LG6700 and firmware update hangs..... - AVS Forum | Home Theater Discussions And Reviews
post #1 of 1 Old 01-05-2013, 09:10 AM - Thread Starter
poppop's Avatar
[SIZE=4]Trying to upgrade firmware and it just ain't downloading.Possibly I'm not doing it correctly using my Netgear wireless so I hooked it up directly using the LG's RJ45 input with same results.I've hooked up the tv to my cable box using only the HDMI output...no 75 Ohm cable....assuming the updates come thru the LAN and not the cable or am I wrong? Any thoughts or input is appreciated.
I did speak with LG this am and went thru the disconnect and reconnect all with no results.[/SIZE]
poppop is offline
Reply LCD Flat Panel Displays
