Panasonic ET5B IPS. Problem HELP! - AVS Forum | Home Theater Discussions And Reviews
post #1 of 1 Old 12-15-2012, 01:52 AM - Thread Starter
Richdot's Avatar
Hi
I am having this annoying problem :
Basically when connected to a gaming console when you change the picture preset to game mode it shows up lines going down the screen like vertical banding ( shows on light colours or unlit areas) But as soon as I select normal picture preset it all goes :s I am really confused why this happens and I seem to be not the only one either..... Any ideas?
Richdot is offline
Reply LCD Flat Panel Displays
