OFFICIAL Samsung Smart TV "Evolution Kit" Thread - Page 64 - AVS Forum | Home Theater Discussions And Reviews
 41Likes
post #1891 of 2265 Old 11-27-2014, 12:58 PM
tman247's Avatar
Quoted: 56 Post(s)
Liked: 50
Originally Posted by pettern View Post
Why would the TV be required to decode the BD stream with h265? HDMI 2.0 and HDCP 2.2 I understand, but the codec requirement in the TV makes no sense. Where do you get this information from?
Fair point. I was more thinking of SmartTV's to be honest, where you might be streaming 4K. As long as the 4K BD player has HEVC support, and the TV has HDMI2.0 (or ideally, HDMI2.2) you should be ok. Difficult taking into consideration devices that could still be over a year away from becoming available.
tman247 is offline
post #1892 of 2265 Old 11-29-2014, 11:43 AM
GypsyDRB's Avatar
Quoted: 13 Post(s)
new firmware SEK-1000
Just updated to 1016. not sure what the fixes are...google wasn't helpful at this point.
GypsyDRB is offline
post #1893 of 2265 Old 11-30-2014, 03:59 PM
GypsyDRB's Avatar
Quoted: 13 Post(s)
Totally unscientific, but i pulled my sek-1000 out today...did the 1056 update, reset the tv, put the sek1000 back in...it updated to 1016, redid my settings and i swear my picture is better
/shrug.
GypsyDRB is offline
post #1894 of 2265 Old 12-03-2014, 12:05 PM
Liked: 0
I had the same below wifif issue with SEK-1000. Samsung sent me a new SEK-2000 as they couldnt fix the issue with SEK-1000. Here is my issue,
I have a Samsung ES8000 TV with SEK-2000 evolution kit. I am not able to access wifi if i connect my Evo kit to the TV. But if i remove the Evo kit i am able to access internet through wifi. Is it a problem which can be fixed?
Can someone plese help?
afsalva is offline
post #1895 of 2265 Old 12-03-2014, 12:09 PM
Liked: 0
Anyone else having wifi issues with SEK-2000 & ES8000 TV? I am not able to ocnnect to a wifif network if i atatch Evo Kit to my TV. But if i remove the Evo Kit i am able to access wifi networks. Can someone please help?
Actually my SEK-2000 is the replace Samsung sent for the same issue with my SEK-1000. But i think this one also has the same issue.
afsalva is offline
post #1896 of 2265 Old 12-04-2014, 08:35 AM
Liked: 0
Fixed
Using the last post from the below link i was able to fix the wifi issue of my UN55ES8000 + SEK-2000.
http :// forums.cnet.com/7723-13973_102-615399/samsung-es8000-wifi-network-problem/
Here is what is mentioned in the post
Problems: Ue65es8000
wifi search network and after that suddenly skip out ....
no connect to wifi
just connect to first wifi that i config at the first time
in secret menu: sometimes i saw wifi MAC and sometime it show fail massage
solution :
put tv in stand by mode
push mute > 1 > 8 > 2 > power ( it is secret or service menu )
be careful, don't change others things
go to: Control > sub option and change "wifi region" and chose A
go back
go to: SVC > SVC restart
now your tv will be restart again and ask you to config it
I hope it work for you to
Please report you test here
afsalva is offline
post #1897 of 2265 Old 12-05-2014, 05:02 PM
gamermwm's Avatar
Quoted: 83 Post(s)
Liked: 93
So I noticed that there was a new software update notification for my SEK-1000. I'm probably not going to update again since I remember hearing somewhere that Samsung was ending support for Dolby Digital/DTS support on certain older models
What is the meaning of life?
www.iamsecond.com/films
gamermwm is offline
post #1898 of 2265 Old 12-17-2014, 05:53 PM
Watcher12's Avatar
Does the SEK-2000 update the F8500's HDMI to 2.0?
Watcher12 is offline
post #1899 of 2265 Old 12-18-2014, 04:24 AM
Quoted: 1393 Post(s)
Liked: 587
I don't really know but I am curious as to why it would make any difference as the F8500 isn't a 4K display.
JimP is offline
post #1900 of 2265 Old 12-18-2014, 08:09 AM
Watcher12's Avatar
3D gaming via PC at 1920x1080, 60fps.
post #1901 of 2265 Old 12-18-2014, 09:40 AM
poppagene's Avatar
Quoted: 602 Post(s)
Liked: 383
no
poppagene is offline
post #1902 of 2265 Old 12-19-2014, 03:27 PM
Liked: 0
So, have the UE40ES8000 and trying to get the SEK-1000 running on it. Was able to get it almost all the way there but...no wireless anymore. Have been on the phone with Samsung support, just went through a RM session but still no dice. Updated to the new firmware for the TV (2015 version, released today) and followed the samsung rep's instructions to the letter. Was able to see the wireless networks during the setup but not able to connect. Now, after a few tries, they don't even show up.
Have upgraded to latest firmware for the SEK-1000: 1013.0. but still no wireless.
Tried getting into the menu afsalva mentioned above but don't see it, the TV just turns on when I press the '1' in the sequence
Any suggestions for what else I can try?
Arne de Booij is offline
post #1903 of 2265 Old 12-21-2014, 09:57 AM
Liked: 0
I have 2 native Samsung TVs and am thinking of purchasing Evo Kits in January - could anyone please tell me whihc ones I need for which TVs and whether I should expect any issues?
Model Code:UE55ES8000UXXU
FW 2015.5
Model Code:UE40F6500SBXXU
FW 2102.2
Do I need evolution kit SEK-1000 or SEK-2000? or something else?
fabhead is offline
post #1904 of 2265 Old 12-22-2014, 04:05 PM
Liked: 0
My instructions are for US model TV (UN series). For international TVs (UE series) you need to use Info -> menu -> mute -> power
see the below Youtube video. Check the comments section also
Search for "Samsung led tv factory reset" in youtube. I am not able to paste links here.
afsalva is offline
post #1905 of 2265 Old 12-25-2014, 10:37 AM
Quoted: 59 Post(s)
FW 2015.5
FW 2102.2
Don't buy an EK, they are just trouble.
It's buggy as hell with my 55ES8000.
Bluetooth problems, 3D, problems, netflix sound problems, netflix starting problems, wifi/ethernet problems.
I need to restart my TV to fix these bugs, but it doesn't completely fix them.
myst4ry is offline
post #1906 of 2265 Old 12-25-2014, 02:04 PM
poppagene's Avatar
Quoted: 602 Post(s)
Liked: 383
More likely the wifi module crapped out
post #1907 of 2265 Old 12-28-2014, 12:47 AM
Liked: 0
Samsung came out too, mine and took tv away.....replaced evo kit
now it remember things after a cold start, but now a new set of issues with the evo kit showed.
now the smart remote works for about 2 mins after switching on then stops, if you you pair the remote again it comes up "not available" And it doesnt like wifi, have to run cat5 to it from router.
defiantly do not recommend getting one
sky190176 is offline
post #1908 of 2265 Old 01-01-2015, 07:44 AM
Chris Hansen's Avatar
Quoted: 127 Post(s)
Liked: 48
Do folks think there will be a 2015 edition of the Evolution Kit to replace the SEK-2000 so that the F8500 will get another update? If so, when do the new Evolution Kits usually get announced and released for purchase?
Chris Hansen is offline
post #1909 of 2265 Old 01-03-2015, 11:20 AM
scubascotland's Avatar
Need some help please.
I'm in the UK and have a Samsung UE65ES8000UXXU fitted with a EVO 1000 kit.
I've been having problems with the WIFI network connection dropping intermittently.
I was offered a EVO 2000 kit to try so carefully went through the installation procedure and when I got to reconnecting the power cable the TV continuously power cycles on and off until the power cable is disconnected again. Nothing can be done via the remote.
I called Samsung support and initially the service rep said the EVO 2000 wasn't compatible with my TV but eventually agreed that it was.
I had already checked I had the latest firmware via the online facility but she said I had to install the latest which was currently only available via the website download to USB stick. This was version 2015.5 dated 19th December 2014.
I can't get an option to upgrade the Firmware via USB no matter what I try, even with the network disconnected. How can I upgrade the Firmware.
I can't see how a firmware upgrade is going to stop the TV power cycling, I think there's a problem with the power board now. I also can't see how a Firmware update is going to stop the WIFI network dropping.
Does the newer EVO 2000 kit draw more power and has damaged my power board on the TV?
Thanks in advance.
scubascotland is offline
post #1910 of 2265 Old 01-03-2015, 11:35 AM
priuscat's Avatar
Quoted: 395 Post(s)
Liked: 175
Thanks in advance.
I don't have your version of TV (I have UN55F9000 with SEK2500U/ZA) I found when I had my DNS set to 8.8.8.8 or 8.8.4.4 the network would disconnect. But when I set the DNS to automatically detect the disconnect problem went away. Maybe in your case 8.8.8.8 or 8.8.4.4 set manually would work.
UN65JS8500FXZA and UBD-K8500/ZA
Slim Port Nano Console
UHD Content CY-SUC05SF/ZA WD Western Digital My Passport Cinema
UHD Video Pack CY-SUC10SH1/ZA Tivo Bolt Roku 4
Sennheiser RS175 Digital Wireless Headphone System
Etekcity 4K x 2K 4 Port High-Speed HDMI Switch 4 Port USB 3.0 Hub
priuscat is offline
post #1911 of 2265 Old 01-04-2015, 02:13 AM
filmfreundCH's Avatar
Thanks in advance.
I had problems with wifi and the EVO Kit 1000 as well - I got rid of them by assigning specific channels for the bands in my router (instead of having them set to automatic).
Perhaps it helps in your case as well...
scubascotland likes this.
TV: Samsung 78JU7500 / BR: Samsung H5900 (region- & code-free) / Audio: Sonos "5.1" / Streaming: ATV4 (with Infuse) / NAS: Time Capsule & WD My Cloud
filmfreundCH is offline
post #1912 of 2265 Old 01-04-2015, 07:21 AM
poppagene's Avatar
Quoted: 602 Post(s)
Liked: 383
Thanks in advance.
Does your wifi still work woth the evo kit removed? Mine doesn't and there have been meny reports of the wifi module going bad.
As for the continual rebooting, try removing the evo kit and make sure that it is seated properly.
As for the firmware, every time I remove an evo kit and go back to the tv, the firmware on my tv resets to an earlier pre-evo kit version. Make sure to upgrade the firmware with the evo kit off before installing or reinstalling it.
post #1913 of 2265 Old 01-05-2015, 04:02 PM
mf26's Avatar
Yes, I'm pretty sure when the ES8000 was announced there would be 4 Evolution Kits for it. Samsung have just this past hour at CES talked about Tizen their new OS for their 2015 range of TV's. New Evolution Kits typically come out May/June time.
mf26 is offline
post #1914 of 2265 Old 01-07-2015, 03:50 AM
DELTAsnake's Avatar
Quoted: 45 Post(s)
I was a little worried that there is no announcement of new Evo Kit's/One Connect Box's, but Googleing for any announcement of this years kits I noticed that there are articles from last year saying they were a no show last year also. I guess CES is to early for them to announce Evo kits.
Samsung UA55HU9000, Samsung HW-J7500, Xbox One, PS4, Wii U. Plus a bunch of old consoles.
XBL: DELTAprime, PSN: DELTAsnake, Wii U: DELTAprime
DELTAsnake is offline
post #1915 of 2265 Old 01-07-2015, 03:36 PM
p5browne's Avatar
Quoted: 2793 Post(s)
Liked: 2110
I would definitely NOT upgrade to the Tizen for a long period of time unless having a can of Raid available! - Bugs!
p5browne is offline
post #1916 of 2265 Old 01-07-2015, 05:48 PM
poppagene's Avatar
Quoted: 602 Post(s)
Liked: 383
I'm ready -- can't be any buggier than the SEK-2000
post #1917 of 2265 Old 01-09-2015, 12:46 PM
mf26's Avatar
Some of my most recent Samsung purchases have lead me to believe their products are pretty much in Beta for the first 6 months of their release.
I recently sold my SEK-2000, the final factor being I'd noticed it was still running the old BBC iPlayer without the monthly series catchup, yet the ES8000 has had the newer version for sometime now.
I may well settle for the SEK-4000 in 2016 what with it supposedly being the last supported model for the ES8000, however so far I think EK kits are too expensive for what they offer in return.
mf26 is offline
post #1918 of 2265 Old 01-12-2015, 11:47 AM
poppagene's Avatar
Quoted: 602 Post(s)
Liked: 383
My es7500 with the SEK-2000 installed had been rebooting while watching at first just occaisionally and over time the frequency increased. After an attampt at working with tech support didn;t resolve things, I asked for a replacement. Samsung told me I needed to contact my retailer even though it is 8 months since it was shipped. I've never heard of a company pushing warranty replacements of an accessory to the retailer such a long time after the purchase. (SEK-1000 is reinstalled and after 4 days, no further reboots.) My retailer is contacting Samsung to sort out why Samsung thinks the retailer should be responsible for sending a replacement.
post #1919 of 2265 Old 01-12-2015, 03:23 PM
I've already had the SEK-2000 replaced but the TV still reboots. I think perhaps the EVO kit has damaged the board in the TV. I'm waiting for Samsung to sort it out.
post #1920 of 2265 Old 01-14-2015, 12:56 PM
castana's Avatar
Liked: 0
Originally Posted by poppagene View Post
Works fine on my ES7500 and the sek2000 browser, smart hub, and new remote are worth the upgrade to me.
Hi poppgene,
Sorry for my daring for this but since I have a problem with my Samsung ES-7500 and my SEK-2000( the TV does not detect the EVO kit) and like I have seen in this forum that you have the same TV and EVO KIT and it works fine for you, for it, Could you help me with that?
Thanks in advance
Alejandro
castana is offline
Reply LCD Flat Panel Displays
Samsung 46 Led Smart Tv , Samsung , Led Hdtv , Samsung Un46es8000 Led Hdtv , Samsung 75 Inch Led Smart 3d Hdtv Un75es9000
