Could samsung's 6900 series be superior to the 7100 series? - AVS Forum | Home Theater Discussions And Reviews
Old 12-30-2012, 04:48 PM - Thread Starter
winston9332's Avatar
Liked: 31
My usual bestbuy clearance aisle wandering led me to an open box samsung un50es6900 at an irresistible price. Few hours later, it was at home going head to head against my sony kdl46hx850 and samsung un46es7100.
Without any delay, i still would venture to say the sony is a better display for better black levels ( though inferior shadow detail than the 6900 ) and motion, but the 6900 is very, very close behind. Its black levels are not that far off the from the sony and even a dark room viewing experience is very close to the sony. Unfortunately, the 7100 is a distant third. It is lighter with worse motion. Viewing angles are better on the sony and 6900 too ( both admittedly suck compared to a plasma ).
So, is there something magical about these new 50" panels or is the 6900 simply a better set than the 7100?
--Picture menu
Mode: Movie
Backlight: 8
Contrast: 100
Brightness: 45
Sharpness: 0
Color: 54
Tint: G50/R50
Screen adjustment submenu:
Picture Size: Screen Fit
Position: [no change]
Auto Adjustment submenu: [Grayed out]
3D submenu: N/A
Advanced settings submenu:
Dynamic contrast: Off
Black tone: Off
Flesh tone: 0
RGB Only Mode: Off
Color space: Custom
White Balance: [see below]
10p White Balance: On
Gamma: +1
Expert Pattern: Off
xvYCC: Off
Motion Lighting: Off [grayed out]
Color Space submenu:
Color Space: Custom
Red: Red 76, Green 0, Blue 0
Green: Red 01, Green 50, Blue 0
Blue: Red 0, Green 05, Blue 50
Yellow: Red 95, Green 74, Blue 0
Cyan: Red 0, Green 50, Blue 50
Magenta: Red 50, Green 0, Blue 41
White balance submenu:
R-Offset: 25
G-Offset: 25
B-Offset: 25
R-Gain: 25
G-Gain: 25
B-Gain: 23
Picture options submenu
Color tone: Warm2
Digital Noise Filter: Off
MPEG Noise Filter: Off
HDMI black level: Normal [grayed out]
Film mode: Off: [grayed out]
Auto Motion Plus: Off
LED Motion Plus: On
winston9332 is offline
Old 01-01-2013, 11:20 AM - Thread Starter
Liked: 31
Had the 6900 up for the past few days and have really enjoyed. Cant get quite as black as the sony, but good tv. If anyone is interested, i will post settings
Old 01-02-2013, 05:03 AM
drprime's Avatar
Hi guys! I have some questions about this TV.
Does anybody know if this Tv mounts Spva panel in the 50" inch version? and 46" inch?
The panel is Ultra Clear (glossy) like the es7000 and es8000 series?
What about clouding and banding in this model?
Thank you
drprime is offline
Old 01-02-2013, 08:00 AM
greyjack's Avatar
Do you game at all?
If so, whats the input lag on those tvs compared to each other.
thanks
greyjack is offline
Old 01-02-2013, 12:47 PM - Thread Starter
Liked: 31
Thank you
6900 is a glossy matte akin to the 6500
no clouding with back light below 15 (max 20). mild clouding when cranked high.
minimum banding (my sony kdl55hx850 has worse).
Liked: 31
Thank you
Sorrry - no gaming
Old 01-02-2013, 06:19 PM
draw3d's Avatar
Winston, I just bought the es6900, can you post your settings please. Thanks!
draw3d is offline
Old 01-04-2013, 06:49 PM - Thread Starter
Liked: 31
Will do thisweekend
Old 01-05-2013, 09:02 AM - Thread Starter
Liked: 31
picture settings posted on first post.
Old 01-05-2013, 05:47 PM
greyjack's Avatar
I checked it out, and the 6900 comes in a 46" version....
It looks like they're a newer model as well releasing in sep compared to the jan release of the 7100.
So maybe the build quality is affected.
Also I love the chrome finish on the 6900.
Was it cheaper then the 7100 for you?
greyjack is offline
Old 01-05-2013, 08:21 PM - Thread Starter
Liked: 31
There was a 46d6900, but only a 50es6900 amd 55es6900 this year i believe
Old 01-05-2013, 09:46 PM
greyjack's Avatar
http://www.amazon.co.uk/Samsung-UE46ES6900-LED-Smart-Silver/dp/B008F6AYU2
and if you have a look at this video, you will see its dated sep at some sort of convention
http://www.youtube.com/watch?v=Vld_6r29u8U
greyjack is offline
Old 01-06-2013, 06:52 AM - Thread Starter
Liked: 31
Dont think it was released in the us...maybe a uk/eu only deal...
Old 01-06-2013, 09:35 AM - Thread Starter
Liked: 31
Comparison pic of 6900 and sony 850
Old 01-06-2013, 05:47 PM
Tom Bley's Avatar
Quoted: 593 Post(s)
Liked: 529
You watch your tv's in the vertical position? Cool! So do I! I didn't think anyone else did this.
Tom Bley is offline
Old 01-06-2013, 05:59 PM
greyjack's Avatar
You can really see the blacks on the sony shine.
Did you calibrate the panels? Or are they just at stock
Thanks for taking the pics though, that's awesome
greyjack is offline
Old 01-07-2013, 07:09 AM - Thread Starter
Liked: 31
The panels are calibrated, though amateurishly. The HX850 is using CNET's settings. The 6900 is using my settings above.
Please note there is some ambient light in the picture; while the 850's filter is more reflective, it does look darker, which helps perceived black levels.
Old 01-09-2013, 07:25 PM
draw3d's Avatar
Finally got around to calibrating my tv with your settings, thanks again!
draw3d is offline
Old 01-12-2013, 07:15 AM
piko111's Avatar
winston9332 draw3d .I just bought the 50es6900, can you post your settings please. Thanks! tv is perfect but something i am doing wrong with calibrating. eek.gif
piko111 is offline
Old 01-12-2013, 04:41 PM - Thread Starter
Liked: 31
Above in first post of thread
Old 03-03-2013, 07:57 PM
wrahn's Avatar
Winston 9332,
Thanks for your input. I currently have the UN46ES7500, and the picture is excellent. However, It's in a bright lite area and I get lots of reflection from the screen. Therefore, I plan on buying the UN50ES6900 because it has the semi-matte screen, and see how it works in the same room. If the picture is excellent and the reflection less, I'll keep the 6900. Then I'll use your calibrations.
Based on your observations, what is your evaluation of the 6900 reflections?
Once again, thanks for your inputs,
Wes
wrahn is offline
Old 03-26-2013, 04:02 PM
atct86's Avatar
I have seen a bunch of the 50es6900 for sale locally. I really like them for the thinner bezel, and cost savings vs a 7100. What are the key differences?
atct86 is offline
Old 03-26-2013, 07:07 PM
The Grim Reaper's Avatar
I am thinking I am going to order the 6900 in the 55 inch from Best Buy here in KC
The Grim Reaper is offline
