Samsung UN55ES7003 or Sony KDL55HX750 - AVS Forum
post #1 of 5 Old 11-29-2012, 10:22 PM - Thread Starter
WestRace's Avatar
So just wondering which one should have better picture quality and better internet support?
The UN55ES7003 is a new model so it should have the latest internet support, but the Sony
seems to have better picture quality. They are about $1500 at best buy.
WestRace is offline
post #2 of 5 Old 11-29-2012, 11:24 PM
Danediz's Avatar
Grab the HX750 or the Samsung ES7100. The 7003 is a black friday TV. Basically a dumbed down version of the 7100. The 7100 was 1599 but i think it jumped back up this week. If u can afford to pony up more money I would def go for the 7100 over the HX750. The 750 has mixed reviews on black levels. Now the Sony HX850 is a diff story and has mainly positive reviews.
Danediz is offline
post #3 of 5 Old 11-29-2012, 11:57 PM - Thread Starter
WestRace's Avatar
The 7100 is currently $1800 at best buy which is probably still within my price range, but I am not sure if it's markedly better than the 7003. Probably need to go back to best buy to check them out.
WestRace is offline
post #4 of 5 Old 12-01-2012, 01:06 PM
xbdestroya's Avatar
Those spec comparisons don't really speak to the main issues though, which are PQ and user experience related.
xbdestroya is offline
post #5 of 5 Old 12-01-2012, 06:28 PM
sureshraja1's Avatar
I have this UN55ES7003FXZA. Recently purchased (11/22/202). Wifi on this TV was working well for a few days (about 4-5 days tops). Now it won't even give me a list of wifi access point. Has anyone had this problem with this TV?
I am having Samsung do a in-home service. Picture quality is good but wifi is not connecting.
I also had this weird screen flickering/jitter when viewing Apple TV. Swapped a couple of these apple Tvs but the problem persisted. After turning Sync Plus off the problem (screen flicker with Apple TV) is gone.
Please let me know about wifi problem with UN55ES7003FXZA. After samsung tech visit I will decide to keep or return this TV.
sureshraja1 is offline
Reply LCD Flat Panel Displays
Sony Bravia Kdl55hx750 55 Inch 240hz 1080p 3d Led Internet Tv , Sony Kdl55hx750 55 Inch 3d Wifi Xr 480hz Led Hdtv Bdps590 3d Wifi Blu Ray
Gear in this thread - Sony by PriceGrabber.com
