12-06-2012, 01:21 PM
mike50's Avatar
Yes. I notice it only with the PS3, when the screen goes black and there is a white bright icon to indicate a new game chapter is loading.
mike50 is offline
post #13 of 16 Old 12-06-2012, 08:57 PM
Tapioca Cold's Avatar
Quoted: 13 Post(s)
If you care about pq then there is no question as to whether which is better. Sure you will see a small amount of bloom at times, but at least the entire set isn't blooming. Which is exactly what you get with en edge-lit set. Just go to any thread with an edge-lit set and 95% of the posts are complaints about clouding/ flashlighting and light bleed. Those problems just don't exist on a full array local dimming set.
A TV is an investment that you will use everyday. EVERYDAY. (This is my old salesman talk coming out). Invest in your TV and you will never have to doubt the quality. You had your last TV for 15 years. That's crazy. 800 dollars would amount to $53.00 extra per year. If your cheaping out and trying to save a buck you will just find your self on the other threads trying to find a solution to your set's flashlighting issues and clouding. Just another donkey chasing the carrot (massaging corners with fingers, swapping sets, visiting BB more times than the kitchen, constantly playing with pq controls etc.)
And if anyone out there disagrees then post pics of your edge-lit set in a dark room showing a black screen or dark scene.
You can't see where the black bars begin and the TV's Bezel begins. And 0% flashlighting in any corner. An edge-lit TV could not do this. Black is tha absence of light.
Tapioca Cold is offline
post #14 of 16 Old 12-07-2012, 02:03 AM
PathofNeo's Avatar
Quoted: 79 Post(s)
Liked: 26
Tapioca- What model do you have?
PathofNeo is offline
post #15 of 16 Old 12-07-2012, 03:38 PM - Thread Starter
jrmtl's Avatar
Quoted: 37 Post(s)
Thanks for those points... and indeed which model do you have ?
Present Set:
jrmtl is offline
post #16 of 16 Old 12-09-2012, 07:56 PM
Quoted: 13 Post(s)
It's not a Sony , But it is an example of what to expect with other full array local dimming sets. It's an LG lz9600 and was the step-up model to the LE8 which failed in certain aspcts. It never released in the US.
I spent good money for it, but being a stickler for great PQ, I'm very happy that I'm no longerr 'chasing that carrot'.
Cold
P.S. Since this pic I have had it professionally calibrated and it looks even better!
I'm sure you will be happy with whatever choice you make. Sometimes being a stickler for quality can be a hindrance to enjoyment.
Reply LCD Flat Panel Displays
