Budget led-lcd - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 01-04-2013, 05:39 PM - Thread Starter
bliip's Avatar
I just bought a 40" Sharp LC-40LE433U for my living room from BestBuy for $449.00 + tax . The size is perfect, but the picture is not as sharp as I thought it should be even after tweaking. I use it for general broadcasts of sitcoms, dramas and documentaries. All movies, games and sports are watched on a much larger better tv in the basement. I watch tv directly in front of the unit and mostly in the evening when it is dimly lit at about 7' -9' away. I do not need internet on this unit. I have a very limited budget and want to know if I will be more satisfied with the picture on this Samsung UN40EH5000 from Crutchfield for $549.99?
bliip is offline
post #2 of 2 Old 01-04-2013, 11:55 PM
sitlet's Avatar
Are you watching HD cable?
Honestly, at 7-9 feet away on a 40-42 inch set, you aren't going to notice much of a difference. I can't say what the difference in those two particular sets would be, but I can't see how they would be too different.
sitlet is offline
Reply LCD Flat Panel Displays
