Sharp Aquos digital audio question - AVS Forum | Home Theater Discussions And Reviews
post #1 of 10 Old 01-01-2013, 07:23 PM - Thread Starter
sguthrie's Avatar
So my old TV finally died, so I went out about bought a Sharp Aquos LC-60LE600U. I've done from the digital audio output into my reciver, but it doesn't seem to be getting any signal. Is there a setting I'm missing to tell it to use the digital audio rather than the TV's speakers?
Try not. Do, or do not. There is no "try".
sguthrie is offline
post #2 of 10 Old 01-01-2013, 09:51 PM
Hi Deaf's Avatar
Quoted: 18 Post(s)
Liked: 30
The digital audio out only works with apps like Netflix and Vudu. Use your cable or Sat box for DD 5.1.
Sony 940E / Sony X800 / DTV 4K / Denon / Klipsch
Hi Deaf is offline
post #3 of 10 Old 01-01-2013, 11:10 PM
8traxrule's Avatar
The setup of this TV is rather confusing. To enable the digital audio output, you need to select "Terminal Setting"- there will be a choice for PCM or bitstream, you will want to set it to Bitstream. Then there is a setting for "Fixed" or "Variable", you will want to set it to whichever one isn't the default in order to turn off the TV's crappy built-in speakers.
8traxrule is offline
post #4 of 10 Old 01-03-2013, 05:16 PM - Thread Starter
sguthrie's Avatar
That stinks...I was hoping I could plug it in to my reciver but still use the TV's volume control. I'm surprised my set even has the output, since it's not a smart TV with all the aps.
sguthrie is offline
post #5 of 10 Old 01-04-2013, 06:00 AM - Thread Starter
sguthrie's Avatar
Ok, so an other question.
I'm thinking of getting some speakers or a sound bar I could use the standard (red / white) audio connectors on so I could listen through them and control the volume with the TV's volume control.
Does anyone know how (or even if) I can set the TV speakers off and pump the output through these connectoins?
sguthrie is offline
post #6 of 10 Old 01-04-2013, 11:22 PM
8traxrule's Avatar
Most HD TV stations broadcast in Dolby Digital 5.1, you can get that with the digital output. You can't use the TV's volume control with it since the digital bitstream is output at a fixed rate. I wouldn't use mine anyways since the volume indicator on the screen annoys me. You can output a variable rate in 2-channel with the analog outputs.
post #7 of 10 Old 04-09-2017, 04:01 PM
Liked: 0
I have a Sharp Aquos LC-60LE650U and got an HTS3450/37 Phillips theater system, got the red and white components hooked to the back of the TV NOT In the Video ports but the two second from the bottom in their respective ports... I have NO audio output whatsoever when changing to PCM OR BitStream, and either Fixed or Variable output, in Netflix OR Pandora, or anywhere else for that matter....
Can I get some assistance?
Sean Feehan is offline
post #8 of 10 Old 04-09-2017, 04:04 PM
BiGx5MurF's Avatar
Quoted: 16 Post(s)
Liked: 1
I have an older sharp aquos in my bedroom with the same issue. Using a pioneer AVR that only has optical inputs. I ended up using a HDMI audio extractor to output optical into AVR.
BiGx5MurF is offline
post #9 of 10 Old 04-09-2017, 04:08 PM
Liked: 0
This unit doesn't have Optical either, it has component, and S-Video... Any other thoughts?
post #10 of 10 Old 04-09-2017, 07:37 PM
BiGx5MurF's Avatar
Quoted: 16 Post(s)
Liked: 1
component will ultimately be capable of higher resolution, and would be preferable.
Reply LCD Flat Panel Displays
Sharp Lc60le600u Led Hdtv
