OFFICIAL Samsung Smart TV "Evolution Kit" Thread - Page 52 - AVS Forum | Home Theater Discussions And Reviews
 41Likes
post #1531 of 2267 Old 05-18-2014, 06:27 PM
DaJoJo's Avatar
Quoted: 355 Post(s)
Liked: 784
Originally Posted by poppagene View Post
Skype isn't working for me with the SEK-2000. Either try to make a call or answer a call, the screen goes to connecting and never connects.
edit:
Back to the SEK-1000/ZA untill they fix the Skype and Netflix apps
thnx for update. i had that too one time.. u could try and wait till u got everything updated on the sek-2000 and remove both apps then reset the smarthub and turn off and on the tv and re-install both apps after that. sometimes its a network error or app get screwed up due to smarthub update.
today i found myself without wireless connection on the tv and i had to plug in the network cable in the end. sometimes it finds wireless but won't connect and sometimes it will give hardware address of 00:00:00:00:00:00 , it misses 5ghz wifi ap's .. clearly something bugging in the firmware.
Klipsch fronts 2xRF-82-II 150W 33Hz-24KHz , center RC-64-II 200W 59Hz-24KHz , sides 2xRS-62-II 150W 50Hz-24KHz , rears 2xRB-81-II 150W 44Hz-24KHz , heights 2x Salora T25i
Yamaha RX-A3040, SVS PB13-Ultra 1000W 14-200hz
4 mm el cheapo wire / Samsung UE-ES8000S TV+evo 2014 / Optoma DH-1015 Sony PS3
DaJoJo is offline
post #1532 of 2267 Old 05-18-2014, 06:31 PM
DaJoJo's Avatar
Quoted: 355 Post(s)
Liked: 784
Originally Posted by SAM22063 View Post
So it is pure waist or should I hope for a firmware download for my US purchased EVO KIT that will make it work with my  European UE55ES8000S
its not gonna work due to different hardware used . but you could try update tv to latest firmware then attach evokit (tv unplugged from mains if u do this) then in support menu update firmware online. skip the usb question and make sure it's online before turning on tv. case of wireless make sure it connected before. or go usb route, then u need the evokit euro firmware on usb.
DaJoJo is offline
post #1533 of 2267 Old 05-18-2014, 07:22 PM
Ldc2335's Avatar
Available for pre-order on Amazon. Also Amazon seller says they have a few in Stock. I call bs.
I pre-ordered through Amazon, easy returns if I have issues.
Sent using Tapatalk for Android.
Ldc2335 is offline
post #1534 of 2267 Old 05-19-2014, 08:17 AM
CannonC's Avatar
Quoted: 48 Post(s)
Liked: 31
Originally Posted by priuscat View Post
Sparco has four SEK-2500UZ/A's available as of May 15, 2014
http://www.sparco.com/cgi-bin/wfind2?spn=A8WT577#.U3UcN_ldWmc
Have you received it yet? I'm curious to some who has purchased this on the performance and feedback on it.
2013 UN65F9000, 2015 SEK-3500U/ZA OCB
2013 PN51F8500
CannonC is offline
post #1535 of 2267 Old 05-19-2014, 08:21 AM
priuscat's Avatar
Quoted: 395 Post(s)
Liked: 176
Not yet,I should receive it Wednesday,I will post my results with it then
UN65JS8500FXZA and UBD-K8500/ZA
Slim Port Nano Console
UHD Content CY-SUC05SF/ZA WD Western Digital My Passport Cinema
UHD Video Pack CY-SUC10SH1/ZA Tivo Bolt Roku 4
Sennheiser RS175 Digital Wireless Headphone System
Etekcity 4K x 2K 4 Port High-Speed HDMI Switch 4 Port USB 3.0 Hub
priuscat is offline
post #1536 of 2267 Old 05-20-2014, 05:38 AM
goldbergfan's Avatar
Hi guys first post on here anyway I have been watching this thred for sometime and just found where to get the Kit in the UK I just got mine today from Currys Pc World
http://www.currys.co.uk/gbuk/tv-dvd-blu-ray/tv-accessories/smart-3d-tv-accessories/samsung-sek-2000-2014-evolution-kit-10004765-pdt.html
goldbergfan is offline
post #1537 of 2267 Old 05-20-2014, 08:57 AM
swt8408's Avatar
Hey I wanted to know if anyone who now has the SEK-2000 has been able to download and use Netflix? I was going to buy one today but I won't if Netflix isn't available. I read here that someone installed it in their TV and then removed it because netflix wasn't available. I would rather wait to purchase mine when Netflix is available for download than have it sitting at home collecting dust and hoping for an update from Samsung to fix the issue.
swt8408 is offline
post #1538 of 2267 Old 05-20-2014, 02:04 PM
Sorry NO netfix on mine . Well all was going great it found the kit it installed drivers then it updated them then updated TV drivers all took about 15 mins then it took me about 30 mins to set the tv up the way I like it so far so good . Then the problems started frown.gif while switching channels the tv froze then turned off and back on it then started the driver updates all again so far it have done this 2 times I also have had a black screen had to restart tv. Ok I am sure they will fix these things well lets hope they do have to say for the money I am a bit disappointed oh well lets see what the future brings
post #1539 of 2267 Old 05-20-2014, 04:26 PM
poppagene's Avatar
Quoted: 665 Post(s)
Liked: 478
Is the skype working for you? I was able to download it, but it wouldn't complete an outgoing call (or even the free test call).
UN48JS8500 UN55HU6950 w/SEK-3500U UN40HU6950 w/SEK-3500U UBD-K8500 UN37C5000
poppagene is offline
post #1540 of 2267 Old 05-20-2014, 04:51 PM
skype was pre installed and works on the test call sorry but not tested it on outgoing calls yet
post #1541 of 2267 Old 05-20-2014, 04:55 PM
At last I can post Pics :)
Damien Inferno likes this.
post #1542 of 2267 Old 05-20-2014, 05:28 PM
bedBug's Avatar
Does anyone know when the new one connect box will be available in Canada for f9000? And where I could order it? Or even if anyone knows the model number so I can google it.
bedBug is offline
post #1543 of 2267 Old 05-20-2014, 05:32 PM
priuscat's Avatar
Quoted: 395 Post(s)
Liked: 176
For the F9000 the model number for the one connect box is SEK2500UZ/A for Canada the "UZ/A" may be different. Check with Sparco, their phone number is 800-840-8400
priuscat is offline
post #1544 of 2267 Old 05-20-2014, 05:33 PM
DaJoJo's Avatar
Quoted: 355 Post(s)
Liked: 784
Originally Posted by bedBug View PostDoes anyone know when the new one connect box will be available in Canada for f9000? And where I could order it? Or even if anyone knows the model number so I can google it.
same as the sek1000 kit, just put 2500 instead of 1000 to google it
DaJoJo is offline
post #1545 of 2267 Old 05-20-2014, 05:36 PM
bedBug's Avatar
Thanks for the quick replies you guys are the best!! I'll check it out.
bedBug is offline
post #1546 of 2267 Old 05-21-2014, 03:42 AM
poppagene's Avatar
Quoted: 665 Post(s)
Liked: 478
A Canadian e-tailer:
http://www.ncix.com/detail/samsung-sek-2500u-za-evolution-kit-one-1c-95600-1540.htm
post #1547 of 2267 Old 05-21-2014, 03:52 AM
pettern's Avatar
Quoted: 95 Post(s)
Liked: 38
For those living in Norway, the ZG model will be available in around 2 weeks time. See for http://www.prisguide.no/produkt/samsung-evolution-kit-sek-2500u-205473 for retailers.
pettern is offline
post #1548 of 2267 Old 05-21-2014, 05:19 AM
Nice pictures. How about getting a scan of the manual and specs? Everyone here seems to be in such a rush to buy something "sight unseen". With no specs on any of the global Samsung sites, and nothing much listed on the e-retailers sites, I would find it hard to lay the money down not knowing what this new Evo-Kit improves upon.
Frank
Samsung UN46ES8000F TV, Samsung WMN350M mini wall mount, Samsung VG-KBD1500 bluetooth keyboard, Samsung HT-E6730W home theater
Highland Logan is offline
post #1549 of 2267 Old 05-21-2014, 05:40 AM
Hi Frank
Sorry to say but there is not much information in the kit and the writing is so small anyway have a look for yourself hope this helps
post #1550 of 2267 Old 05-21-2014, 06:45 AM
Thanks for that.
So just an install manual, no real info on what systems and services update, and which ones do not?
Frank
post #1551 of 2267 Old 05-21-2014, 08:44 AM
Otto Pylot's Avatar
Quoted: 1530 Post(s)
Liked: 959
That's the biggest problem I see with these Evo kit updates. It's a great idea to keep your purchase at the current technologies but they need to explain what they exactly are offering. Especially with the new HDMI 2.0 specs. There's a lot of smoke and mirrors that some of the mfrs are playing with in regards to HDMI 2.0 and it would be nice to see exactly what your $400 or what ever is really getting.
Otto Pylot is offline
post #1552 of 2267 Old 05-21-2014, 01:11 PM
Now to be fair, for the SEK-1000 there was a lot of information on what was updated, and what would not carry over from the 2013 SH to the 2012+EK. All of this was on the Samsung site, but for the SEK-2000, it seems that have allowed some companies to sell it before the specs were released. I get that some distributors have gotten a special deal to sell before it hits the rest of the stores, but they could of at least still published the info.
But I suppose, why bother... it seems a lot of people are willing to buy sight unseen.
Me, however... I need to know what it will do, before I buy. I wasn't too impressed with what the SEK-1000 would do for me, so I figured I would wait. Looks like I will have to wait a bit longer. It is only a 2012 TV, after all. Hell I may just wait till the 2016 EK gets released.
Frank
post #1553 of 2267 Old 05-21-2014, 01:58 PM
Otto Pylot's Avatar
Liked: 959
+1
post #1554 of 2267 Old 05-21-2014, 02:29 PM
priuscat's Avatar
Quoted: 395 Post(s)
Liked: 176
Well my SEK2500UZ/A is DOA. When connected the tv image shows a flat screen tv in the center of screen and the one connect box to the right center with the one connect cable between the two with the connector plugs motioning to connect to the tv and box.
priuscat is offline
post #1555 of 2267 Old 05-21-2014, 02:40 PM
CannonC's Avatar
Quoted: 48 Post(s)
Liked: 31
Sorry to hear this. That sucks! Do you think it's because it needs a firmware update? Keep us posted. what a bummer
2013 PN51F8500
CannonC is offline
post #1556 of 2267 Old 05-21-2014, 04:32 PM
Ldc2335's Avatar
I should get my sek-2000 from Amazon on the 28th. I'll be sure to report success(or failure) with my 65f8000.
Ldc2335 is offline
post #1557 of 2267 Old 05-21-2014, 04:45 PM
priuscat's Avatar
Quoted: 395 Post(s)
Liked: 176
There's no way to do a firmware update because the TV screen only shows the image of the cable trying to connect. Nothing on my remote works except on/off. BTW the latest firmware with the original one connect box is 2007.3 and was told by the Samsung "Experts" that that's the latest version.
priuscat is offline
post #1558 of 2267 Old 05-21-2014, 05:13 PM
priuscat's Avatar
Quoted: 395 Post(s)
Liked: 176
Here's a photo of what I get. When connected to my SEK2500UZ/A
priuscat is offline
post #1559 of 2267 Old 05-21-2014, 05:36 PM
DaJoJo's Avatar
Quoted: 355 Post(s)
Liked: 784
they finally list the sek-2000XC/2500UXC here in netherlands.. unknown deliverydate though
sek-2000 249 €
sek-2500U 338,39 €
EAN Code : 8806086096515
2000:
  • Update to 2014 Smart HUB
  • New Smart TV posibilities (voice and gesture improved)
  • Quad Core Plus processor
  • 4 years of software updates
EAN Code : 8806086112741
2500U:
  • HDMI 2.0
  • Update to 2014 Smart Hub
  • Quad Core Plus Processor
DaJoJo is offline
post #1560 of 2267 Old 05-21-2014, 05:45 PM
sangnas's Avatar
Quoted: 17 Post(s)
You need to do the update with the old box plugged in first.
sangnas is offline
Reply LCD Flat Panel Displays
Samsung 46 Led Smart Tv , Samsung , Led Hdtv , Samsung Un46es8000 Led Hdtv , Samsung 75 Inch Led Smart 3d Hdtv Un75es9000
