Suggestion for LCD Monitor Plus Sound Bar for Kitchen (Digital Cable) - AVS Forum | Home Theater Discussions And Reviews
post #1 of 1 Old 12-28-2012, 04:45 AM - Thread Starter
GTVic's Avatar
Parents currently have a ~16" 4:3 flat panel with terrible speakers sitting on a book case attached to a digital cable box. It is in a kitchen close to living room and dining room so the goal is to improve the display size and to significantly improve the audio to be useful beyond just a kitchen TV, without running wires and without clutter. Preferably around $500 budget.
Would like to replace this with:
- 24" 16:9 1080P LCD Monitor (cheaper than a small TV but need a recommendation since not all monitors would be suitable for TV)
- Sound Bar or similar
- Need to control volume with cable box remote or separate remote since LCD panel won't have volume
Nice options would be
- wireless streaming to the soundbar
- listen to digital cable music channels without the monitor being on
- OTA AM/FM
- CD Player (connect a portable unit or built-in)
Suggestions appreciated, thanks
GTVic is offline
Reply LCD Flat Panel Displays
