TV to fit in 28.5 inch wide space - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 12-16-2012, 03:19 PM - Thread Starter
dannyfive0's Avatar
I recently moved into a new house (built in 1940's) and the living room has a custom built in cabinet for the TV. The space is 28.5" - 28.75" wide. I'm having trouble finding a TV that fits the space. At this point, I'm not picky, I just want a flat screen that will fit the space. Anybody know of a flat screen with 28.5" width?
dannyfive0 is offline
post #2 of 3 Old 12-16-2012, 05:11 PM
walford's Avatar
There are some 29 and 30" diagonal inch 720p LCD models which should fit in your space. There may even be some 32" models that will fit. Make sure you also have room for ventilation if the unit you get has ventilation slots on the side. I suggest you go to BB and Wall Mart with your tape measure in hand and see what you can find.
walford is offline
post #3 of 3 Old 12-22-2012, 10:50 AM
djmechanic1's Avatar
Hanspree and Coby both make TV`s that will fit this space. I purchased a Hanspree several years ago.
djmechanic1 is offline
Reply LCD Flat Panel Displays
