4 screws that mount the stand to back of tv ?? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 12-13-2012, 10:10 AM - Thread Starter
elykoj's Avatar
anyone know the size of these 4 screws that mount the stand to the back of the tv? my tv stand is backordered and i have misplaced the screws to mount the stand that came with it to the tv. ANYONE ????
elykoj is offline
post #2 of 3 Old 12-13-2012, 12:00 PM
lovinthehd's Avatar
Quoted: 4588 Post(s)
Liked: 4781
Did you look in your manual? Hard for anyone else to do that since you don't even post the brand let alone the model of your tv....or call the manufacturer's customer service line...
lovinthehd is offline
post #3 of 3 Old 12-13-2012, 01:28 PM
TKO
TKO's Avatar
The TV most likely follows VESA standards and will use an M4 screw size probably no more than 1/2" in length.
Tom
TKO is offline
Reply LCD Flat Panel Displays
