LC-70LE945U release? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 12-02-2012, 06:32 PM - Thread Starter
jyeh74's Avatar
I was looking at a Sharp LC-70LE847U found at Best Buy until I saw a Sharp LC-70LE845U on their website. What is the difference? Is the 845 just for Best Buy? And, there is also a LC-70C8470U but I'm not sure what that is? I am guessing for Costco or something?
Is there suppose to be a 9 series release that is full array LED? LC-70LE945U
I tried searching but could not find anything.
Debating if it is worth it to pay $4000-4500 for a Sony XBR-65HX929 or Elite Pro60X5FD.......or just pay $2500 (half that) for a Sharp LC-70LE845U. The Sharp looks ok, and is very affordable. I just never had a Sharp so cannot comment on the picture and build quality. Thoughts?
jyeh74 is offline
post #2 of 2 Old 12-03-2012, 02:31 AM
johnfull's Avatar
Quoted: 367 Post(s)
Liked: 109
I like my LE845U that I got at BestBuy in June.
Some people have reported problems with uneven backlighting, but mine's good.
The active 3D feature works quite well.
The internet apps are variable and there is no keyboard on the remote -- all done onscreen and kind of clumsy.
Color is good after you calibrate. Lots of white and red clipping otherwise.
There are several threads discussing this and similar Quattron models and their differences from one-another...
johnfull is offline
Reply LCD Flat Panel Displays
Sharp Quattron Lc 70le945u
