small cheap HDTV's UPSTAR ? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 12-24-2012, 10:42 AM - Thread Starter
nota's Avatar
I bought a samsung 39'' led tv on black friday
but it got lines and flashing on screen with in the 30 return at tigerD
so back it went
and they had a upstar 24'' led/lcd 1080 for $99. after rebate
and I wanted a 24 computer monitor anyway so I picked one up
as a stop gap untill the post xmass sales kick in
word of warning this tv has TWO power switches
but the owners manual said NOTHING about the second PRIME switch
that is hidden on the bottom of the tv
the remote or the top visible buttons do NOTHING unless the bottom hidden switch is on FIRST
anyway the little tv looks good and was the best deal on a 1080/led tv out there locally
and cheaper then just a monitor in the size range by a quite a bit
and it has a full range of inputs vga hdmi component usb ect that many cheaper monitors lack
but I seen nothing on upstar or this tv P240WD here
anyone else try one or use it for a monitor ?
nota is offline
post #2 of 2 Old 01-07-2013, 08:28 AM
librarylisa's Avatar
I thought my Upstar 24" was broken! I read and read the directions looking for the reason it wouldn't power on. Then I accidentally found the button at the bottom of the screen. Glad to know I wasn't the only one
Love the TV for the price. I need a soundbar that is compatible and inexpensive. Any ideas or recommendations?
librarylisa is offline
Reply LCD Flat Panel Displays
