Which 60" TV Should I Go With?? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 21 Old 12-09-2012, 11:20 AM - Thread Starter
TLang520's Avatar
Don't know which of these TV's would be better for me to buy, was hoping to spend under $1000, but if the Sharp would be alot better than the Vizio I'll pony up the extra few hundred. Any help would be appreciated!
Vizio E601i-A3 http://store.vizio.com/led-lcd-hdtvs/e601ia3.html
or
Sharp LC60LE640U http://www.sharpusa.com/ForHome/HomeEntertainment/LCDTV/Models/LC60LE640U.aspx
TLang520 is offline
post #2 of 21 Old 12-09-2012, 12:19 PM
Flatliner's Avatar
or
I have owned both over the past two months. I liked the Vizio a lot when I first got it. Color and overall screen quality, particularly right in front, is extremely good. Mine suffered lip sync issues but it was random enough that I was just putting up with it when it occurred. Unfortunately, after about a month, the picture stopped displaying an image though I could tell at least some of the LED's where still on (dark gray screen, not completely off). I also continued to hear audio. Anyway, back it went...and, I have to say, the incident with both the lip sync and final failure made me a bit gun shy of trying another one.
Fast forward to last week when I picked up the Sharp. I think the picture overall is a little better than that on the Vizio. Better blacks and slightly better off angle viewing. The surface is a little more matte than the Vizio. I did, for whatever reason, have a much easier time dialing in the color on the Vizio vs the Sharp (even though the Sharp has a lot of fine color controls). Main issues I have experienced with the Sharp:
1) Terrible soap opera effect with motion out of the box. Turning off all motion effects does not completely fix the issue. Thus far, the only solution I have found is to use the Game mode, which has two drawbacks. A) It cannot be used when watching the built in Apps such as Netflix. B) it's much more difficult to calibrate - and I'm not sure yet it can be accurately calibrated - as the Gamma is out of range as compared to the Movie mode (which, again offers no way to fix the motion issues).
2) At least on my unit, the built in WiFi is extremely weak to the point of being almost unusable. In fact, I can only get it to connect if I remove the security feature (password protection) from my wifi. With password protection enabled, I only get error messages when inputing my password and attempting to connect (WPA). I even went so far as to purchase a dual band (N+G) router to see if it might be my wireless router. It's not!
3) Arg! I have also experienced lip sync issues at least on one occasion with OTA HD (optical out to receiver). Never an issue with my prevous TV and same connection.
So, unfortunately, the Sharp is likely going back as well. I have no idea what I'm going to buy at this point to replace my seven year old 32" Olevia LCD.
Flatliner is offline
post #3 of 21 Old 12-09-2012, 12:49 PM - Thread Starter
TLang520's Avatar
Thanks for the reply!
Good to hear from someone who has first hand experience with both. From your experience it sounds like the Sharp probably isn't worth the extra $3-400. At $999 for a 60" tv it's probably worth it for me to give the Vizio a shot for myself.
Does anybody know of anything atleast 55" and up for under $1000 that would be a better alternative to the two I've listed?
TLang520 is offline
post #4 of 21 Old 12-09-2012, 01:05 PM
Flatliner's Avatar
A lot has to do with where the TV will be placed with regards to options. If you don't have to deal with reflections, I noticed that Costco currently has the LG LM6700 55" for $1199, which is the best price I have seen for that yet. It's a gorgeous set aesthetically with edge to edge glass - but it is much more reflective than the matte screens. The IPS panel will also not have the black levels of the Sharp nor Vizio. Otherwise, it should be a nice set. It was on my short list until I saw that the reflection issue was a deal breaker for my location.
I suspect the Sharp will drop in price a lot over the next month. If you buy somewhere with a price guarantee, you're pretty much covered if the price drops. For instance, if the price drops within 90 days at Costco, they will refund you the difference (you can also return it in that period for any reason). HHgregg also currently offers a thirty day holiday price guarantee.
One other negative with Sharp is that they may not be around a year from now given their financial situation. Just something to consider.
post #5 of 21 Old 12-09-2012, 01:13 PM - Thread Starter
TLang520's Avatar
The reflection on my current tv, a 42" Sanyo is pretty horrible, well everything on this Sanyo is pretty horrible lol, so I'd like to avoid that issue. And if that's the case with Sharp I don't want to get involved in that incase the tv would ever have a problem. We have two other vizio's in our house that have been perfect for years now, so I'm leaning more and more towards giving their 60" a shot.
TLang520 is offline
post #6 of 21 Old 12-09-2012, 01:20 PM
Flatliner's Avatar
Yeah, I may actually end up trying another Vizio myself after all of this. I did have to call their customer service and was surprised to get a live person located in the U.S. so I think Vizio is on the right track, at least regarding customer service.
post #7 of 21 Old 12-10-2012, 08:52 PM - Thread Starter
TLang520's Avatar
In case it helps anyone, I got the Vizio today and after calibrating it to my liking I could not be any happier, its just incredible watching the monday night football game right now, and its miles better than my old 42" sanyo.
TLang520 is offline
post #8 of 21 Old 12-10-2012, 10:53 PM
Jack Morris's Avatar
Depends on if money is no object.... otherwise, the Visio is a no brainer, IMO.
Jack Morris is offline
post #9 of 21 Old 12-13-2012, 01:11 PM
schex's Avatar
Did you get the Vizio due to price? I too have heavy reflections and am "switching sides" from my Plasma. Liked both of these. Costco has the Vizio E601IA3 , the Sharp LC 60C 6400u and the LG60LS5750. I saw the Sharp LE on base - wish I could make up my mind - they all seem pretty good - I like that the Vizio has Pandora I noticed the Sharp LE did not.
Almost seems as though the cheapest set (Vizio) has the best reviews or am I wrong?
Also noticed that Vizio has wifi and Sharp does not? I can't hard wire my TV so if it's gonna get internet I need WIFI
SCHEX
schex is offline
post #10 of 21 Old 12-13-2012, 02:00 PM
Flatliner's Avatar
The Sharp 6400 does have WiFi built in, though mine is pitifully weak and requires help with reception [Belkin makes a very inexpensive ethernet wifi bridge which works].
Regarding picture quality, the Sharp is better. Noticeably better blacks, less clouding and a little better off angle viewing. Once one sees the image quality of the Sharp, it sort of spoils you. Negatives: I have experienced Lip-Sync issues with both sets occasionally with OTH HD [ABC]. The Sharp has an issue dealing with motion and film material unless Game mode is used - the Vizio did not have this problem. So, as can be seen, both have plenty of warts/ issues and neither is perfect. And, Yes, it sucks the Sharp does not include Pandora. My wife said it had to go back for that reason alone.
post #11 of 21 Old 12-13-2012, 02:12 PM - Thread Starter
TLang520's Avatar
I got the Vizio due to price, reviews, having good experiences with other vizio tv's (have 3 others in my house), and wanting a bigger screen. My budget was $1000, and I was originally planning to get a 47" LG 3D TV to replace my 42" Sanyo LCD, but I honestly don't like 3D that much so I decided to look for a bigger LED set. When I saw the Vizio I was almost certain it was exactly what I was looking for.
I've never owned any Sharp products but I've always thought their TV's looked very nice. Since $1000 was my budget, I was looking at the Sharp LC60LE600U (Which is basically supposed to be the 640U with out any features more or less for $999), but after finding reviews on that model it sounded like it was just not very good and people who bought it seemed to always take it back and switch to the 640U. To me though comparing the Vizio E601i-A3 and the Sharp LC60LE640U, I didn't see anything that would make me spend the extra $3-400 to get the Sharp over the Vizio, and yes you are correct, from what I've read the Vizio has much better reviews.
So far my experience with the Vizio has been excellent. Not only does it seem massive compared to my old 42" sanyo, the picture is atleast 1000 times better than my sanyo's, once I calibrated it to my liking, it is just incredible to look at to me. The wifi and all the apps I've tested so far work wonderfully. My xbox 360 plays beautifully, and for some reason my surround sound sounds better hooked up to this tv than my sanyo. My room the TV is in is fairly dark most of the time but I opened up all the windows to test the glare on the screen and I didn't even see anything, no reflections for me at all now. The only thing that is not great about the tv is the speakers, they are a little mediocre, but what do you expect from a 1 inch thick tv lol. I use my surround sound always anyway so it's not an issue for me.
Obviously the final decision is yours for what you buy, but if you need to know anything else about the Vizio, I'll happily try to help you out!
TLang520 is offline
post #12 of 21 Old 12-13-2012, 05:39 PM
schex's Avatar
Thanks for the replies. I appreciate it. I have been rewiring my wall mounted speakers to make room for a bigger screen. I painted today smile.gif
So I am almost there just gotta pull the trigger.
My room is very bright. I really would buy a dumb TV if they had any?? I don't need speakers or really any internet, off angle viewing no more than about 45 degrees.
With those parameters and a $1500 or so budget any ideas??
Bajapalm
how about a pic? the bright room & the plasma and now moved speakers
TIA
view of my living room and back of panny from dining area
SCHEX
schex is offline
post #13 of 21 Old 12-13-2012, 06:41 PM
Flatliner's Avatar
45 degrees is enough to get a very noticeable washing out of the picture with the Vizio. It has a very small sweet spot right in front, where it looks exceptional. Some people are more sensitive to this than others but I was surprised by how washed out the picture became outside of that sweet spot. This is common on all non-ips displays - and the IPS models suffer other issues such as poor black levels - but it is particularly severe with the Vizio. First thing I noticed when I replaced it with the Sharp was this difference, followed by the better blacks. But, as I mentioned above, it has it's own set of issues.
The "dumber" sets in this price range are often inferior in other ways, the most notable being a severe lack of fine picture control. The Sharp that's often around 1K for instance suffers from this - and I think others have noticed it may be a lesser quality panel as well.
In the end, it comes down to what trade offs you want to make at this price.
post #14 of 21 Old 12-13-2012, 07:37 PM - Thread Starter
TLang520's Avatar
Yeah I agree with most of this, I don't have the viewing angle problem with the Vizio the way my room is set up so it looks great all the time to me.
And that's the exact reason I didn't get the sharp for around 1k, all the reviews said it lacked the ability to really calibrate the picture and the panel may have been lesser quality.
In my personal experience, all of the possible issues the Vizio could have had (lip sync, viewing angle, and im sure a few other things i cant think of right now) have not applied to me at all, I've been very happy with everything so far. I don't know how good of a judge I am for picture quality because I'm comparing this tv to my old garbage 42" sanyo lcd, but the display meets my expectations and looks beautiful to me for everything I've watched so far.
TLang520 is offline
post #15 of 21 Old 12-13-2012, 07:45 PM
Flatliner's Avatar
The Vizio looked great to me in it's sweet spot. I also think it was a little better with regard to color accuracy than the Sharp. The lip-sync issue I had was random - and rare enough - that I was willing to put up with it [and changing the channel back and forth fixed it when it occurred]. The major reason I don't still have the Vizio is that it failed completely and lost it's picture just after a month. I guess I just ended up with a dud. Anyway, enjoy the Vizio! I'm still trying to figure out my next step - deal with the Sharp issues or get what?
post #16 of 21 Old 12-13-2012, 10:19 PM
schex's Avatar
In Costco I looked at Vizio quite a bit - the colors were a bit muted compared to the others around it but that could just be settings? I did not notice a significant drop in PQ with off angle viewing. The plasmas looked the best to me, but the reflectivity of the screen is just such a killer for me - what about the LG?? any feedback on their unit??
SCHEX
schex is offline
post #17 of 21 Old 12-13-2012, 10:33 PM - Thread Starter
TLang520's Avatar
I don't have any experience with LG really at all, but I can tell you it's most likely just the settings on the Vizio, out of the box when I first turned the tv on I thought it looked kinda bad actually, the picture was dark and washed out looking. But once I calibrated the settings to my liking, I was blown away by the picture quality and colors. Just for an example, I saw the movie "Finding Nemo" was on tv last night and I turned it on because I knew that movie has a lot of vibrant colors being underwater and stuff, and even though it's just a kids movie, I literally fell into a trance for a solid 20 minutes, just amazed by how eye popping and vibrant the colors of that movie appeared.
TLang520 is offline
post #18 of 21 Old 12-14-2012, 05:26 AM
RockmanX's Avatar
Liked: 37
Lg is a good brand of course go to your local BB or Conns and view and play with options
RockmanX is offline
post #19 of 21 Old 12-14-2012, 06:30 AM
Flatliner's Avatar
I have been closely looking at the LG LM6700 at Costco lately. Love the design aesthetics of the edge to edge glass. The screen is not high gloss but is definitely much more reflective than any of the matte screens. Cnet tested both the LM6700 and the LM7600. While both look almost identical on paper except for features, Cnet found the LM7600 to be much better with regard to picture quality, even surpassing LG's top of the line sets. The big issue they found was uniformity. Since I tried an LG about a year ago and saw major issues with uniformity, this is one of the major issues preventing me from trying another LG as they seem to have a major issue with this. The other thing is size. It doesn't sound like there would be much difference between 55" and 60" but once you have been looking at a 60" for a while in use, downsizing is very noticeable. I saw this after using the Vizio for about month and then trying a Panasonic 55" right after. It felt small. The current LG's which are 60" are not rated very highly from what I have read.
The LG smart apps also lacked Pandora, unless that has changed. Does anyone know? So far, both the Vizio and the Panasonic have had the most complete built in smart apps if that matters to anyone. If the Sony 850 drops in price to under $1500, that would likely be the set I try next - though it's not 60" but 55".
post #20 of 21 Old 12-14-2012, 10:10 AM
schex's Avatar
Thanks for the input -
TLang your story reminded me of about ten yrs ago when I first got a DVD player and plasma - I didn't own a DVD so borrowed one from my niece "Princess Diaries" haha my family still teases me, but it was for science!!
I have been a Panny fanboy since 03 or so so all of these are new to me,
Flatliner - my Costco didn't have the LM 6700 only the LS 5750 @ $1199 -
If the pix on the Sharp Aquos/LG/Vizio and Costco Sharp are all about equal - I think I lean toward the Vizio since it's cheaper $979 and has Pandora - Reflectivity would be my second priority tp PQ of the set
SCHEX
schex is offline
post #21 of 21 Old 12-14-2012, 03:12 PM
RockmanX's Avatar
Liked: 37
I'm sure vizio has gotten better quality wise but before as I own a 32 inch the picture is trash even on HDTV programming
RockmanX is offline
Reply LCD Flat Panel Displays
