HDMI cable from amazon - AVS Forum | Home Theater Discussions And Reviews
post #1 of 19 Old 12-22-2012, 02:58 PM - Thread Starter
Waqas5's Avatar
I need a HDMi cable for my LCD Samsung tv, I want to know which HDMi cable is worth buying. I know I can find a pretty good cable from amazon for a cheep price. I am looking t get a 6ft cable.
Suggestings will be great.
Waqas5 is offline
post #2 of 19 Old 12-22-2012, 03:11 PM
Gregck's Avatar
http://www.amazon.com/AmazonBasics-High-Speed-HDMI-Cable-Meters/dp/B003L1ZYYM/ref=sr_1_1?ie=UTF8&qid=1356214178&sr=8-1&keywords=hdmi
If you want to save a dollar or two, you can order from Monoprice.com, but shipping will take much longer.
Just be sure to look for a cable that supports the newest standard for HDMI which supports 3D/ethernet/audio return etc, especially if you have a 3D TV.
EDIT: and just to make sure, do not overspend on an HDMI cable, the $2000 monster cable and the $5 Amazon cable are the same thing.
Gregck is offline
post #3 of 19 Old 12-22-2012, 04:35 PM
fritzi93's Avatar
Liked: 41
If I were you, I'd get 2 or 3 from monoprice. Shipping will be only a little more, and you'd have extras on hand.
As mentioned, they're just as good as the astoundingly over-priced monster cables. So don't be a sucker.tongue.gif
fritzi93 is offline
post #4 of 19 Old 12-22-2012, 04:52 PM - Thread Starter
Waqas5's Avatar
Thanks for the suggesting, would you recommend any specific brand? Should I order it from amazon or Mono price?
Waqas5 is offline
post #5 of 19 Old 12-22-2012, 04:54 PM
Gregck's Avatar
As i mentioned, if they are 3d/ethernet capable, they are pretty much all the same. if you need the cable as soon as possible, order from Amazon, if you can wait a week or two, order from monoprice.
it's as simple as that! Good luck!
Gregck is offline
post #6 of 19 Old 12-22-2012, 09:17 PM - Thread Starter
Waqas5's Avatar
Will it be worth it if I order it from mono price? I need two of them.
Waqas5 is offline
post #7 of 19 Old 12-23-2012, 08:08 AM
fritzi93's Avatar
Liked: 41
Just a few weeks ago, I got 3 of these:
http://www.monoprice.com/products/product.asp?c_id=102&cp_id=10240&cs_id=1024008&p_id=3953&seq=1&format=2
Other colors and lengths available. These are as good as any, and cheaper. IIRC, it took less than a week to get them via USPS. But right now, figure a week or more.
Good luck.
[EDIT] If you need HDMI w/ethernet cables, look here:
http://www.monoprice.com/products/search.asp?keyword=hdmi+ethernet+cable
fritzi93 is offline
post #8 of 19 Old 12-23-2012, 08:38 AM
bryant's Avatar
I bought these (amazon) and have been very happy with them. If you have Amazon Prime, I found these to be a bit cheaper than MonoPrice too. I have some MonoPrice HDMI cables as well & found these to be just as good.
bryant is offline
post #9 of 19 Old 12-24-2012, 02:28 PM - Thread Starter
Waqas5's Avatar
Is this a good HDMI cable http://www.amazon.com/BlueRigger-Speed-Cable-Ethernet-2-Pack/dp/B0079MX4Q4/ref=sr_1_11?ie=UTF8&qid=1356384440&sr=8-11&keywords=hdmi+cable+6ft
I am going to be ordering two of them, so I need to know where I should order it from?
Waqas5 is offline
post #10 of 19 Old 12-24-2012, 07:15 PM
Otto Pylot's Avatar
Quoted: 1364 Post(s)
Liked: 854
All you need is Certified High Speed HDMI cables from a reputable dealer/mfr such as Monoprice, MediaBridge, or BlueJeans. Just make sure the certification is for the length of cable you buy. Certified cables are tested for a particular length to insure that they meet the HDMI specs. However, those specs cover more than is currently available in consumer products (such as ethernet, there are no consumer devices that can use ethernet over HDMI yet) so you're buying for the "future". If you think you need ARC, make sure that your devices are ARC capable (receiver and tv).
Otto Pylot is offline
post #11 of 19 Old 12-25-2012, 11:55 AM - Thread Starter
Waqas5's Avatar
I was thinking about getting this cable from Amazon http://www.amazon.com/gp/product/B0079MX4Q4/ref=ox_sc_act_title_1?ie=UTF8&smid=A3TG9YEWX61L6A
Is this cable the same from Amazon http://www.monoprice.com/products/product.asp?c_id=102&cp_id=10240&cs_id=1024008&p_id=3945&seq=1&format=2
I am going to be ordering two of these
How do I find out if the cable is certified?
Waqas5 is offline
post #12 of 19 Old 12-25-2012, 01:39 PM
Otto Pylot's Avatar
Liked: 854
The Monoprice cables have ferrite cores which I don't think you really need so I wouldn't pay extra for that feature. If the cable is "certified for the length of cable" to meet all HDMI specs, then it should state that somewhere on the packaging or it should come with a certificate. Some mfrs have the certificates available on their websites that you can view and download. You need to ask if not clearly stated. Having a cable that is certified for the length that you buy is important. You may buy a cable from a mfr that indicates all cables are certified but if that certification is really only good for the 3' cable, and you buy a 10' cable, you may encounter issues ("sparkles", no video, etc). And I'd never buy an HDMI cable from eBay because most of them are fake, sub-standard cables, especially if the price is really good.
post #13 of 19 Old 12-25-2012, 05:14 PM - Thread Starter
Waqas5's Avatar
Would recommend me buying the cable from mono price?
I don't think it is listed that cable certified. http://www.monoprice.com/products/product.asp?c_id=102&cp_id=10240&cs_id=1024008&p_id=3945&seq=1&format=2
Waqas5 is offline
post #14 of 19 Old 12-25-2012, 05:38 PM
rogo's Avatar
Quoted: 1593 Post(s)
Liked: 1790
Any Monoprice cable is fine for a short run.
Period.
There's a saying about "everything in moderation". If only it was applied to well, you know...
rogo is offline
post #15 of 19 Old 12-25-2012, 07:57 PM
nota's Avatar
for a 25ft run computer to tv
what is the best picture to price deal
vga hdmi Y Pi Pr wifi or other ?
nota is offline
post #16 of 19 Old 12-25-2012, 08:23 PM
Jack Morris's Avatar
Do you have something like a DC-DA1 which will fool a source to think that your VGA output is connected to a Hollywood approved HDMI monitor?
These days, for no problems but restricted (by law) abilities you need to use an HDMI cable.mad.gif
Jack Morris is offline
post #17 of 19 Old 12-26-2012, 11:43 AM - Thread Starter
Waqas5's Avatar
I just want to verify that this HDMI cable is worth buying because I am going to be buying two http://www.monoprice.com/products/product.asp?c_id=102&cp_id=10240&cs_id=1024008&p_id=3952&seq=1&format=2
Also will this cable give me the same picture quality as the one I have now? This is the one I have now http://www.sears.com/shc/s/p_10153_12605_05710901000P?vName=Cameras%20&%20Camcorders&cName=CameraCables&Connectors&sName=HDMI%20Cablesmv=rr
Waqas5 is offline
post #18 of 19 Old 12-26-2012, 12:02 PM
Otto Pylot's Avatar
Liked: 854
$30 is a bit steep for the Sears 6' cable. If certification isn't listed, then you need to contact the mfr and see what they have to say. Gold connectors, oxygen-free metal, etc are all extra fluff that really don't justify the extra cost. The Amazon link doesn't work so I can't see what the cables are like. You can use non-certified cables from a reputable mfr/dealer it's just that the certification guarantees that the cable has been tested to work under the High Speed HMDI protocols listed for the length of cable.
post #19 of 19 Old 12-26-2012, 01:03 PM
Ratman's Avatar
Quoted: 1289 Post(s)
Liked: 1028
Top of page:
"HOME > CABLES > Video Cables - HDMI > 28AWG HDMI High Speed Certified Male to Male Cables"
Ratman is offline
Reply LCD Flat Panel Displays
