LG 55LM5800/5850 Owner's Thread - AVS Forum | Home Theater Discussions And Reviews
post #1 of 25 Old 12-07-2012, 06:17 AM - Thread Starter
Navigationroad's Avatar
I’ve been a lurker on this site for several years. I’ve read nearly all the posts on last year’s LW series and all this year’s threads on the LM6200, 6700, 7600, and 8600 series TV’s. I have been following the “Missing Trumotion “, thread with great interest also.
Last week I was in Costco Canada and saw a deal that I could not pass up. It was for the LM5850, a model that after all my research I was not familiar with. Although I hadn’t read anything about this TV I knew that it would be similar to the rest of the LM series but at a lower price point and therefore fewer features; and should share both their strengths and weaknesses. I was not too far wrong and so far I am pleased with my purchase. I think it’s a keeper.
If there are any other owners of this series out there, and there must be some because this TV was flying of the shelves at Costco, I would be interested in hearing from you so that we can share our thoughts and findings.
Navigationroad is offline
post #2 of 25 Old 12-11-2012, 08:44 AM - Thread Starter
I guess there aren't too many people out there with this tv.
post #3 of 25 Old 12-17-2012, 08:40 AM - Thread Starter
Anybody out there. I would love to hear from some other owners of these models. I've had the LM5850 for over a week now and am still quite happy in most respects. Im slowly getting the picture to where I like it.
post #4 of 25 Old 01-14-2013, 10:07 AM - Thread Starter
Just changed the name of this thread in the hopes that it will attract some interest. There must be some owners of these LG models out there.
post #5 of 25 Old 01-14-2013, 10:49 AM
rich7sena's Avatar
I've been looking into this TV as by local electronics retailer has one (without a stand, unfortunately) on open box. I believe it had a very brief stint in big box American retailers. From what I understand, it is a 1080p 120Hz passive 3D without any local dimming. I imagine it would be comparable in picture to the LM4600.
rich7sena is offline
post #6 of 25 Old 01-14-2013, 11:03 AM - Thread Starter
Based on many posts in various threads the 120Hz claim is debatable. It appears that most of the 2012 LM series models, except for the LM6200.7600,8600, and 9600, do not have Trumotion fully implemented either. Despite this I am very pleased with my LM5850.
post #7 of 25 Old 01-14-2013, 03:44 PM
beezorz's Avatar
Navigationroad, would you be willing to post your settings based on the Disney WOW disc you mentioned in the LM4600 thread?
I have the 55LM5800 and am enjoying it quite a bit for 3D Blu Rays and gaming in 3D with the PS3 is a massive improvement over the Sony set I previously had.
Would really love to be able to find some good calibration settings for the LM5800 for watching movies as well as for use with the PS3.
beezorz is offline
post #8 of 25 Old 01-14-2013, 04:22 PM - Thread Starter
I should be able to post my settings by tomorrow morning. At the present time I have only used the WOW disc to calibrate the settings for the BP420 that came with my LM5850. I have not as yet adjusted the settings for my PS3, but I could do it soon.
Keep in mind that the adjustments you make to your settings in the 2D mode do not apply to 3D. When a 3D signal is detected the TV automatically defaults to the standard setting with an increased backlight intensity that doesn't appear to be adjustable. You can however adjust both the contrast and brightness, but only before starting the 3D movie. Other settings might be adjustable but it is very difficult to tell when it's not possible to do on the fly.
Regards
Kevin
post #9 of 25 Old 01-15-2013, 06:33 AM - Thread Starter
As promised here are my calibration settings for my LM5850 using the Disney WOW disc played through an LG BP420 bluray player.
All adjustments were made in a semi darkened room. The only light source is a 13W 5000K CFL light bulb mounted about 9 inches behind the TV and about 1 foot in front of the wall. This is my best attempt at bias lighting.
HDMI 2
Energy Saving: Minimum (I could probably get the same backlight results by adjusting the dedicated backlight setting but I found this reduced my bleed on all inputs.)
Backlight: 40 (This can be changed depending on ambient lighting and user preference. Based on the WOW disc it does not affect the other calibration settings.
Contrast: 97
Brightness: 56
H Sharpness: 48
V Sharpness: 48
Color: 53
Tint: R3
Expert Control:
Dynamic Contrast: Off
Noise Reduction: Off
Digital Noise Reduction: Off
Black Level: Low
Color Gamut: BT709 (Not sure if this setting makes much difference. Still playing with it.)
Edge Enhancer: Low
Color Filter: Off
Color Temperature: Warm
Gamma: 2.4 ( Still playing with this settng also. Even when set at 2.4 the ideal gamma of 2.2 is not reached according to WOW)
All other settings are left unchanged.
As I mentioned in my previous post these settings are only good for 2D. I will do a calibration using my PS3 and post those settings in a few days.
Hope these help you for now.
Kevin
post #10 of 25 Old 01-15-2013, 02:16 PM
beezorz's Avatar
I used these settings to watch some movies with the PS3, and it is an improvement for sure.
Thanks for posting them!
beezorz is offline
post #11 of 25 Old 01-15-2013, 05:52 PM - Thread Starter
Your welcome. Like I said I will try and get the PS3 settings posted soon. I will see if I have some time early tomorrow morning.
post #12 of 25 Old 01-16-2013, 06:14 AM - Thread Starter
I ran the WOW calibration disc on my PS3 this morning. Other than a few minor changes the settings were generally the same. Something I forgot to mention in my previous post, and is quite important, is that the Aspect Ratio must me set to "Just Scan".
My PS3 is set up as per CNET's recommendations which can be found at the following link:
http://news.cnet.com/8301-17938_105-10022389-1.html
Here are the slight changes I made to the settings. These differences are very minor and could simply be due to input variations. Settings not mentioned are identical to my previous post.
Again, all adjustments were made in a semi darkened room. The only light source is a 13W 5000K CFL light bulb mounted about 9 inches behind the TV and about 1 foot in front of the wall. This is my best attempt at bias lighting.
Aspect Ratio: Just Scan
Brightness: 57
Color: 52
Tint:R1
That's it. Like I said not much difference between the two Blu-ray players. For some reason Gamma looked a little closer to ideal with the PS3. Considering this TV is at the lower range of the LM line it passes most of the tests extremely well.
If you are interested in the type of tests you can do with the WOW disc you can download the manual at the following link:
http://disney-wow.com/downloads.html
Kevin
post #13 of 25 Old 01-16-2013, 12:50 PM
beezorz's Avatar
That's awesome, Kevin, thank you for the additional PS3 settings and info.
You're right about not being able to adjust the picture settings while in 3D mode, but I found that you can switch picture presets with the AV Mode button on the remote. It just cycles through "Off", "Cinema", "Sport" and "Game", but it's something.
beezorz is offline
post #14 of 25 Old 01-16-2013, 05:24 PM
FredSmilth's Avatar
I have recently acquired this tv. Noticed that the trumotion wasn't available like already stated. I'm just wondering if we know if this TV is actually 120hz or not.
thanks, Fred
FredSmilth is offline
post #15 of 25 Old 01-16-2013, 06:06 PM - Thread Starter
thanks, Fred
Based on many comments made in various treads it's debatable as to whether the lower LM models are actually 120Hz.
post #16 of 25 Old 01-16-2013, 06:18 PM
FredSmilth's Avatar
Thanks for the quick reply!
It does seem to be that way. Oh well, regardless if it is or not, I'm happy with it.
Thanks, Fred
post #17 of 25 Old 04-04-2013, 08:39 AM
bargugl's Avatar
Quoted: 13 Post(s)
The LM5800 and LM4600 are basically the same tv. The LM5800 just uses a slightly different housing. In the US, most of the big box retailers/online warehouses only had the 5800 series available for couple of months in mid 2012, if they had them at all. They suddenly disappeared and then the LM4600's showed up in September/October. I've checked the parts lists and the LM6200, LM5800, LM4600, and the G2 all use the exact same model LCD panel, at least in the 47" and 55" sizes. They also all share the same power supply. Other than the G2, they also use the same mediatek processor that LG used in just about everything from the LM6700 on down. If anyone wants more info on the LM5800, they could probably just read the threads on the LM4600. Not sure why most of the US switched to the LM4600 series. Perhaps model number confusion as the LS5700 was a smart TV, while the LM5800 was not?
bargugl is offline
post #18 of 25 Old 04-05-2013, 05:07 AM - Thread Starter
Thanks for the info bargugl. It would be nice if LM5800 and 4600 owners could get some of the features the LM6200 model has. I believe the 6200 can make changes to the picture settings on the fly while playing 3D for example.
post #19 of 25 Old 04-09-2013, 09:19 PM
JamesEBoy87's Avatar
Hey guys just recently bought this tv in the deal where you get the blu ray with it....was wondering if there is any news on the tv getting "true motion" in a update or something? The box says 120hz true motion but noticing my picture doesn't seem as fast as the other 120hz tvs ive seen around anyone got some info?
JamesEBoy87 is offline
post #20 of 25 Old 04-10-2013, 05:36 AM - Thread Starter
This thread gives you the complete saga of the missing Trumotion feature on the lower tier 2012 LG models. I also have the 55LM5850 and was initially upset that LG could get away with this false advertising. However, for what I paid for the TV I'm for the most part happy.
http://www.avsforum.com/t/1408659/lg-trumotion-missing-specific-to-42lm-47lm-55lm-series-excludes-lm7600-and-newer.
I somehow doubt we will see a firmware update to include Trumotion. Owners of the LM6700 did get a partial fix after hdguru posted this article:
http://hdguru.com/lg-55lm6700-hdtv-review-when-120-hz-isnt-120-hz-updated/8281/
As this article points out this is not a 120Hz panel but a 60Hz. But again for what I paid for the TV with the excellent BP420 blu-ray player thrown in I'm very happy with it. Now if I had bought the LM6700 for $1200 or $1300 I would probably have a different opinion.
post #21 of 25 Old 05-06-2013, 12:34 PM
elementtw1023's Avatar
Just bought the 47" LM5800. Love it so far! Thanks for the calibration settings NavigationRoad! The TV has great color but I wish black levels were deeper. But overall its a great TV especially since I picked up a floor model for $400
elementtw1023 is offline
post #22 of 25 Old 06-20-2013, 11:04 PM
jhonjhon23's Avatar
Hey guys new to the forum.....i'm thinking of buying the lg lm5850 47" just a quick question though, does it play downloaded 3d movies through the usb? and also do i have to convert said downloaded file?
jhonjhon23 is offline
post #23 of 25 Old 06-28-2013, 06:35 AM - Thread Starter
Sorry jhonjhon I cannot answer that question as I have never tried to play movies through the USB. The 5850 is similar to the LM4600, 4700 and 6700 models. Perhaps someone in those forums can help you.
post #24 of 25 Old 06-28-2013, 07:06 AM
saugguy's Avatar
On the USB playback, the 55LM5800 is pretty good
It has played pretty much everything I threw at it including side by side 3d movies in mp4 format (download from youtube, for example)
saugguy is offline
post #25 of 25 Old 06-02-2014, 03:06 PM
55lm5850's Avatar
I have a 55lm5850that after 1.5 years while per on pause the tv went black and will not come back. Called support and a tech is suppose to come in 2 days. Will update
55lm5850 is offline
Reply LCD Flat Panel Displays
