Anyone try Omnimounts Play40 or 70 mount? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 12-06-2012, 10:57 AM - Thread Starter
brywisco's Avatar
I just ordered an Omnimount Play70 and was wondering if anyone had any experience with them.
They seem pretty new. It was expensive, but may be the perfect solution to my mount dilemna.
brywisco is offline
post #2 of 6 Old 12-06-2012, 11:40 AM - Thread Starter
brywisco's Avatar
brywisco is offline
post #3 of 6 Old 07-09-2014, 03:52 PM
homebrewguy's Avatar
Quoted: 21 Post(s)
Bumping this thread.
I am about too buy two play70s has anyone tried these are they the only product out there that has true full range of motion? I have a two Samsung 60" un60d8000 looking to mount new construction
homebrewguy is offline
post #4 of 6 Old 07-26-2014, 11:02 AM
Quoted: 21 Post(s)
Really no one has bought this mount...? Now I am skeptical if I should buy them, does anyone know of another mount that has come to freedom like this one?
post #5 of 6 Old 10-16-2014, 05:24 PM
Quoted: 21 Post(s)
Mounted it. It is a pretty impressive mount. Installation was very easy and it does exactly what it says it will, providing movement that no other mount can provide.
post #6 of 6 Old 05-02-2016, 01:41 PM
lexi73's Avatar
Bumping again, Any updates of additional owners? I'm looking at the play 70 for a new 65" Vizio and i'm curious how much "pan" i'll get with a 65" on the 28" arm length. I plan on putting it on a wall that when in use will need to be pulled out and turned as far as possible to the left for the best viewing angle.
Anyone who has one, how has it been working?
lexi73 is offline
Reply LCD Flat Panel Displays
