Digital audio out - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 12-14-2012, 08:42 AM - Thread Starter
joebas's Avatar
Is the output of the Digital Audio cable 5.1 or just stereo?
joebas is offline
post #2 of 7 Old 12-14-2012, 12:29 PM
sitlet's Avatar
Quoted: 14 Post(s)
Well, this is a very vague question. However, assuming you mean the optical output of a tv, then the answer is the optical output will output 5.1 from the tv's internal tuner, both OTA and QAM, if the source is 5.1 of course. Devices connected to the tv via hdmi will normall not output 5.1 through the optical port, only stereo. There are a few models that will, however they are slim to none.
sitlet is offline
post #3 of 7 Old 12-14-2012, 01:03 PM
Otto Pylot's Avatar
Quoted: 1625 Post(s)
Liked: 1022
^^^^^ 100% correct.
Otto Pylot is offline
post #4 of 7 Old 12-14-2012, 05:30 PM - Thread Starter
joebas's Avatar
Yes, sorry I was talking about the optical out on my Sharp lc60le640U. I am thinking of buying the Vizio VHT510 & wanted to know if 5.1 would be sent to the soundbar. Thanks for your help.
joebas is offline
post #5 of 7 Old 01-01-2013, 07:30 AM
bajaspeed's Avatar
How far in does the optical plug go into the tv? Mine wants to only go in half way and everytime you turn the tv on, you have to work the card around to get sound, any suggestions?
bajaspeed is offline
post #6 of 7 Old 01-01-2013, 02:07 PM
sitlet's Avatar
Quoted: 14 Post(s)
That should not happen. Either you have a bad cable or a bad port on the tv.
sitlet is offline
post #7 of 7 Old 01-01-2013, 02:20 PM
Ratman's Avatar
Quoted: 1475 Post(s)
Liked: 1180
.... or you didn't remove the protective caps/covers from the cable.
If you can’t explain it simply, you don’t understand it well enough – Albert Einstein
Ratman is offline
Reply LCD Flat Panel Displays
