OFFICIAL Samsung Smart TV "Evolution Kit" Thread - Page 58 - AVS Forum | Home Theater Discussions And Reviews
 41Likes
post #1711 of 2265 Old 06-24-2014, 07:22 AM
chenrikson's Avatar
Quoted: 12 Post(s)
Originally Posted by USMCj View Post
No. Sek2000 equipped tv's use the smart view 2.0 app instead.
So it follows that the remote supplied with the SEK-2000 is not the same as that supplied with "H" series sets, right?
chenrikson is offline
post #1712 of 2265 Old 06-24-2014, 07:46 AM
USMCj's Avatar
I'm not sure which remote comes with the H series. If the h series is a 2014 smart tv, then it should come with the same remote as the sek2000.
USMCj is offline
post #1713 of 2265 Old 06-24-2014, 01:13 PM
poppagene's Avatar
Quoted: 602 Post(s)
Liked: 381
The remote that comes with the SEK-2000 is similar to the bluetooth remote that ships with H series LED tvs. The remote also works with the SEK-1000 although the functionality is a bit different. As to universal remotes, My tivo remote was programmed to turn the ES7500 on and off and to control the volume and this function works both without either evolution kit as well as with eithet SEK-1000 or SEK-2000 installed. I can't speak to other universal remote features. I also do not have an Ipad and can't speak as to the functionality of using an Ipad with the SEK-2000, SEK-1000 or without either.
poppagene is online now
post #1714 of 2265 Old 06-25-2014, 12:16 AM
DaJoJo's Avatar
Quoted: 355 Post(s)
Liked: 783
on/off and volume works with IR remote on all versions. the networkbased tvremote for 3rd party devices control works also on my es8000 with evokit if you have the old samsung remotehub connected.
still no sign of evokit 2000 here in netherlands.. according to samsung they're still working on the firmwarebugs and won't ship it untill that is solved.
Klipsch fronts 2xRF-82-II 150W 33Hz-24KHz , center RC-64-II 200W 59Hz-24KHz , sides 2xRS-62-II 150W 50Hz-24KHz , rears 2xRB-81-II 150W 44Hz-24KHz , heights 2x Salora T25i
Yamaha RX-A3040, SVS PB13-Ultra 1000W 14-200hz
4 mm el cheapo wire / Samsung UE-ES8000S TV+evo 2014 / Optoma DH-1015 Sony PS3
DaJoJo is offline
post #1715 of 2265 Old 06-25-2014, 08:11 AM
chenrikson's Avatar
Quoted: 12 Post(s)
I note that some individuals are selling the "new" remote on eBay. Comments about the new remote seem to favor it over the remote that came with the SEK-1000 (and 2013 TV sets). I wonder if these remotes will work with the SEK-1000 or if there are 2 versions of the new remote ???
post #1716 of 2265 Old 06-25-2014, 10:24 AM
Quoted: 1392 Post(s)
Liked: 587
I can't seem to find one of the sek-2000 remotes on ebay.
Can you please link one.
TIA
JimP is offline
post #1717 of 2265 Old 06-25-2014, 03:09 PM
poppagene's Avatar
Quoted: 602 Post(s)
Liked: 381
TIA
The poster didn;t say they were pulled from a SEK-2000, but that the identical remote. The part number is RMCTPH1AP1.
http://www.ebay.com/sch/i.html?_trks...H1AP1&_sacat=0
post #1718 of 2265 Old 06-25-2014, 03:14 PM
priuscat's Avatar
Quoted: 395 Post(s)
Liked: 175
That's the same remote that came with my SEK2500U/ZA evolution kit for my UN55F9000 tv
UN65JS8500FXZA and UBD-K8500/ZA
Slim Port Nano Console
UHD Content CY-SUC05SF/ZA WD Western Digital My Passport Cinema
UHD Video Pack CY-SUC10SH1/ZA Tivo Bolt Roku 4
Sennheiser RS175 Digital Wireless Headphone System
Etekcity 4K x 2K 4 Port High-Speed HDMI Switch 4 Port USB 3.0 Hub
priuscat is offline
post #1719 of 2265 Old 06-26-2014, 06:36 AM
DaJoJo's Avatar
Quoted: 355 Post(s)
Liked: 783
only half.. tv power, volume up/down and channel up/down probably work, but to be able to use point n click it needs newer firmware and this firmware cannot be installed on a tv or tv+sek1000 as it is sek-2000 specific. however there is a chance it might work if it uses the bluetooth mouse input on the tv. i don't have my sek-2000 yet so i can't try it out, but i will when it finally get it.
DaJoJo is offline
post #1720 of 2265 Old 06-26-2014, 07:56 AM
chenrikson's Avatar
Quoted: 12 Post(s)
Thanks for the information -- I don't think I'll be buying the new remote w/o a SEK-2000 :-)
post #1721 of 2265 Old 06-26-2014, 08:36 AM
DaJoJo's Avatar
Quoted: 355 Post(s)
Liked: 783
welcome.. i think that would be best choice, but if you have a motion/voice controlled samsung like my es8000s then it might just work with this remote. perhaps you're better off waiting a bit until i or someone else tried the new remote on their tv or tv+sek1000. if u don't have a sek-1000 yet it is highly recommended to get a sek-2000 though.
DaJoJo is offline
post #1722 of 2265 Old 06-27-2014, 07:21 AM
USMCj's Avatar
Point and click and voice search do not work without the sek2000 evo box plugged in. I've tried it.
USMCj is offline
post #1723 of 2265 Old 06-27-2014, 08:10 AM
poppagene's Avatar
Quoted: 602 Post(s)
Liked: 381
Why wouldn't voice interaction work in exactly the same way as with the remote that comes with the sek1000? Did you enable voice commands in the menu and press the voice button on the remote before trying it? I'm just asking since I don't use the voice control and didn't test that out when I used the 2014 remote with the SEK-1000.
I agree that point and click doesn't work, but you can arrow up or down or across and click to select things. Otherwise the reomte seems to be fully functional. It's only the features that are specific to the 2014 smart tv models that don't work without the new evolution kit.
post #1724 of 2265 Old 06-27-2014, 08:15 AM
Quoted: 18 Post(s)
Liked: 1
Hey guys, I just picked up the F8000 model. Do i need to buy the new evolution kit for it...Besides upgrading the smart hub, does it do anything else like make picture quality better etc...
johnnyboy1988 is offline
post #1725 of 2265 Old 06-27-2014, 11:44 AM
dvdmd1's Avatar
Quoted: 30 Post(s)
Liked: 40
Don't waste your money on the evolution kit,it's not worth it.Just my own opinion from trying out 2 SEK-2000 kits
dvdmd1 is offline
post #1726 of 2265 Old 06-27-2014, 09:02 PM
theslydog's Avatar
sek-1000/za doesn't work on a EU tv.
edit: sek-2000/za aint gonna work either
Is this known for sure? I was hoping the units themselves were the same and just firmware differences as tuners are in the tv.
theslydog is offline
post #1727 of 2265 Old 06-29-2014, 04:24 PM
survivor's Avatar
My F8000 will be delivered this Wednesday. Have been wondering about the same thing myself. Let me know your feedback if you have gone with the SEK-2000 evo kit for your F8000.
survivor is offline
post #1728 of 2265 Old 07-01-2014, 08:16 AM
chenrikson's Avatar
Quoted: 12 Post(s)
I have an E8000 series plasma with the sek-1000. I don't use motion or voice control - ever. I found the sek-1000 worth every penny for the Smart interface and the much improved remote. I doubt that I'll spring for the sek-2000 -- but "There's always next year" :-)
post #1729 of 2265 Old 07-01-2014, 04:51 PM
OugaBooga's Avatar
OK, I have the es8000 but NEVER used the voice or motion control.I also don't use smart hub features other then browsing the net or you tube.I find things load slowly when web browsing & youTube from time to time just freezes when watching longer vids, more then 15-20min vids.
What are the differences between the 1st & 2nd evo kits OTHER then the remotes that I May be interested in.
Is there ANY features added that were removed from es8000 sets in the beggining & is there something added that helps sharpen/cripen/speed things up PQ wise.
I wasn't all that interested in the 1st evo since i heard more then enuff complaints plugging it in & tv's going bad/wonky.
THX in Advance.
SEK-2000/ZA....Any GOOD ?
OugaBooga is offline
post #1730 of 2265 Old 07-02-2014, 07:45 PM
DaJoJo's Avatar
Quoted: 355 Post(s)
Liked: 783
yes.
DaJoJo is offline
post #1731 of 2265 Old 07-02-2014, 07:53 PM
DaJoJo's Avatar
Quoted: 355 Post(s)
Liked: 783
me too.. the speed improvement alone was enough for me to get the sek-1000. the new interface and skype was the second reason. i'm just getting the sek-2000 coz i can sell my sek-1000 to a friend otherwise i would be seriously doubting buying the sek-2000 as i see no usable improvements over a sek-1000.
THX in Advance.
sek-2000 has same issues but samsung has an firmware update for that. most issues come from not updating the tv prior to installing the evokit and not following the correct steps. evokit is a nice thing to have as it speeds up your es8000 a lot and with the 2000 kit the youtube and webbrowser are a lot faster and more stable. also there are some nice new features for digital tv like the whats on tv and drawing the channelnumber on the remote pad and some other stuff. sek-1000 will make u happy, sek-2000 donno if that make u even happier.
DaJoJo is offline
post #1732 of 2265 Old 07-02-2014, 08:23 PM
gamermwm's Avatar
Quoted: 83 Post(s)
Liked: 93
THX in Advance.
I mostly use the Smart Hub for the highest resolution when using HBO Go & Netflix. They output in full 1080p via the Smart Hub, unlike game systems like the PS3/Xbox 360 which limit output for their video streaming apps to 720p upscaled
I'm still happily using the SEK-1000. I will eventually get the new SEK-2000 but I'm in no hurry until the price drops considerably or I snag a deal. I don't see it as a huge upgrade over what I already have
What is the meaning of life?
www.iamsecond.com/films
gamermwm is offline
post #1733 of 2265 Old 07-03-2014, 02:42 PM
tmatas's Avatar
Hi guys,
I have a 65F8000 and I'm thinking about buying SEK-2000. Can anyone check if Samsung added the option to switch between big and small picture in PIP (picture in picture) mode.
Without this PIP is pretty much useless for me (although I managed to program my Logitech harmony remote to make 4 clicks needed for enabling PIP)
tmatas is offline
post #1734 of 2265 Old 07-05-2014, 02:32 AM
DeathCom's Avatar
Has anyone tested input lag with the SEK-2000 with a PNxxF8500? The F8500s have some pretty serious lag and I really hope this kit will help get it to a respectable level (even the game mode trick is a bit under par).
Thanks to rckrz6 who ran some input lag tests with the first evo kit... though those results are extremely disappointing and leave me with little hope for the new kits...
Originally Posted by rckrz6 View Post
I was correct about the EVOKIT causing more input lag... I tested game mode with and without the evo kit compared to my computer monitor. 50 MS without EVO KIT 100 MS with EVO KIT.. I knew it wasn't in my head. I guess ill be hoping for better news for the 2014 kit
DeathCom is offline
post #1735 of 2265 Old 07-05-2014, 03:24 AM
mf26's Avatar
Originally Posted by tmatas View Post
Hi guys,
Yes, this still exists.
mf26 is offline
post #1736 of 2265 Old 07-06-2014, 01:35 AM
tmatas's Avatar
Sorry, I don't understand .
This option didn't exist before, so can you confirm that it exists now and is there a separate key for it on the new remote?
tmatas is offline
post #1737 of 2265 Old 07-06-2014, 06:35 AM
mf26's Avatar
See image below taken from a SEK2000, size existed on the ES8000 too. And no there is no separate PIP button on the new remote.
mf26 is offline
post #1738 of 2265 Old 07-06-2014, 01:52 PM
tmatas's Avatar
OK, I understand you now.
I was actually thinking about swapping the PIP windows (what was main picture (big one) goes to PIP (small one) and viceversa), and not changing their size.
But if there is not a separate button on the remote, I suppose this is not possible.
tmatas is offline
post #1739 of 2265 Old 07-09-2014, 07:54 AM
Liked: 0
Evo Kit SEK 2000 disables my bluetooth module
I have an ES8000 and Samsung just recently swapped my SEK 1000 for the SEK 2000 becuase I was having issues with my remote unpairing form the tv. Now with the SEK 2000, I'm having the same problem. I have double checked my remote and it is sending out a bluetooth signal because my phone can find the it. However, my tv 's bluetooth address isn't listed when I go intot he menu under contact samsung. I've reasearched this but can't find anyone else having this issue. If I take the evo kit off the tv and restart it, the bluetooth works just fine. Samsung keeps trying to replace the remote which I know isn't the issue. Not having bluetooth also doesn't allow me to us the 3D glasses. I have been going back and forth with Samsung for about 7 weeks now. Any suggestions?
Daver S is offline
post #1740 of 2265 Old 07-09-2014, 08:53 AM
poisike's Avatar
Quoted: 325 Post(s)
Liked: 96
I had a similar problem and it was a hardware problem with the TV. It was repaired once and when it failed again I refused a repair and asked for my money back. It seems that a lot of 2012 8 series TVs have a failing BT/WiFi chips.
scubascotland likes this.
Samsung UE65F9000ST + SEK-3500U/ZG (European firmware v1421.2)
Samsung UE78HU8500TX (European firmware v1290.2
poisike is offline
Reply LCD Flat Panel Displays
Samsung 46 Led Smart Tv , Samsung , Led Hdtv , Samsung Un46es8000 Led Hdtv , Samsung 75 Inch Led Smart 3d Hdtv Un75es9000
