OFFICIAL Samsung Smart TV "Evolution Kit" Thread - Page 62 - AVS Forum
post #1831 of 1848 Old 10-26-2014, 06:36 PM
DaJoJo's Avatar
Quoted: 320 Post(s)
Liked: 763
glad u sorted it.
thing i hate most about this 2014 evokit is that they use different device security connection now and i can't use the remote prog on windows pc and my domotica and this nice android app https://play.google.com/store/apps/d...i.remote.phone anymore.
Klipsch fronts 2xRF-82-II 150W 33Hz-24KHz
center RC-64-II 200W 59Hz-24KHz
sides 2xRS-62-II 150W 50Hz-24KHz
rears 2xRB-81-II 150W 44Hz-24KHz
Yamaha RX-A3040, YST-SW800 Sub 1000W RMS 6 Ohm 18-170 hz / SVS PB13-Ultra 1000W 14-200hz
Audioquest 1.6mm wire / Samsung UE-ES8000S TV+evo 2014 / Sony Playstation 3/ AC PlayonHD2
DaJoJo is offline
post #1832 of 1848 Old 10-27-2014, 12:38 PM
thebignewt's Avatar
Quoted: 28 Post(s)
Liked: 26
Originally Posted by DaJoJo View Post
glad u sorted it.
I got mine n 2013, when the F8000 came out. If I had it to do all over again I wouldn't get it. It works OK, but doesn't add anything I need to the TV's function.
Samsung ES8000 65", Evo Kit installed, Yamaha AVR with Paradigm speakers, iMac, iPad, Apple TV and HTC One phone.
thebignewt is offline
post #1833 of 1848 Old 10-27-2014, 06:52 PM
DaJoJo's Avatar
Quoted: 320 Post(s)
Liked: 763
yeah the 2013 version is good as it is. not much trouble installing and works great with all apps. i do like the new remote on 2014 though and webbrowser improved but the rest is not that interesting and it makes it unnecesary difficult to browse media and to use PIP i have to go into the menu and the hdmi controls don't work that great. some menu options suck a lot also. using the touchless remote function by using hand is now using finger and sucks also as half of the time it don't work. i gave away my 2013 evokit as a present and i regret it allready, thinking im gonna buy a new 2013 and revert to that.
DaJoJo is offline
post #1834 of 1848 Old 10-28-2014, 02:25 AM
Liked: 0
In Watching regular TV Programming or live tv show. can we play, paise, rewind it? (freeview feature?
remfpage is offline
post #1835 of 1848 Old 10-28-2014, 02:27 AM
Liked: 0
Evolution kit sek-2000
remfpage is offline
post #1836 of 1848 Old 10-28-2014, 05:56 AM
Liked: 0
Samsung UN65F9000AFXZA & SEK-2500U/ZA
I own The UN65F9000AFXZA Version number: UD07
I purchased This 4K TV thinking it was 4K. My model is UN65F9000AFXZA. My picture looked so crappy. I later found out that the SEK-2500U was able to correct this issue. I purchased the SEK-2500U/ZA & followed all directions to the "T". It found an updated ver. when i started and the newest ver is 1172. The picture is a lot better, but now my motion control does not work...WTF? Is anyone else having similar problems? I even followed the directions to disable voice guidance. Still nothing. Can anyone kindly help cause the samsung support number that I called is very useless.
Prlauren is offline
post #1837 of 1848 Old 10-28-2014, 09:33 AM
DaJoJo's Avatar
Quoted: 320 Post(s)
Liked: 763
you tried turning on the tv and wait till it booted and then pressing both return and guide buttons on the remote for about 3-4 secs ?
DaJoJo is offline
post #1838 of 1848 Old 10-28-2014, 09:37 AM
poppagene's Avatar
Quoted: 12 Post(s)
You should also post in 2014 Samsung SEK-2500U/ZA Evolution Kit and CY-SUC10SH/ZA UHD Video Pack
poppagene is offline
post #1839 of 1848 Old 10-28-2014, 12:03 PM
Liked: 0
Yes I did. Cause I'm new here and I Posted in the wrong site to start. I relized I should have posted it here. So are we going to help or ride somebody for making a mistake?
Prlauren is offline
post #1840 of 1848 Old 10-28-2014, 12:06 PM
Liked: 0
Return & Guide Button
No I Didn't but I will try when I get home from work. Thanks for the input.
Prlauren is offline
post #1841 of 1848 Old 10-28-2014, 03:54 PM
DaJoJo's Avatar
Quoted: 320 Post(s)
Liked: 763
he is trying to help
DaJoJo is offline
post #1842 of 1848 Old 10-28-2014, 04:12 PM
poppagene's Avatar
Quoted: 12 Post(s)
I'm just saying that they may have more experience with your tv.
post #1843 of 1848 Old 10-29-2014, 02:00 AM
Liked: 0
Got the SEK-2000, the new remote doesn't work for me, I have the 55ES8000 and I think the bluetooth on my TV just dies.
I wouldn't recommend buying the kit, I get microstutters in Netflix, which I didn't before.
myst4ry is offline
post #1844 of 1848 Old 10-29-2014, 05:24 AM
Liked: 0
Yeah I tried the return & guide Button and it just paired the remote again. My problem is not with the remote it's with the camera and hand motion. It start's to work and then it doesn't. I shut off Voice control as recommended.
Prlauren is offline
post #1845 of 1848 Old 10-29-2014, 05:54 AM
poppagene's Avatar
Quoted: 12 Post(s)
Are you using wi-fi for netflix? new kit is fine for me for both netflix and amazon instant prime using wired network. As for the remote, there have been numerous postings on the failings of the bluetooth/wi-fi modules with or without the evolution kit. I don't know if they are on a combined module or on separate boards, but it may be that your netflix and remote problems have a related cause.
post #1846 of 1848 Old 10-29-2014, 03:29 PM
Liked: 0
Using wired, the problem is: audio has microstutters for like 0.1-0.3 seconds long, at sporadic moments. Kinda annoying because it sounds like a cut, missed packet or a pop. I also had a problem with the wired adapter for the EK not fitting well, and losing connection, piece of crap.
myst4ry is offline
post #1847 of 1848 Old 10-29-2014, 07:25 PM
DaJoJo's Avatar
Quoted: 320 Post(s)
Liked: 763
yeah i got the same issue with that finger-remote motion thing. voice control sucks too, it doesnt work most of time. also my wifi stopped working a while back. i think im gonna call the store and get them to fix it as it is clearly a factory fault.
DaJoJo is offline
post #1848 of 1848 Old Yesterday, 05:26 AM
Liked: 0
I had the old connect one box. The hand controls were different. You use to use your whole hand, now just a finger. It use to work to good until I connected the SEK-2500U/ZA. Now it doesnt work at all. I went to the test mode and it says my room is to dark. I tried it with all the lights on in the room and during the day with my shades open and it still says my room is to dark.The pointer on the remote works very good no issues with that at all.
Prlauren is offline
Reply LCD Flat Panel Displays
Samsung 46 Led Smart Tv , Samsung , Led Hdtv , Samsung Un46es8000 Led Hdtv , Samsung 75 Inch Led Smart 3d Hdtv Un75es9000
