Should I buy LCD now or wait? Which is the best large size best value LCD? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 12-29-2012, 03:31 PM - Thread Starter
aznphatb0i's Avatar
Hey!
I'm in the market for a new LCD -- would like to get the largest display possible but bang for the buck as well
Currently looking at:
TCL LE55FHDF3300Z 55" @ $599.99
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=1913086
Vizio E601i-A3 60" @ $999.99
http://www.tigerdirect.com/applications/searchtools/item-details.asp?EdpNo=5246445
VIZIO E701i-A3 70-inch @ $1899.99
http://www.amazon.com/VIZIO-E701i-A3-70-inch-1080p-120Hz/dp/B009SJNTIY
The VIZIO 70" is pretty much 'out of my price range' as I would ideally not like to exceed ~$1200 but it's there as a slight possibility
Any advice / models I should take into account / good deals ---- and upcoming models of 2013 I should be waiting for instead of buying now?
aznphatb0i is offline
post #2 of 4 Old 12-29-2012, 04:15 PM
sitlet's Avatar
Quoted: 14 Post(s)
Out of those two, Vizio and TCL, I would 100% go with Vizio.
sitlet is offline
post #3 of 4 Old 12-29-2012, 05:06 PM
Devedander's Avatar
Quoted: 16 Post(s)
Liked: 36
I think 46 an d47 inch is the range that is offering the best value right now closely followed by 55 inch. 60+ is still running a pretty hefty premium over the lower sizes.
Truthfully the time to buy was BF when that 60 incher Vizio I think was going for $600... maybe head over to your local Best Buy and see if they have any good clearance ones... some 46-55 inch Samsung 3D panels have been going for $700-900 on clearance starting today.
Monster Gold Plated Optical Cables: http://monstercable.com/productPage.asp?pin=1263
Awesome user review: "Unreal quality. Sounded like I upgraded my speakers." :D
Devedander is offline
post #4 of 4 Old 12-29-2012, 05:49 PM
Mavinwow's Avatar
Quoted: 419 Post(s)
Liked: 488
prices will drop on this years models after CES in January if you want to wait
Samsung 55ES8000
Vizio 70 P Series, Calibration settings
CalMAN 5 Novice Walkthrough
Denon X4200, 5.1.4 setup
Mavinwow is offline
Reply LCD Flat Panel Displays
