Sharp AQUOS LC-60LE600U 60" LED TV - AVS Forum | Home Theater Discussions And Reviews
post #1 of 1 Old 12-19-2012, 11:24 AM - Thread Starter
krdell's Avatar
I just bought this TV for $950 from Best Buy. I'll preface by saying that I understand that I bought a bargain TV so I wasn't going to get the best quality product out there. Having said that, I am wondering if there is a picture setting configuration I can set to fix a gripe I have with dark pictures. When set at the default level, when the scene has darkness or shadows you simply cant see them very well. When I turn up the brightness/backlighting the darks appear grey and/or grainy. I have tried adjusting the contrast some but not sure if that helps. If there a combination of settings I can try or is this just an issue with the TV? Thanks in advance!
krdell is offline
Reply LCD Flat Panel Displays
Sharp Lc60le600u Led Hdtv
