Looking for an inexpensive mount for a Samsung UN55ES7100 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 9 Old 12-16-2012, 03:38 PM - Thread Starter
elliscs's Avatar
I'm looking for an inexpensive mount for a Samsung UN55ES7100. I want a tilt mount but I don't want to pay an arm and a leg. Can't seem to find any recommendations on the forums anywhere so I thought I'd ask.
elliscs is offline
post #2 of 9 Old 12-16-2012, 07:06 PM
topr's Avatar
topr is offline
post #3 of 9 Old 12-16-2012, 11:22 PM - Thread Starter
elliscs's Avatar
Should about the quality of those mounts? They're so much cheaper than everything else .
elliscs is offline
post #4 of 9 Old 12-17-2012, 01:21 AM
Gregck's Avatar
Not at all. 99% of wall mounts in retail stores are marked up 75-90% of what they should actually retail for. Monoprice mounts are good. Rule of thumb with any wallmount, whether it's a $400 wall mount from best buy or a $20 wall mount from monoprice, BRING YOUR OWN BOLTS!
good luck!
Gregck is offline
post #5 of 9 Old 12-17-2012, 09:47 AM - Thread Starter
elliscs's Avatar
good luck!
Good advice. Anything I should consider before buying from one from Monoprice? There seem to be a ton to choose from.
elliscs is offline
post #6 of 9 Old 12-17-2012, 01:49 PM
badchad65's Avatar
Just a couple things from my recent experience:
1. I would definitely make sure it had a "fine tune" adjustment for leveling after hanging. The actual mount is often small. Once a larger TV is hung on it, any imperfections become magnified.
2. I would look for a "swing out" option. Some of the sanus mounts have an option where the TV can swing away from the wall after mounting. It makes it WAY easier to add new connections (e.g. plug in a new HDMI device).
These might not be compatible with "inexpensive", but would be well worth the cost in my humble opinion.
Polk Fronts: RTi A7's
Polk Center: CSi A6
Polk Surrounds: FXi A6's
Polk Rear Surround: RTi4
Sub: HSU VTF-3 (MK1)
AVR: Yamaha RX-A2010
B&K Reference 200.7
TV: Sharp LC-70LE847U
badchad65 is offline
post #7 of 9 Old 12-18-2012, 08:31 AM
boxorox87's Avatar
I go to a local home improvement store and buy ProMount brand products. It is much cheaper than anyplace I can find online and I love both articulating mounts I have bought.
I live in Wisconsin and buy them at Menard's.
boxorox87 is offline
post #8 of 9 Old 01-24-2013, 07:53 PM
dta721's Avatar
dta721 is offline
post #9 of 9 Old 01-26-2013, 02:46 PM
jclimber99's Avatar
There is no need for fine tune adjustments. Place mount on wall, mark holes using level on mount. Drill holes, attach bolts (here is where you can I guess move the mount a smidgen before super tightening the bolts). Once the bolts are tightened the mount should not move even with a TV on it.
I would advise against a swing out option. Those mounts are ugly and place the TV farther away from the wall than a non-swinging mount.
I would even advise against a tilting mount unless you are hanging the TV well above natural eye level (ideally center of TV should be at eye level). I got the 6523 monoprice non-tilting mount and it's great. Only $25 too! But as someone else mentioned, I had to go to Home Depot to buy bolts (the ones it came with were either too short or too long for my 55ES7100).
Go Aggies!
jclimber99 is offline
Reply LCD Flat Panel Displays
Samsung Un55es7100 55 Inch 1080p 240 Hz 3d Slim Led Hdtv Black
