What models are back lit local dimming? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 8 Old 01-03-2013, 12:10 PM - Thread Starter
Mopar_Mudder's Avatar
Quoted: 27 Post(s)
Liked: 37
I am trying to research a new TV and am finding it hard to see what models are back lit LED with local dimming. You would think that the manufacture web sites would state that feature.
I am looking mainly in the Samsung & Sony lines
I see now that the Sony is only the XRB line, they are too large and too high priced, so Sony is out.
Mopar_Mudder is offline
post #2 of 8 Old 01-03-2013, 02:26 PM
1000's Avatar
Quoted: 44 Post(s)
Liked: 35
I think you will find that only the high end Sony panel and the Sharp Elite panels have backlit tech with local dimming. Some of the vanilla Sharp panels are also backlit but no local dimming as far as I know. It seems most are turning to the edge-lit panels as I assume they are cheaper to make.
1000
1000 is offline
post #3 of 8 Old 01-03-2013, 02:29 PM
Apostate's Avatar
Quoted: 100 Post(s)
Liked: 134
Just to note that there is a difference between full array LED and direct LED (backlit LED). Full array LED is the fancy kind that high end Sony and Sharp Elite use.
Direct or backlit LED is like regular LCD except with LED instead of CCFL lighting. Direct LED is the thick kind and is usually cheaper than edge lit LED.
All three flavors may or may not come with local dimming.
Apostate is offline
post #4 of 8 Old 01-03-2013, 02:39 PM
6athome's Avatar
Quoted: 522 Post(s)
Liked: 159
in 2012 LG had two local dimming led nano TV'S .the LG LV9500 and LM9600. The LV was active 3D and the LM9600 has passive 3D.
6athome is offline
post #5 of 8 Old 01-03-2013, 03:06 PM - Thread Starter
Quoted: 27 Post(s)
Liked: 37
Thanks for the replys. Would be nice if they just gave the real specs on these thing, guess most people just don't care when they get them.
Any of the Samsung models that are NOT edge lit and have local diming?
post #6 of 8 Old 01-03-2013, 03:40 PM
rickie's Avatar
The Vizio M3D651SV aslo has local dimming, though it is an edge lit LED.
Rick
rickie is offline
post #7 of 8 Old 01-03-2013, 04:03 PM
8mile13's Avatar
Quoted: 1752 Post(s)
Liked: 1025
There is Full Array Local Dimming and there is Edge Lit Local Dimming
http://reviews.cnet.com/2795-6482_7-399.html
There are no Samsung Full Array Local Dimmings any more , last one was the 2009 UNXXB8500.
In general the Full Array Local Dimmings are the most expensive LEDs (only 4K Edge Lit LEDs are more expensive)
2012 Full Aray Local Dimmings, most of them
http://www.avsforum.com/t/1365130/full-array-led
older full Array Local Dimming list and benefits
http://www.avsforum.com/t/1245172/unofficial-local-dimming-list-and-benefits
8mile13 is offline
post #8 of 8 Old 01-04-2013, 12:43 PM
Apostate's Avatar
Quoted: 100 Post(s)
Liked: 134
Doesn't look like it. From what I saw at Amazon, Samsung offers ES and EH series HDTVs. ES is the edge lit LED (thin kind). EH is the direct (backlit) LED (thick kind) and is the lower line.
Local dimming is only offered on upper ES series.
Apostate is offline
Reply LCD Flat Panel Displays
Lg Electronics 84lm9600 84 Inch Uhd 4k
