OFFICIAL Samsung Smart TV "Evolution Kit" Thread - Page 59 - AVS Forum | Home Theater Discussions And Reviews
 41Likes
post #1741 of 2265 Old 07-14-2014, 12:22 AM
OugaBooga's Avatar
Originally Posted by poisike View Post
I had a similar problem and it was a hardware problem with the TV. It was repaired once and when it failed again I refused a repair and asked for my money back. It seems that a lot of 2012 8 series TVs have a failing BT/WiFi chips.
Maybe that's why the newer models don't have that es8000 BT dongle like thing for glasses any more..............just a thought.
Seems they figured it out & us 2012 owners are left with luck of the draw...........
I am scared using an evo kit will mess something up...........i really wouldn't mind getting the newer evo #2 but not feeling to confident in the way sammy handles problems.
SEK-2000/ZA....Any GOOD ?
OugaBooga is offline
post #1742 of 2265 Old 07-14-2014, 03:50 PM
mf26's Avatar
I see Amazon Instant is now up on the UK App Store for those that are interested. Just BBC iPlayer and 4OD to go then..
mf26 is offline
post #1743 of 2265 Old 07-15-2014, 04:43 AM
Liked: 0
Samsung UHD pack
I have Samsung UN65HU9000FXZA with Evolution Kit 2014 and got UHD Pack from Samsung, but unable to play it. Tv is recognize movies, but after few sec appearing message about unable to play um4 format. Tv software has latest updates. Any idea?
vadimzven is offline
post #1744 of 2265 Old 07-15-2014, 05:06 PM
p5browne's Avatar
Quoted: 2792 Post(s)
Liked: 2106
Remember. the FINAL 4K Specifications have not been arrived at yet! Why BD Players Manufacturers have been holding off. They don't want to put out a product that will be obsolete the day after tomorrow. Unfortunately, TV Producers aren't of the same mentality.
p5browne is online now
post #1745 of 2265 Old 07-18-2014, 06:39 AM
poppagene's Avatar
Quoted: 602 Post(s)
Liked: 382
The 2014 UHD Evolution Kit was designed for the 2013 TVs so uninstall it and go backto the one connect that came with your UN65HU9000FXZA.
poppagene is online now
post #1746 of 2265 Old 07-20-2014, 01:04 PM
Liked: 0
Does the SEK-2000 change the behaviour of the digital audio output at all?
The most annoying thing with my ES8000 is that I have to manually enable Dolby/DTS output every time I watch a video (in Samsung Link or other apps) which has it, because the TV always defaults to outputting stereo over SPDIF. So every time I have to do:
Menu -> Sound -> Additional Settings -> SPDIF output -> Audio Format -> then select Dolby Digital or DTS
dj1471 is offline
post #1747 of 2265 Old 07-21-2014, 12:50 AM
Cazador-'s Avatar
The best audio mode is:
PCM - Line
PCM is an uncompressed audio signal. The TV sends the original sound of the source to external speakers through SPDIF (optical) in correct format (Dolby Digital, DTS...). are the speakers or home cinema which decode the signal audio in their format original.
Cazador- is offline
post #1748 of 2265 Old 07-21-2014, 01:01 AM
poisike's Avatar
Quoted: 325 Post(s)
Liked: 96
PCM - Line
Samsung tvs only output 2 channel PCM.
To answer the original question, my SEK-2500U remembers that I selected DD, not sure about the SEK-2000.
Samsung UE65F9000ST + SEK-3500U/ZG (European firmware v1421.2)
Samsung UE78HU8500TX (European firmware v1290.2
poisike is offline
post #1749 of 2265 Old 07-21-2014, 10:45 AM
Liked: 0
Will the Evolution Kit work on a Series 6 Samsung tv model number UA60F6400. It does have provision for the kit at the back.
Festus Bella Goseb is offline
post #1750 of 2265 Old 07-21-2014, 01:44 PM
mjmbond's Avatar
Not sure if I understand your comment, but my HU8550 outputs DD 5.1 over ARC HDMI when watching movies with the Vudu app.
mjmbond is offline
post #1751 of 2265 Old 07-21-2014, 01:48 PM
poisike's Avatar
Quoted: 325 Post(s)
Liked: 96
Sure it does if you select dolby digital in sound menu. But if you select PCM it only outputs stereo.
poisike is offline
post #1752 of 2265 Old 07-21-2014, 02:13 PM
mjmbond's Avatar
Ok, understood
priuscat likes this.
mjmbond is offline
post #1753 of 2265 Old 07-23-2014, 01:16 PM
Liked: 0
I connected to original evolution kit SEK-2500U/ZA, which came with TV, but it doesn't want play UHD movies.
post #1754 of 2265 Old 07-24-2014, 03:30 PM
Liked: 0
So I just received my SEK-2000 and was installing it in my UN60ES8000, but I can't get the thing to work. I made sure the updates were applied before installing it, but nothing happens after I turn the tv on, no updates or anything. The current firmware version on my tv is 001054? Any ideas??? I tired taking it out and putting it back in at least 7 times but still nothing. Is there a way to tell if the unit is getting power? I guess I am trying to figure out is the unit bad or is it the tv causing the problem?
bcnul8tr is offline
post #1755 of 2265 Old 07-24-2014, 08:43 PM
p5browne's Avatar
Liked: 2106
Did you plug the SEK in with the Power Cord removed from the wall? If not, hopefully no damage was done. Try again with the Power Disconnected. Then put power plug back in. Still not working - try the Factory Reset in the Service Menu without the SEK.
(Remember, shutting the TV Off, is actually putting it into Standby Mode - in other words, it's still somewhat on.)
post #1756 of 2265 Old 07-25-2014, 03:32 AM
Cazador-'s Avatar
Smile Upgrade File(USB type) (Firmware) - 25-jul-2014
Any know is this versión is compatible with european model?
http://www.samsung.com/de/support/model/SEK-2000/XC
Firmware
Upgrade File(USB type) (Firmware) (ver.1.0)
  1. Title 2014 Evolution Kit Firmware
  2. Applicable Model SEK-2000
  3. Carrier or Corporate Customer for 2012 TV : T-ECPGAKUTfor 2013 TV : T-FXPGAKUC
  4. Description Version 1004.9
Date: 25-jul-2014 Language: ENGLISH Size:2549.86 MBhttp://www.samsung.com/us/support/ow...ct/SEK-2000/XM
Cazador- is offline
post #1757 of 2265 Old 07-26-2014, 09:23 PM
USMCj's Avatar
My PN60F8500 with 2014 SEK-2000 evo kit got a software update from ver 1002 to ver 1004 sometime last night.
Anyone know what's new in this version?
USMCj is offline
post #1758 of 2265 Old 07-27-2014, 10:08 AM
dancoh's Avatar
Hi. I have a 2013 65" UHD TV F9005. I just bought my evolution kit. Went home installed it. And things are weird. Netflix was there but dissapeared. Now I can't install it. Download.300. And then software update has a update that just seems to be repeating itself.The TV has update 1150. I know there is a 2221. And when I choose software update it starts directly at 89% goes to 100%. Shuts down and then on. But it is still on 1150. Using a USB to install 2221 does not seem to work. It does not ask me if I want to use the usb. It just goes straight to the internet to look for a update.
Anyone with similar problems?
dancoh is offline
post #1759 of 2265 Old 07-27-2014, 10:21 AM
priuscat's Avatar
Quoted: 395 Post(s)
Liked: 175
have you tried getting your answer here?
2014 Samsung SEK-2500U/ZA Evolution Kit and CY-SUC10SH/ZA UHD Video Pack
UN65JS8500FXZA and UBD-K8500/ZA
Slim Port Nano Console
UHD Content CY-SUC05SF/ZA WD Western Digital My Passport Cinema
UHD Video Pack CY-SUC10SH1/ZA Tivo Bolt Roku 4
Sennheiser RS175 Digital Wireless Headphone System
Etekcity 4K x 2K 4 Port High-Speed HDMI Switch 4 Port USB 3.0 Hub
priuscat is offline
post #1760 of 2265 Old 07-27-2014, 10:46 AM
Mrorange303's Avatar
Quoted: 1199 Post(s)
Liked: 355
Make sure the uhd pack is plugged into USB 3.
Mrorange303 is offline
post #1761 of 2265 Old 07-27-2014, 05:31 PM
priuscat's Avatar
Quoted: 395 Post(s)
Liked: 175
The UHD Content CY-SUC05SF/ZA that came complementary from Samsung will not play on TV's that have the SEK2500U/ZA connected. But the UHD Video Pack CY-SUC10SH/ZA will play with TV's having the SEK2500U/ZA connected. Whereas the UHD Video Pack CY-SUC10SH/ZA will not play with the original one connect box connected to the TV.
priuscat is offline
post #1762 of 2265 Old 07-27-2014, 06:22 PM
sikclown's Avatar
Quoted: 1377 Post(s)
Liked: 691
The current available update for the F9000 with the 2014 UHD Evolution Kit is 1150. 2221 is for the 2013 One Connect and will not install on the Evolution Kit.
UN65F9000AFXZA + SEK3500u/za firmware version 1461
Denon AVR-X7200WA, Apple TV, UBD-K8500, PS4, Xbox One, Nvidia Sheild Pro, PC
(2) Klipsch RF-82IIs, (4)RS-52IIs,, (1)RP-450CA, (4) RP-140SA, (1) SVS PB12-Plus
Emotiva XPA-100, XPA-200, Emotiva A-700
UN55KS9000 firmware 1132,Denon x4200w, Apple TV, Panny BDT460, PC,
Nvidia Shield, Klipsch G-42,(2) R-3650-W-II,(4) RSL-C34E, SVS SB-1000, UPA-200
sikclown is offline
post #1763 of 2265 Old 07-27-2014, 08:14 PM
p5browne's Avatar
Liked: 2106
UNPLUG the power cord from the Wall!!!!!
Please, do NOT plug in Evolution Kits with the Power Cord in the Wall!!!!
Turning the TV to Off, only means you're putting the set into STANDBY, NOT Actually OFF!!!!
post #1764 of 2265 Old 07-28-2014, 06:13 AM
Liked: 0
I have a hu7500, does anybody know if the video packs will work on a uk tv? samsung customer service say that it wont but if its just a video file i cant see the problem?
sherpa_man is offline
post #1765 of 2265 Old 07-31-2014, 12:48 AM
Liked: 0
Thumbs down SEK 2000 poor picture quality
I just installed SEK 2000 for my F8005 TV. I didn't expect much about the KIT it self, but I was hoping to get more power to web browsing. Okay, maybe the UI is slightly better than the original, but my biggest disappointment was picture quality! I understood from the product advertisement ("between the lines") that KIT may improve the picture quality, however in my case it got worse. All channels are more blurry then before (HD & SD cannels) same apply to recordings that I have made before installation. Has anyone experienced similar? or do you know how to get picture quality back at least same the level than before (not by removing the KIT).
Solikka is offline
post #1766 of 2265 Old 07-31-2014, 12:58 PM
mf26's Avatar
I see BBC iPlayer is now up for the SEK-2000, that just leaves 4oD.
mf26 is offline
post #1767 of 2265 Old 07-31-2014, 01:54 PM
poppagene's Avatar
Quoted: 602 Post(s)
Liked: 382
I haven't seen a similar issue, but some needed to re calibrate their picture settings after installing the upgrade. I suggest you reset your picture settings and go through the calibration / fine tuning again.
post #1768 of 2265 Old 07-31-2014, 08:03 PM
p5browne's Avatar
Liked: 2106
Have the Spears and Munsil 2 Blu-ray? Recalibrate your Sharpness settings.
post #1769 of 2265 Old 08-01-2014, 03:15 AM
Quoted: 57 Post(s)
Hi All,
Can anyone tell me if the one connect box controls the clear motion rate (1200),pur color,micro dimming, UHD dimming or is those features built into the panels? I see the new line up of 9000 series UHDs has upgraded specs in these categories . Will we be getting those kind of upgrades in the SEK2500 with our 2013 model UN65F9000? 1440 CMR, UHD dimming, pur color, wide color enhancer plus, auto depth enhancer,instant on,etc.
I see the un65f9000 has a SLIM LED panel and the new models label the panel "UHD 4K LED" are these the same panels and just named different?
Thank you for any input.
Bryscott is offline
post #1770 of 2265 Old 08-04-2014, 04:04 AM
Liked: 0
Some feedback. Unfortunately tuning the picture didn't help. I contacted Samsung service and we tired to update firmware by USB, but it was unsuccessful. They took remote connection to TV and tried to do something, no luck. Now, I could take the Kit back to store where they can test the functionality, if it works in some other supported TV:s. If they can't find any problems from the Kit, I can take my TV to service for check up. I am getting tired and ready to give up. I'll return the Kit back to store and spend the money in Soundbar. I hope that it will bring me some satisfaction after all.
Solikka is offline
Reply LCD Flat Panel Displays
Samsung 46 Led Smart Tv , Samsung , Led Hdtv , Samsung Un46es8000 Led Hdtv , Samsung 75 Inch Led Smart 3d Hdtv Un75es9000
