vizio xvt553sv need to warm up to stay on. - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 01-07-2013, 10:59 AM - Thread Starter
bigrick7's Avatar
My Vizio XVT553sv suffered a power surge it would not turn on at all. I changed the power supply board and the motherboard. the TV does turn on at first with freezing video and sometimes the sound goes out . after about 1 or 2 minutes it turns back off the Vizio logo blinks. then tv turns back on again every so often it does this process twice. after cycling like this it usually stays on until turned off. what I do now is turn on the TV without a video source turned on for about 5 minutes then I turn on the video source the TV works good after doing this. I'm guessing one of the boards has a problem any help would be appreciated. thank you in advance.
bigrick7 is offline
post #2 of 4 Old 01-08-2013, 04:21 AM
videobruce's Avatar
Quoted: 608 Post(s)
Liked: 247
1. Where did you get the boards from?
2. Do you have a Service Manual?
Free, abundant OTA television separates this country from many others. ATSC1 has only been in force since 2009. The wireless industry has enough spectrum. Enough of 'planned obsolesce'.
videobruce is offline
post #3 of 4 Old 01-08-2013, 09:51 AM - Thread Starter
bigrick7's Avatar
I purchased the boards from an ebay seller that sells boards on a regular basis. also no i don't have the service manual.
bigrick7 is offline
post #4 of 4 Old 01-08-2013, 09:56 AM
videobruce's Avatar
Quoted: 608 Post(s)
Liked: 247
I would ask him if he can get a manual for you unless you can do so from Vizio. I wouldn't work on anything as this w/o a manual.
Reply LCD Flat Panel Displays
