Just found out my TV isn't actually 120hz, what the heck? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 11 Old 12-25-2012, 06:14 AM - Thread Starter
HelloHelloHello's Avatar
LG 46LD550, advertised as 120hz.. plugged my computer into it and what do you know, it only reports a max refresh rate of 70hz?
HelloHelloHello is offline
post #2 of 11 Old 12-25-2012, 06:31 AM
Dr.Shankenstein's Avatar
Quoted: 507 Post(s)
Liked: 442
The 120HZ usually refers to the post-processing done by the Tru-Motion feature on the set.
Dr.Shankenstein is online now
post #3 of 11 Old 12-25-2012, 07:01 AM - Thread Starter
post #4 of 11 Old 12-25-2012, 08:15 AM
PlasmaPZ80U's Avatar
Quoted: 2289 Post(s)
Liked: 705
not really, all TVs with a refresh rate higher than 60Hz work this way
-7.1ch Bedroom HT-
Samsung UN46EH6030
Yamaha RX-A2070
SVS Prime Bookshelf and Prime Center
Sony SS-CS5 Surrounds and Cambridge S20 Rear Surrounds
Rythmik LV12R
PlasmaPZ80U is offline
post #5 of 11 Old 12-25-2012, 09:51 AM
Otto Pylot's Avatar
Quoted: 1621 Post(s)
Liked: 1020
As PlasmaPZ80U said, not really. It's always helpful to learn as much as you can about the new technologies so that you don't have any surprises like this. You probably don't see any SOE either because TruMotion is turned off.
Otto Pylot is offline
post #6 of 11 Old 12-25-2012, 10:15 AM
Luke M's Avatar
Quoted: 328 Post(s)
Liked: 112
As far as I know, zero 120hz TVs can accept a 120Hz input. Even the most expensive ones can't. One thing getting in the way is that standard HDMI can't do it. You would need high speed HDMI, or DL-DVI, or DisplayPort.
Luke M is offline
post #7 of 11 Old 12-25-2012, 07:57 PM
Otto Pylot's Avatar
Liked: 1020
Nowadays using anything less than a Certified High Speed HDMI cable for the HDMI 1.4 hardware spec would be silly. Most, if not all new tv's comply with the 1.4 hardware spec.
post #8 of 11 Old 12-25-2012, 11:27 PM - Thread Starter
No, it's defintiely on.
post #9 of 11 Old 12-26-2012, 06:02 AM
walford's Avatar
A 120 Hz TV displays 120 images per second. See:
http://whatis.techtarget.com/definition/soap-opera-effect-motion-interpolation
Also the INFO button on most HDTVs displays the resolution that the TV is receiving and not the resolution that the TV is displaying
walford is offline
post #10 of 11 Old 12-26-2012, 06:07 AM
dfp
dfp's Avatar
I think everyone is saying that signals into the TV are 60Hz, and the TV itself doubles the frame rate internally to 120Hz. Trumotion then allows you to increase the adjustment to eliminate blur... turning it up all the way should lead to the soap opera effect. I do recall reading that certain LG models were advertised as having Trumotion but it wasn't implemented in the firmware. Possibly firmware updates provided it for owners. The best thing you could do is to read the LG thread for your model and see what you can find out there.
dfp is offline
post #11 of 11 Old 12-26-2012, 01:09 PM
sitlet's Avatar
Quoted: 14 Post(s)
This. And the fact that your computer says it can go up to 70hz is not necessarily what the tv can accept. As stated above, tv's normally will only accept a 60hz (or 24hz in some cases) signal. If the tv specs say it's a 120hz set, then it is.
sitlet is online now
Reply LCD Flat Panel Displays
